Agm?
Popular Reply
The C8 has a fairly sophisticated charging system. It has a battery monitor module. It will evaluate the state of charge of the battery by measuring the open circuit voltage (more or less) after the car has been sitting for several hours. When the car is running it measures charging voltage (system voltage) and also measures current going in and out of the battery (it sits between the battery negative terminal and negative battery cable). It has 5 charging modes depending on various factors. But the main mode is the fuel economy mode - basically the car targets a battery state of charge of 80%, which is an open circuit voltage of 12.42. That actual charging voltage for that charging mode is between 12.5v and 13.2v. This will presumably result in the targeted open circuit voltage (after the car has been off for 4 or more hours) of 12.42, which corresponds to the 80% SOC for the FLA.
So, the concern folks have is that the voltage vs state of charge is different for an AGM battery vs a Flooded Lead Acid (FLA) battery. Which leads to statements that they have a "different' charging profile. See attached charts.
The attached chart shows the difference. When fully charged a FLA open circuit voltage will be 12.6. But for an AGM it will be 13. A charger that is designed to take an AGM to 100% state of charge (SOC) might overcharge an FLA if the goal was 100% state of charge, and if the charger was only looking at voltage.
But, based on the description in the Service Manual, the goal of the C8 charging system is 80% state of charge. So for the FLA that corresponds to an open circuit voltage of 12.42. If the charging system in the car charged the AGM battery to an OC level of 12.42 volts, that would result in the AGM battery having a SOC of 76% instead of 80% (I did a linear interpolation of the chart values to get that). That is a negligible difference.
Its possible that the charging system goes further, and interprets the charging voltage vs current in real time - potentially making adjustments based on that - meaning it might be able to sense battery differences and adjust accordingly. But none of that appears in the description of the charging system in the Service Manual.
and virtually all consumer charges now charge AGM and lead acid without any modification.
As I have noted before, there is a field in the scan tool that indicates battery type - and options include Default, Flooded Battery, AGM Battery, Enhanced Flooded
Battery, or Lithium Battery. However, the expected value is "default", and there are no instructions anywhere in the manual about setting it differently for different batteries. There are, however, plenty of instructions for the setting of external test equipment to the proper battery type, but none regarding changing the setting in the car.
AGM just means that the electrolyte(which is the same as a regular battery) is suspended in media (glass mat).
AGM stands for Absorbed Glass Mat, It can be a direct replacement with no special equipment or adjustment to charging systems or stand alone 12v battery chargers.
They're also better in cold weather, have a lower self discharge rate, can take a beating (last longer) in charge/discharge cycles, work upside down (although not recommended in your C8), and are maintenance free. They are usually pricier, though, but worth it.
As soon as the factory battery wears out in any vehicle I've owned since the early 2000s, I always replace it with an AGM. Drop in replacement. Done.
