Sponsored by: Wheel Design
Convertible Tonneau
Old Mar 11, 2025 | 11:39 AM
myvette2015's Avatar
myvette2015
Default Convertible Tonneau
Is there sufficient clearance to open the convertible tonneau in standard size two car garage with garage door in open position?
Also can you stop the tonneau while in the opening stages with your hand.
Old Mar 11, 2025 | 11:41 AM
dmwphoto's Avatar
dmwphoto
Originally Posted by myvette2015
is there sufficient clearance to open the convertible tonneau in standard size two car garage with garage door in open position? yes
also can you stop the tonneau while in the opening stages with your hand.
no.......
dmwphoto's Avatar
dmwphoto
yes to question one, no to question 2
Old Mar 11, 2025 | 11:55 AM
McBeef's Avatar
McBeef
can't imagine how any answer in this forum would put me at ease with question #1.
the height of the convertible (at its highest point) while operating is well documented. measure the lowest point in your garage. then you'll have the only answer you need.
Old Mar 11, 2025 | 05:13 PM
rvsullivan's Avatar
rvsullivan
St. Jude Donor '20-'21,'24-'25
Just did this very thing yesterday at a ceramic coating installer. Standard residential 2 car garage and at it's highest point it cleared the door by about 5-6 inches.
If you are opening it manually, you can stop the operation by releasing the button!
Old Mar 11, 2025 | 05:29 PM
Andybump's Avatar
Andybump
In mine I can. I have no idea if mine is considered "standard". You need to measure yours for yourself.
Do not stop the movement with your hand. Release the top button and it stops.
Old Mar 11, 2025 | 06:03 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
I measured the open height in the driveway. Then transfered this to the lowest point in the garage with the garage door up.
Old Mar 11, 2025 | 08:46 PM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
My garage has a 9 ft ceiling and I open it all time inside. I have at least 2 ft clearance.
Old Mar 11, 2025 | 10:52 PM
StormTrooper R's Avatar
StormTrooper R
I have 10 foot ceilings in my garage with 8 foot doors, but like yours, it is not a standard height.
Old Mar 12, 2025 | 08:54 AM
Andybump's Avatar
Andybump
Default What is "standard heigh" for a garage
Is there such a thing? I did a quick search - not exhaustive. Here is statement I found. I think it makes it clear that one must measure their actual height to be sure. Damage can run into the the 1000s of dollars if a mistake is made.
8 feet
Detached Residential Garage Plans Custom Home Drafting Plan Shop Train To Love House Plan ~ garage plan ideas garage plan software garage plan builder Garage Plans, Garage Ideas, Plane, Barndominium, Custom Homes, House Plans, How To Plan, Design, Aircraft
The standard garage ceiling height can vary, but according to international building codes, the minimum height is 8 feet. However, it can range from 7 to 12 feet or more depending on design and construction. The standard height of an overhead sectional garage door is 7 feet, which is considered the industry standard. Some recommendations include a ceiling height of 8 to 9 feet.
Old Mar 13, 2025 | 08:20 AM
Rapid One's Avatar
Rapid One
I can open it in my garage with a center of garage mounted opener. If you have a single door and the opener is above the car I would say no.
Old Mar 13, 2025 | 10:07 AM
frankjr's Avatar
frankjr
Have a two-car garage with single door so opener is center mounted so no issues, also helps that the ceiling height is 9'.
To Convertible Tonneau
