Sponsored by: Wheel Design
Condensor protectors
Old Dec 12, 2023 | 03:25 PM
Tsnloiv's Avatar
Tsnloiv
Cruising
Default Condensor protectors
So Chevy charges $425.00 for these. Is there an after market version that is good and perhaps a bit cheaper?
Old Dec 12, 2023 | 03:53 PM
sTz's Avatar
sTz
I went w/Customs Car Grills 4-piece for around $100. I just wanted to get something on there quick, and planned to upgrade later as I wasn’t thrilled about the zip ties, but I was able to position them so only 3 were visible on each side, and I mean visible by stooping down and looking closely. I honestly forgot about them and have moved on…
Old Dec 12, 2023 | 03:56 PM
Ricketts's Avatar
Ricketts
I put the Billfaro ones off amazon for $79.95 on mine, and they fit great. If I bought another C8 tomorrow, I'd buy the same ones again.
Old Dec 12, 2023 | 05:20 PM
Ron_Attleboro_MA's Avatar
Ron_Attleboro_MA
I also went with Billfario. There are others for under $100. Make sure they don't have rough cut edges!
No sharp edges!!!
Old Dec 12, 2023 | 05:22 PM
kromdom's Avatar
kromdom
Ron and Ricketts, a million thanks to you both. I will be ordering Billfaros for both front and side rads
Old Dec 12, 2023 | 05:28 PM
Tsnloiv's Avatar
Tsnloiv
Cruising
Thanks so much!!
Old Dec 12, 2023 | 06:55 PM
Dave'sManCave's Avatar
Dave'sManCave
Did the same they installed fine and do the job. Can't see how a piece of screen is worth $500 from GM or some of these other places... They are simply figuring that if you can afford a Vette, you will pay stupid money for $19 worth of steel mesh...
Old Dec 12, 2023 | 07:02 PM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
I bought these too. Nice product...horrible instructions. I wouldn't pay the $$$$ GM is charging.
Old Dec 12, 2023 | 07:08 PM
winders's Avatar
winders
No sharp edges!!!
That mesh looks much too fine. Here are the factory parts and notice the size of the mesh:
If the mesh is too fine, it will block too much airflow....not good.
Old Dec 12, 2023 | 08:26 PM
mortelec's Avatar
mortelec
😂 Probably the dumbest post yet.
Old Dec 12, 2023 | 08:40 PM
$500 for mesh screens is nuts.
Dave'sManCave
Well, GM was concerned with installing mesh from the factory, because they said it does limit airflow and could impact cooling. Watch a video with one of the corvette engineers, discussing that...
Here is the set that I installed:
https://amzn.to/470fMQS
Old Dec 12, 2023 | 09:48 PM
winders's Avatar
winders
As someone who has designed oil cooling systems for race cars and has experience incorporating metal mesh systems to protect oil coolers, I actually know what I am talking about. So, please, keep showing us all your ignorance...
Old Dec 12, 2023 | 09:53 PM
mortelec's Avatar
mortelec
let's see
4000 mile road trip through desert heat, tracked my car in heat and drag raced in heat and never came near overheating. I disagree with these causing an airflow issue. Not ignorant just facts.
Old Dec 12, 2023 | 10:01 PM
Dave'sManCave
let's see
I was the one that mentioned overheating, and I was quoting a video of one of the corvette engineers saying that in an interview, when asked why GM didn't incorporate screens in the first place... He was talking to how the DCT fluid has a very narrow window of operating temp and that it was sensitive to that and so they didn't want to reduce airflow to the coolers...
Old Dec 12, 2023 | 10:15 PM
winders's Avatar
winders
let's see
Chevy seems to agree with me that restricted airflow can be a problem:
...and that is with the Factory grille guards that flow quite a bit more air than the cheap Amazon version you use.
To Condensor protectors
