Sponsored by: Wheel Design
How often do you launch control?
Old Jul 26, 2024 | 08:50 PM
reef12344's Avatar
reef12344
Default How often do you launch control?
Any chance of real damage?
I would think they would limit it or reduce access if it was an issue but just wondering how often do you use it?
Popular Reply
Jul 26, 2024, 09:14 PM
jipper's Avatar
jipper
Not once - don't even know how to do it
Old Jul 26, 2024 | 09:04 PM
Acpantera's Avatar
Acpantera
Maybe just 6 times in 4,500 miles.
Old Jul 26, 2024 | 09:06 PM
Ron_Attleboro_MA's Avatar
Ron_Attleboro_MA
I now have 4300 miles. I just can't do it. I do love fast acceleration in the first 3 gears.
The Stingray feels so strong in the first gears, not so much after 70mph.
Tadge said in the ZR1 release the the ZR1 could go from 80 to 200 to 80 in 25 seconds(maybe he said 20 seconds?).
I don't mind stopping to let people turn in front of me just so I can accelerate afterwards. Even my wife loves the sounds and the DCT shifts!
Old Jul 26, 2024 | 09:13 PM
BADBIRDCAGE's Avatar
BADBIRDCAGE
Three and a half years and 20,000 miles. Have used launch control a half dozen times. Last time was last week. Works flawlessly.
Of the 30 plus C8 owners in our Corvette club less than four of us have used launch control.
Old Jul 26, 2024 | 09:14 PM
jipper's Avatar
jipper
Old Jul 26, 2024 | 09:21 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
It is definitely Hard on the drive train.
Old Jul 26, 2024 | 09:26 PM
sshallen's Avatar
sshallen
Never. Seems inappropriate on public roads and I don't have access to a private area.
Weird to me that people will put painters tape over their trackwrap under their Novistretch to drive four exits on the interstate but will hammer the drivetrain...
Old Jul 26, 2024 | 11:25 PM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
Hell, I've got a convertible and I've never had the top down...
Florida's way too hot...
Old Jul 27, 2024 | 12:03 AM
Rocketmanwpb's Avatar
Rocketmanwpb
Not yet, owned since January 20th and 4,300 miles.
Old Jul 27, 2024 | 01:03 AM
Zormecteon's Avatar
Zormecteon
Another vote of NOT ONCE. .. I don't track the car and would be crazy to use it on the street.
Old Jul 27, 2024 | 01:32 AM
khearon23's Avatar
khearon23
I don't know how many times I've launched mine, but I definitely don't feel like I'm damaging anything. It's not a concern at all.
Old Jul 27, 2024 | 06:29 AM
BADBIRDCAGE
Launch control exercise was my wife’s favorite thing at Corvette Owners School at Spring Mountain. The drive train is completely pre-loaded when you release the brake pedal. No instant shock like side stepping a clutch pedal and between each gear change. GM designed and built it into the car and says you can use it. It’s not a daily thing for me but I certainly don’t fear my car will break because I engage it occasionally.
Old Jul 27, 2024 | 07:11 AM
Chip02's Avatar
Chip02
Every time I take someone new for a ride. And then some. A couple of dozen times with 7800 mi. on it. At the COV at Ron Fellows they noted that the warranty covers unlimited use of launch control. And it does feel much less abusive to the car than flooring it from a dead stop.
Old Jul 27, 2024 | 07:27 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Never seen anything since I got my 2020 C8 Z51 that says it's harmful. This is the only thing I had found from GM was from a video on what it does:
Interesting comment with no details made by GM’s Chief Engineer, Piatek: “We found that during very aggressive launches we can drive torque through both shafts/clutches simultaneously which improves the 0 to 60 times.”
Road and Track interpretation of that statement was: "With the C8's Performance Launch mode, the car will actually use the inertia of the engine coming down between revs to propel the car forward. Chevy calls these "Boosted Shifts," and they're only used with a Performance Launch.
In a recent post it was indicated GM is doing what some other performance DCT's do. Put power thru both clutches simulations BY SLIPPING THE CLUTCHES. I posted that must be for only milliseconds. A member who works in the automotive control field said with some performance DCTs it's near 100 milliseconds.
I have used Launch Control several times AFTER I had over 1500 miles on my E-Ray. Prior I had made many non-Lauch Control GM 0 to 60 Dash Tests. After I learned some "tricks" I consistently achieved 2.5 seconds, one with my ~190 lb visiting cousin in the car who has a Porsche Carrara 4S mechanical AWD. He noted the E-Ray was a much more aggressive Launch. On his next visit I'll make one with Launch Control, hard to describe how aggressive the Launch is on street pavement.
This has been my best after Launch Control:
Now before folks without an E-Ray get their shorts in a knot, GM subtracts dragstrip rollout similar to Car Mags when they post 0 to 60 times. so the actual number is higher. How much? Don't know but my SWAG is it could be ~0.3 seconds. That may be because they are using an array of 3 accelerometers to define start that can detect minute movement in any direction. Not using satellites 12,555 miles in the sky! GM has 4 of those arrays in the C8 to provide control input to MRC shocks. Note they don't send signals to satellites to do that! BTW Tesla Electronics G-TECH Pro uses an array of accelerometers to detect start for their measurements.
To achieve this number (which others have done as as well) I used what I learned from prior launches without launch control. Have to:
1) Get the EV battery at 100% charge, not it's normal 80%. I do that by driving in Z-Mode set to Track for >10 miles which also heats the tires;
2) Further heat the tire surface just prior to the test by accelerating at WOT from ~10 to >95 mph;
3) Followed by immediately braking at ~0.8 "g" just prior to the Test;
4) Also had low fuel in tank, great weather.
Note my "passenger" only weights 11 lbs. Remi' is like Enzo in the movie "Racing in the Rain," he loves speed
I do use Launh Control sparingly but think what I do all the time is "tough" on the DCT. But did that for 4 years with my DCT, never an issue. The 25-mph speed limit rural road I live on is off a 4-lane divided highway. There is traffic in both directions, going ~70 mph to and from Myrtle Beach and I95 South. It's often heavy with RV's in the packs of traffic. Don't want to have folks slow for me so I apply the brakes very aggressively traveling in Z-Mode Power set to Track. No need to use the downshift paddle as in that Mode it downshifts several gears, Rev Matching each all in the blink of an eye. Love the sound!
Old Jul 27, 2024 | 11:09 AM
SMOKN C8's Avatar
SMOKN C8
Same. At the Ron Fellows COS, they tell you have it, that is what you have a warranty for.
If it was "damaging" to the car, GM would not have made it an option.
Old Jul 27, 2024 | 12:45 PM
5632's Avatar
5632
Is that why Vipers did not have it?
Old Jul 27, 2024 | 12:47 PM
johnodrake's Avatar
johnodrake
Moderator
I used it a few times early on. When I saw < 3.0 0-60, that was enough. I don't go to the strip.
To How often do you launch control?
Old Jul 27, 2024 | 12:52 PM
johnodrake's Avatar
johnodrake
Moderator
It is not an option, all C8s have it. Its use is optional.
Old Jul 27, 2024 | 01:35 PM
Avanti's Avatar
Avanti
Never have, never will... just more gobble-de-gook I've never needed.
Old Jul 27, 2024 | 02:31 PM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
I did it a few time at Ron Fellows but never on my own C8. Some noted above it is too tough on car, but at Fellows it was noted GM has stated that you can do it as often as you like on C8 with full warranty backing. That was not so on C7 and they only gave us a sheet of how to do it.
