Sponsored by: Wheel Design
First front spoiler scrape - OUCH
Old Oct 1, 2023 | 09:53 AM
PaulCPO's Avatar
PaulCPO
Default First front spoiler scrape - OUCH
Well, it happened. Leaving a local establishment last night. Even with the FEL engaged and going diagonally, scraped the living crap out my front-end splitter. It's low profile too. Weird thing is that it did not scrape going in so not sure what happened.
It's pretty gnarly underneath and while you cannot see it as my wife has reminded, I still know it's there.
Anyone try to smooth this kind of thing out? I work with thermoplastics professionally so thinking I will try and smooth and buff it out.
For the nay sayers on FEL, this would have happened many times before if I did not have it.
Popular Reply
Oct 1, 2023, 05:28 PM
combatninja's Avatar
combatninja
Treat the OEM Z51/low pro plastic splitter as a disposable wear item. Replace it every couple of years.
Old Oct 1, 2023 | 10:07 AM
Kracka's Avatar
Kracka
Was it just the regular Z51 splitter? If so, they're cheap and readily available as used take-offs on this site. I think I sold mine for $50. As basically disposable plastic, it's probably not worth the time/effort to attempt repairing it.
Old Oct 1, 2023 | 10:48 AM
papillion's Avatar
papillion
Default Mrs. Einstein
Your wife is pretty smart. So is my wife. We should listen to them more.
Old Oct 1, 2023 | 10:50 AM
dashotgun's Avatar
dashotgun
it is a car ouchies are bound to happen. As stated the poverty splitter is inexpensive. This is why i won't put on an expensive cf front splitter
Old Oct 1, 2023 | 11:59 AM
jthornton's Avatar
jthornton
I had the same thing happen to me going in a parking lot no problem coming out even with front up I touched so I backed up and did a crazy diagonal exit taking up both the in and out side of the entrance/exit. Coming from a C5 the front lift is mandatory for me.
JT
Old Oct 1, 2023 | 04:51 PM
PaulCPO's Avatar
PaulCPO
Thanks for the love, guys.
It's the LP splitter. I think you are right. Probably not worth the effort.
Yes, they are.
Yeah. I won't be dropping 1200 bucks on a CF one any time soon.
JT
Wished I had had the forethought to do that. I just wasn't paying attention coming out.
Old Oct 1, 2023 | 05:28 PM
combatninja
Old Oct 1, 2023 | 06:49 PM
Zormecteon's Avatar
Zormecteon
Even with front lift, I've scraped. (didn't think it was THAT steep). But when I was under the car at the dealership I couldn't see any scratches...
They may not be on yours either. .. RELAX.
Old Oct 1, 2023 | 06:55 PM
Maxie2U's Avatar
Maxie2U
I have a ACS C8 5VM Style Front Splitter in Carbon Flash. I have scraped and hit it hard a few times and by the sound thought it was toast. To my continued surprise and amazement its fine.
Old Oct 1, 2023 | 07:11 PM
Avanti's Avatar
Avanti
Curb "feelers" are all they're good for. Drive it until it gets too beat-up, then remove or replace it.
Old Oct 1, 2023 | 08:10 PM
Maxie2U's Avatar
Maxie2U
I disagree that’s all they are good for…
Old Oct 1, 2023 | 08:52 PM
jipper's Avatar
jipper
I have never been so back and forth on a feature as I am with front lift....I never had an issue on my c7z51 and have tried my buddies c8 in my drive and didn't have an issue...but I literally change my mind hourly on it...2600 is so much for something that I don't think I need...
Old Oct 1, 2023 | 08:55 PM
HAD2HAV2's Avatar
HAD2HAV2
I'm on poverty splitter #2. It was a big Ouch! I replaced mine with a carbon fiber hydro dipped.
I need to take a photo.
Old Oct 1, 2023 | 11:01 PM
TonySopranosHairline's Avatar
Personally, I think Front lift is only worth it if you have a steep drive way and you know you'll risk scraping every day. But in reality, $2600 buys you at least 10 OEM Z51 splitters. I don't think it's worth spending $2600 to protect a a piece of plastic that is $200-$250 and it takes A LOT of harsh scrapes to actually break the splitter. Put that money into mag ride or a nicer interior.
Old Oct 1, 2023 | 11:31 PM
Since you say you can’t see it unless under the car, I would just leave it for now. Chances are another mishap will occur and then you can determine whether or not to replace it depending on how obvious the damage is.
Old Oct 2, 2023 | 07:23 AM
jthornton's Avatar
jthornton
For me the front lift was a no brainer as you never know what kind of obstacle you will be up against. I have several places programmed into the GPS and use it often going in and out of parking lots.
JT
Old Oct 2, 2023 | 08:27 AM
jipper's Avatar
jipper
yeah…and I brought my buddies over and it doesn’t scrape at all without having the lift engaged, the front air deflectors do barely make contact but they are only 3.5 inches so guessing that’s pretty nomral.
i read on another old thread that the approach angle on the c7 z51 was 9 degrees and this one is 9.7 degrees without lift….if so I never had any issues on c7 so hopefully good
To First front spoiler scrape - OUCH
Old Oct 2, 2023 | 10:33 AM
Ricketts's Avatar
Ricketts
Can't see it? Keep on truckin!!
Old Oct 2, 2023 | 11:27 AM
Fast Dawg's Avatar
Fast Dawg
It all depends on where you live and drive the car. I've got over ten locations already programmed into my front lift memory where all of my previous Corvettes scraped.
Old Oct 2, 2023 | 11:34 AM
RKCRLR's Avatar
RKCRLR
I just used my front lift yesterday where I know I would have scraped without the lift (and other cars did). I was directed to overflow parking that was in an upslope field with a makeshift ramp to get over the curb. The ramp was only wide enough to take straight on.
