Sponsored by: Wheel Design
Automatic Mode question after downshift
Old Apr 19, 2025 | 03:26 PM
D0lphan72's Avatar
D0lphan72
Default Automatic Mode question after downshift
Happy Saturday everyone!
Last night I had a dream that I was cruising down the highway in my non- z51 in “my mode” when a mustang GT approached me and asked to do a drag race from 60 MPH. In this dream I agreed and although I was in drive mode I held the left paddle so it could downshift to 3rd gear. When we started moving i didn’t realize I had to shift myself from 3 -> 4 even though I was still in drive and not manual because I thought it would naturally upshift at redline.
The next time I have a dream about racing someone on the highway would there be anything I can do to ensure I can manually downshift in drive mode but the car will still shift itself once I floor it? Thanks!
Old Apr 19, 2025 | 03:35 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
  • When in auto mode and you over ride it the DCT will stay in manual mode which means you bumped off the rev limiter when your car did not up shift automatically. If you paddle down for a hard pull you must be ready for an almost instantaneous upshift. The car will revert to auto in about 10 seconds long after you hit the rev limiter!
FastLaneShoji's Avatar
FastLaneShoji
Sleep tight, SWIM.
Old Apr 19, 2025 | 03:46 PM
Ron_Attleboro_MA's Avatar
Ron_Attleboro_MA
Dream, check for police first! How do you have your Z-button setup.
Best to have in "Track-Mode" and the car will insure you are ready to dream on.
Old Apr 19, 2025 | 04:04 PM
D0lphan72's Avatar
D0lphan72
have never really used Z mode because I felt the other modes have what I need covered. Can I set Z mode to be able to automatically shift for me in the scenario I posted on?
Old Apr 19, 2025 | 04:15 PM
L72_coupe's Avatar
L72_coupe
Z mode is fully customizable. set engine, trans, braking, etc to "track"...suspension to "tour" or "sport" for street use
Old Apr 19, 2025 | 04:18 PM
D0lphan72's Avatar
D0lphan72
yeah I did know that. Just wasn’t sure if engine settings would effect if I could downshift in auto and it would still upshift automatically
Old Apr 19, 2025 | 04:25 PM
Ron_Attleboro_MA
You can only manually shift in "M-Mode".
If you downshift in any other configuration, the car's computer will override.
You should not need to downshift in "Track-Mode".
Old Apr 19, 2025 | 04:31 PM
L72_coupe's Avatar
L72_coupe
Trying to help your dream
'track' setting will choose the lowest gear possible for the speed your traveling, and upshift normally at redline
hit Z instead of the paddle, no worries
Old Apr 19, 2025 | 04:33 PM
RKCRLR's Avatar
RKCRLR
The driver modes won't effect whether or not the DCT upshifts at redline. Using the M button on the console puts the DCT in permanent manual mode and it will bounce off the rev limiter. However using the paddles puts it in temporary manual mode. In temporary manual mode it is supposed to automatically upshift at redline.
"The C8 has two manual modes. If you pull a paddle while in Drive, you get a temporary manual mode, which automatically times out, or can be exited sooner by holding the upshift paddle. In this mode, the car will automatically upshift at redline. If you press the M button in the center console, you get full manual mode. There's no time out, and the car won't upshift at redline."
https://www.roadandtrack.com/new-car...pecs-analysis/
Maybe your dream wasn't real.
Old Apr 19, 2025 | 04:36 PM
FrankT's Avatar
FrankT
It's not clear why a manual down shift (in any mode) while in Auto mode would hit the rev limiter ..... But it does unfortunately. This would be a great improvement to have a setting for this!! Porsches will shift and not hit the rev limiter, not programable.
Old Apr 19, 2025 | 04:38 PM
D0lphan72's Avatar
D0lphan72
good write up thanks. Looks like I should try holding the left pedal longer when I downshift for it to go back into auto
Old Apr 19, 2025 | 04:58 PM
BPHORSEGUY's Avatar
BPHORSEGUY
Tons of mis-information here ! In the ops dream he was driving along in auto when the Mustang pulled up and obviously wanted to race.
The op correctly wanted to be a gear or 2 lower BEFORE the start just as you would with a stick. Being in track or Z mode would have caused the car to downshift AFTER the start while the Mustang was already in max acceleration. In the given scenario unless the Mustang wants to give you a few seconds to "setup " only thing you can do is pump the down paddle a couple of times till you are at optimum powerband and then mash the pedal being ready for an instant manual paddle upshift before red line. Having the car down shift a couple gears in Z mode or not After the start, although only taking a few tenths of a second will not be conducive to a win.
Old Apr 19, 2025 | 05:08 PM
BPHORSEGUY's Avatar
BPHORSEGUY
No... that is not what you want to do! READ the above
BANG BANG 1 OR 2 DOWNSHIFTS WITH PADDLE THEN MASH THE ACCELERATOR and almost instantly do a paddle upshift before hitting rev limiter
If that doesn't work nothing else will !
Old Apr 19, 2025 | 05:50 PM
BPHORSEGUY's Avatar
BPHORSEGUY
Absolutely false..On the street I leave my car in auto almost all the time and override with paddles all the time. Unless I stupidly try to downshift to "over redline" or up shift to a "severe lugging situation" the computer does not even think of overriding my commands. An average passenger would not even know when I am shifting versus the computer. I have done this thousands of times over 2 years so please do not try to tell me I'm wrong!
Old Apr 19, 2025 | 05:58 PM
Zormecteon's Avatar
Zormecteon
I would..
hit Z mode, and punch the gas.
It will pick the proper gear faster than you can pull that downshift when you hit the go peddle. ...
Track mode will change the suspension setting to too hard for the street. .. Z mode can set the engine/shift to track mode. ...
Old Apr 19, 2025 | 06:46 PM
BPHORSEGUY's Avatar
BPHORSEGUY
You don't hit the downshift paddle after you hit the gas you do it before. when you hit the gas the car is already in the correct gear and nothing is faster then that. In the ops scenario the race starts when he hits the gas, in my scenario the car is setup before the go signal so is faster since the car needs to do nothing, down shifts have already happened!
To Automatic Mode question after downshift
Old Apr 20, 2025 | 11:29 AM
Zormecteon's Avatar
Zormecteon
by milliseconds.
Old Apr 20, 2025 | 01:09 PM
Andybump's Avatar
Andybump
The driver modes won't effect whether or not the DCT upshifts at redline. Using the M button on the console puts the DCT in permanent manual mode and it will bounce off the rev limiter. However using the paddles puts it in temporary manual mode. In temporary manual mode it is supposed to automatically upshift at redline.......
Yes, it is, but adding to this - "When in Temporary Manual Paddle Shift mode, the transmission will automatically upshift if the accelerator pedal is pressed all the way to the floor". So, if the OP had the pedal fully floored it should have up-shifted like you said. Otherwise its going to be stuck in the Temporary Manual Mode until the aggressive driving stops for several seconds - here are the exit criteria:
To exit Temporary Manual Paddle Shift mode
do one of the following:
• Hold the + paddle for more than one second.
• Drive at a steady speed without
manual shifts or aggressive cornering for
several seconds
• Lower vehicle speed to 6 km/h (4 mph)
or less.
Old Apr 20, 2025 | 02:25 PM
Red Mist Rulz's Avatar
Red Mist Rulz
No. If you manually override auto by using the paddles, the car will stay in manual mode for a period of time. You can put it back into auto mode by hitting the M button on the console twice, but that probably wouldn't be quick enough in your situation.
But if you just mash the pedal to the floor in auto mode, the car will still downshift without you having to hit the paddle. It might lag a bit compared to using the paddle, though.
