This may be old news to others, but I have always struggled with different pressure readings between my hand held tire pressure gauge, the compressor gauge and the in car dash reading. I was surprised to find that putting the car in the accessory mode and starting the compressor that the TPM is very responsive and that I could watch the dash and turn off the compressor when the desired pressure was reached. In the past I thought there was a delay in the TPM readings. Sure is a lot easier than guessing how to compensate for differences between the three readings.
you do realize almost every tire gauge known to man is INACCURATE right?
I feel the same. I buy quality gauges, try to keep the pressure within a pound or two of 30 cold, but it can be frustrating watching the TPMS readings fluctuate. I trust a quality gauge and use the TPMS to warn me of an emergency while driving. Got a little nail in my right rear now that I know Discount is gonna decine to patch (right on the inside of the first line of tread), and I hate to swap out two new rears with only 12K on these.......only losing a pound a day, so dealing with it for the moment.
FWIW I think the inexpensive dial gauges are repeatable, they're just often not accurate / not calibrated correctly. I have one that is basically 5psi off, to get 35 in the tire you need 40 on the gauge. Knowing that, it's fine. From what I've read it's really common with them, but they're repeatable. The stick style ones have another variability in how they are used on top.
Doesn't matter much to me anymore since I picked up one of the little 20v Dewalt compressors. You just set the thing and it runs till it hits the setting, and so far it appears to be very accurate and consistent. Also works as a air pump for airbeds and such. Pretty happy with it. The Milwaukee ones are supposed to be good as well.
I had mine all reset to factory settings, each tire was almost 2 PSI low.
I noticed an amazing difference immediately, correct tire pressure is everything on this car.
Over the years my experience has been and still is that GM's on-car systems are not particularly accurate or reliable. I always use and rely on Meiser handheld gauges on the street and when racing.
Been frustrated lately with tire gauges. My 10 year old accurate with a balance hose so filled two tires at a time, failed. Have had digital gauges but batteries go quickly. Looked at a Car Mag article and bought what they said was best, not cheap. Within a year battery was dead. So I'm using my old 2" diameter mechanical Bourdon tube gauge. It matches the car's pressure gauge within about a 1/2 lb. As long as it does, will not buy another!
Now if you wanted, could have it checked against a know standard. For our welding gauges we had a test standard that was calibrated annual to a know standard by an outside firm. Production regulator gauges were checked against that gauge at a frequency set by QA.
Ahhh... the difference between "accuracy" and "precision" in reference to gauges.... .. They're not the same thing.
That's true, but it doesn't matter how precise the display is if it's not accurate. One of my digital gauges has a readout in .5 psi increments, the other .1 psi. The IP 1 psi. Those are measures of precision. Neither figure tells me how far off from actual the reading is (accuracy).
I think if one has two decent gauges from different brands, and they're within about 1/2 pd of each other, you can accept theiy're accurate enough. It's unlikely two totally different products are going to be off by the same amount.
I recall reading an article (in Road & Track, IIRC), probably 40 or more years ago, where the author visited a Schraeder factory that made pencil tire pressure gauges. He expected some high-tech machine for checking accuracy. Turned out they just compared them against each other, and if one varied by more than a small amount from the rest they just threw it out.
Originally Posted by Myfourth1
Set the PSI, pull the trigger and works every time, perfectly.
I would still test it against a separate gauge periodically, to make sure it stays accurate and doesn't drift.
I have an old Michelin digital gauge, and Jaco digital. Both pretty close. I use an auto-stop pump and set it to 1/2 lb over. ..
By the way, I have set my (phone) calendar to remind me to do the air on the last Saturday of every month. .. .. The C8 is "up" for the winter so I won't check it again till the cover comes back off.
If you check your tires regularly and they are consistent one tire to another, you know you don't have an inflation issue. A leak from a nail etc. Michelin Man will tell you 10 degrees F can make a 1-2 psi delta so I don't get to OCD with the number. I'm looking for the anomaly. Once a month, I go all the way around and adjust to 30 psi cold. This works for me.
From my track days, I found "Longacre" tire pressure gauges the very best. In fact, it's reading is +/- 1 psi compared to the car reading (Corvette and Toyota Sienna). In contrast, the gauge on the portable tire inflators tend to read higher than actual.
Long story short, if you buy a trustworthy tire pressure gauge, then problem solved ! Cheers,
Michael
Funny story (to me, anyway) about my Schrader gauges. Yes, I've had several...at one time. Plus a lot of other pencil gauges. A friend loaned me his digital gauge which wasn't expensive but it was pretty good.
Just for kicks (this was back in the early 2000's), I pulled out all my pencil tire gauges---almost all were the metal outside with a plastic indicator. I took the friend's digital and got a reading on all my tires (1 or 2 were off by a pound). With each of the pencil gauges I walked around the car and took the pressure they would register. That was, I think, seven circles of the car. Guess I could've done it all in one go-round, but I was energetic.
Only one of the el cheapo tire gauges were different than the digital one. And the one that was different was off by just under a pound---couldn't say if it was a half or more or less. I was pretty surprised. So was my friend.
I learned a long time ago, buy a quality gauge and stick with it. Certainly occasionally check it against another known quality gauge. But never ever waste time having 2 or 3 gauges and checking with all of them, going to drive yourself crazy.
Learned from all my time at the racetrack, quality gauge plus knowledge of tires and what performance you are trying to achieve, looking closely at the tires you will know pretty quick if you are running the correct pressures or not.
