Sponsored by: Wheel Design
Reduced Trunk Heat Solution!
Old Aug 20, 2024 | 02:00 PM
Sixgun95's Avatar
Sixgun95
Default Reduced Trunk Heat Solution!
This weekend I installed https://www.heatshieldproducts.com/hp-stealth-shield The heat reduction is significant, I measured between 30-40 deg reduction, enough that it is no longer "stupid hot" in the trunk.
I started another thread on this a few weeks ago, go to it and see post #35 for pictures. https://www.corvetteforum.com/forums...runk-temp.html
Works great, easy install, recommend it if you want to see a difference.
Popular Reply
Aug 21, 2024, 11:31 AM
Sledge Hammer's Avatar
Sledge Hammer
Not trying to bust anyone's chops here, but when one says they got a 30 to 40 degree reduction and another says they got a 25 to 30 degree reduction what that says to me is they did not actually measure the amount of reduction they got or they would have specified it with an exact number. Kracka is the only one that I have seen that has specified before and after results and they don't come anywhere near the results suggested in this post.
Old Aug 20, 2024 | 10:48 PM
v1 rot8's Avatar
v1 rot8
30 degrees is a big drop. I used a product called Blockit based on a YouTube video I saw. Made no difference. Compared trunks with another HTC after an hour drive together and they felt exactly the same. Seems like it was around $130 or so. How much was the product you used?
Old Aug 20, 2024 | 11:30 PM
Nicely done and a 30* drop is noteworrhy.
Old Aug 20, 2024 | 11:41 PM
Glen e's Avatar
Glen e
I got good luck layering the back panel with two different foils, the first one is a thick three-quarter inch foam silver insulation, the outer layer is a gold thinner surface. Both lowered my rear trunk 25 to 30°.
Old Aug 21, 2024 | 12:04 AM
Sixgun95's Avatar
Sixgun95
$164 on Amazon.
Amazon Amazon
Called Heat Shield, they said they receive many calls about C8 trunk heat, he knew exactly what I needed. He said if I can get to the top of the exhaust to wrap it with their exhaust shield fabric. After the heat shield I installed, nothing else is needed.
Old Aug 21, 2024 | 11:31 AM
Sledge Hammer
Old Aug 21, 2024 | 03:41 PM
VetteDrmr's Avatar
VetteDrmr
I was about to say the same. It's tough to get real A/B results: ambient temp., duration and engine load, and what are you measuring? Surface temp of the front panel, or temp of a sample baggage article located in a specific location? IMO a 5 degree drop in luggage articles would be significant.
Again, not trying to rain on anyone's parade, but I'd rather do that than give someone unrealistic expectations.
Have a good one,
Mike
Old Aug 21, 2024 | 03:55 PM
bmanahan's Avatar
bmanahan
What is the impact on the trunk space after you install this?
Old Aug 21, 2024 | 04:22 PM
Kracka's Avatar
Kracka
Zero impact. I was asked in another thread, but to answer the question here as well, the total weight added was less than 1 pound (14 ounces to be exact).
Old Aug 21, 2024 | 04:23 PM
Kracka's Avatar
Kracka
Have a good one,
Mike
See below:
Originally Posted by Kracka
Here's my DIY project for ~$50 with actual data to back it up:
https://www.corvetteforum.com/forums...for-trunk.html
Old Aug 22, 2024 | 07:42 PM
thunderstrike's Avatar
thunderstrike
Thank you, great post on #35. Fronk gets warm too from the radiators. Are you planning to do the front and post pics? Sure appreciate the advice the bottom is where the insulation is needed.
________________________________________
Currently own:
2019 Mustang GT Premium 6MT Daily Driver
2023 Corvette Stingray 2LT (Ron Fellows Corvette Performance School Graduate)
2017 Porsche 718 Cayman
2009 Jeep Wrangler Rubicon
Old Aug 22, 2024 | 11:55 PM
C-17LoadVette's Avatar
C-17LoadVette
This is a sports car. Not a place to put gold insulation. When have you seen a Lambo, Ferrari, R8, Porsche, etc with that type of insulation. Our Vette's were not meant to have insulation like the gold etc. They are sports cars meant to enjoy with speed and have fun. Accept the fact you have to put the ice cream and milk in the frunk; the crackers and canned goods in the back if you are shopping. If not shopping the beach chairs in the back and the beach cooler in the frunk.
Old Aug 23, 2024 | 12:01 AM
Sixgun95's Avatar
Sixgun95
Currently own:
Not planning to do the frunk, had not noticed any abnormal heat.
Old Aug 23, 2024 | 09:24 AM
Dan Hintz's Avatar
Dan Hintz
Well, thank God you've arrived to tell us all how we should be using our own vehicles! <pshew> I was about to waste a few dollars and improve the utility of my car, but now that you've stepped in to show us the error of our ways, I can go back to limiting what I put in my trunk/frunk. And wow, I almost did something different than Lamborghini, Porsche, etc... talk about egg on MY face!
Keep up the good work!
Old Aug 23, 2024 | 10:22 AM
Glen e's Avatar
Glen e
“ you should not use gold insulation on a Corvette! “
Well now I’ve read it all…when I didn’t think this forum could get any more weird…
Old Aug 23, 2024 | 10:53 AM
Sledge Hammer
To Reduced Trunk Heat Solution!
