Battery Concerns
Since the advent of AGM batteries, I have noticed longer charge retention and longer life in all my power sport stuff. My 21 Silverado has auto stop/start and it has an AGM battery in it as part of a more robust starting system , would be nice if GM spec'd the Vette with an AGM, seeing how long most of the sit.
Our own Andybump has tested the battery drain after the car is shut off and the 10 minute RAP times out. It's very low, even below GM's published standards. If your battery has really lost 60% of its charge with the usage you describe, I suspect a bad battery.
Where is this documented? I've only seen this recommended for the E-Ray. There's nothing in my 2021 owners manual suggesting this. My Stingray sat for 3 weeks with no charger attached and it started up as if it had been driven the day before.
This is what's confusing me ? I think you and I know what's going on I just don't want to confuse other readers because it is a very common error that C8 owners think they are seeing battery voltage. Most older cars did actually show battery voltage !
Same reason you see a step change in oil pressure and some low readings, all to save energy and both "computer controlled."
Of course if the engine is running the system voltage and battery voltage are going to be very close to the charging voltage. Not to be confused with the so called "open circuit" battery voltage that should be measured with no current in or out of the battery. And, if you want to estimate the battery state of charge using a voltmeter, that needs to be the open circuit battery voltage measured after waiting several hours for the surface charge to decay.
I do not know if that can be accurately done with the DIC meter, even if one waits several hours and does not start the car, but rather puts it in service mode. The problem, I think, is that when the car wakes up, even without starting, the draw (I measured) after waking up the car then turning it off was still 10-11 amps (not ma). That drops in steps to 10 ma after 12 minutes with the ignition off but it will not drop like that if the ignition is in the service mode.
Of interest my BMW X5 SUV is 2 1/2 years old and my FOB had a dash display of "Weak Battery." My wife had some difficulty opening the locked door so changed hers as well. Both wee reading low in the Green OK band BUT the new batteries where at the top of the green OK band. Smart to charge at 2 to 3 years!
Also caution buying from Amazon! May be OK but had a 3 Volt battery I bought last year for my Street Rod Remote had two others in the package. One read in the Red, Weak Zone, the other showed hardly any voltage. Never know what are legit or bootlegged.
But for me, it's my DD I use and like to use to make minimum ~60 mile round trips to town ~3 times a week on back fun roads. I don't want to mess with my CKET charger.
BUT C8 owner's should understand you can let it sit 4+ weeks without plugging it in. Starting with the C7 Corvettes have circuits to shut off all significant power after ~10 minutes. Andy Bump measured a parasitic current draw after 10 minutes of ~15 milliamps. 12 volts X 0.015 amps = about 0.2 Watts. To put in perspective: According to the Journal Environmental Science & Technology, the average iPhone charger has a standby power consumption of 0.26 wattswhen not in use, consuming up to 2.24 watts charging. So yep, that cell phone charger you have plugged into the wall when not in use is consuming more power than your C8 when parked for more than 10 minutes!
My C8 is always ready when I need it, even after being parked no battery charger for 3 weeks when on vacation! The Corvette is better than most cars! If a DD why waste my time messing with a plug going and coming for a one year longer life?
Do folks do that for all their DD's. Heck the wife's new BMW does not have the C8 circuits that keep parasitic current draw of ~15 milliamps, (0.2 Watts of power!) If you have a garage queen fine. It you only drive once a week fine BUT the C8 parasitic current draw is better than most cars, why single it out! Believe some think it's like a Corvette of the past. The C7 and C8 are NOT!
I look at batteries like tires, always change earlier than many to get best hydroplaning performance. One incident not worth postponing expenditure for new tires.
Feel the same with batteries that have variable life depending on many things including manufacturing variations. I'll change a battery just before winter when voltage measurements say it's getting low. Saving a few dollars is not worth a PIA incident of no start in winter!
