Sponsored by: Wheel Design
PPF problem on hood
Old Jul 12, 2024 | 09:23 PM
Hockeyfun1's Avatar
Hockeyfun1
Default PPF problem on hood
Any idea what's causing this? My PPF installer first said they won't cover it because it's probably from the wipers. I've never touched the wipers and they're nowhere near there when they move. They cut a little back and fixed it for free but said next time is on me. It's also slightly doing it on the other side by the other wiper too.
Is this a defect in installation or something that I'm supposedly doing?
Old Jul 12, 2024 | 09:53 PM
QuickSilver20's Avatar
QuickSilver20
How far under the backside of the hood does the ppf go? It almost looks like it’s not wrapped enough around the hood to create a good seal. also normally the underside of the hood isn’t as smooth as the rest of the car so it may not be able to make a good seal.
Another possibility is that the ppf is contacting the plastic piece when you open and shut the hood creating this issue. If it’s from contact from shutting the hood I would think cutting the ppf before the seam rather than wrapping should solve the problem.
regardless definitely seems like an installation error and not sure how the wipers would ever come close to that area.
Old Jul 12, 2024 | 09:56 PM
tadda's Avatar
tadda
Veteran: Marine Corps
That doesn't look like damage from a wiper.... How far under the edge of the hood was the PPF wrapped?
Old Jul 12, 2024 | 10:06 PM
Hockeyfun1's Avatar
Hockeyfun1
I'll have to look when I get home to see where's it wrapped to. They basically cut the bad looking piece off and said "good to go, you'll pay next time if it peels up" which it sounds like it will if it's not even wrapped in that area anymore.
Old Jul 12, 2024 | 10:29 PM
Zymurgy's Avatar
Zymurgy
Moderator
That's what it looks like to me. The gap between the hood and the black plastic gets very narrow where the damage is.
Old Jul 12, 2024 | 11:15 PM
Maxie2U's Avatar
Maxie2U
Clearly they F-U by not tucking it under the hood’s edge. So you need to tell them to do that or they have to keep replacing it. I would be tempted to put them on the spot by asking them to explain just how a wiper can reach/touch the hood!
Question, what brand of PPF did you buy?
Old Jul 12, 2024 | 11:28 PM
Hockeyfun1's Avatar
Hockeyfun1
I asked them how it's coming in contact and they said "we don't know but it is". They then were acting accusatory like I changed my wipers and did it. I told them they're the same wipers that came with the car and I never touched them.
It's XPEL.
Old Jul 12, 2024 | 11:48 PM
tadda's Avatar
tadda
How long ago was this installed?
Old Jul 13, 2024 | 12:09 AM
Hockeyfun1's Avatar
Hockeyfun1
2 years ago
8100 miles on the car (22).
Old Jul 13, 2024 | 12:30 AM
RocketRob's Avatar
RocketRob
I just happened to see your thread listed as I opened up the Forum and clicked on it. Since I have a C6, I am hardly ever in this section. There is a member with a C6 who wraps cars for a living and probably can give you a great analysis of what is happening to yours. Maybe send a PM to Stayinstock and he can probably provide you with some good information. Just a thought.
Old Jul 13, 2024 | 01:10 AM
Tanilroy's Avatar
Tanilroy
Cruising
Also have PPF on my hood. Applied for whole car over 2 years ago as well and happy with it. My hood seams stayed intact and don’t look like what’s happened to yours. I hope you can resolve. The black trim on your front does seem like it might be rubbing the hood in some areas where the PPF seam is on the hood? That black trim is not rubbing the hood on my car. I agree that the wiper is nowhere near the affected area.
Old Jul 13, 2024 | 02:02 AM
I can’t see how your wipers could mess with the PPF - does not look like they come close to touching the hood. I’d get a second opinion from another shop.
Old Jul 13, 2024 | 07:44 AM
Scruff Vette's Avatar
Scruff Vette
Typically the back edge of the hood has some rough areas in the paint where it's not polished as smooth at the flat surface of the hood is. I had that on my C7s and my C8. I'm thinking the installer could not get the PPF to completely seal to that area.
Old Jul 13, 2024 | 07:55 AM
mtraylor2001's Avatar
mtraylor2001
As others have said. It truly looks like an install issue. Others with same car and PPF done have this issue. Turn the wipers on for the installer to show them the blades is not the issue. Also if the installer is xpel authorized installer. The install and the product are covered for 10 years. Since the installer is telling you that its your fault and not the install. I would take it to somewhere else and have it fixed correctly and get reccomendation from xpel or local references.
Old Jul 13, 2024 | 08:15 AM
Grand_Wish's Avatar
Grand_Wish
You can take this up with Xpel directly and they can advise you if this is on the installer which from what i am seeing is a bad install. Look over the warranty info to see how they cover defects and such. Keep us posted!
https://www.xpel.com/warranty-information
Old Jul 13, 2024 | 08:22 AM
Walt White Coupe's Avatar
Walt White Coupe
Caused by the wipers??? What a crock of poop. So now the side they "fixed" is even cut back further. Doesn't sound like a fix to me.
Old Jul 13, 2024 | 08:39 AM
Maxie2U's Avatar
Maxie2U
It's XPEL.
Find out if they are an authorized XPEL dealer better yet see it there is another authorized XPEL dealer near you then drop by that shop and ask them to look at it. I’m confident they’ll tell you it’s a bad install and they may even be willing to replace it under Xpel’s warranty. Even if they don’t you can use their feedback if your current shop continues gives you crap.
BTW, after it’s gets replacement you can report the issue to XPEL. They really care about their brand and will decertify a shop and on occasion blacklist them from being able to buy product from XPEL.
Find An Authorized XPEL Installer
https://www.xpel.com/clearbra-installers
To PPF problem on hood
Old Jul 13, 2024 | 08:47 AM
qwazipsycho's Avatar
qwazipsycho
I also have a 23 purchased in October (22) and PPF. I don't have this problem but if I did, and I couldn't see how it contacts anything else, I would definitely be holding the PPF installer responsible. The fact that they don't want to warranty it says they are not worth your business.
Old Jul 13, 2024 | 08:49 AM
Grand_Wish's Avatar
Grand_Wish
I guess he doesn't care about reviews!
Old Jul 13, 2024 | 09:52 AM
YO-EL's Avatar
YO-EL
BS
2 yrs down the road, they obviously don't want to deal with it.
This is 100% an install issue just coming to the surface now...
