Sponsored by: Wheel Design
A/C Issues
Old Jul 10, 2025 | 04:37 PM
Adaviss's Avatar
Adaviss
Default A/C Issues
I have a A/C issue I have to decide how to deal with. I just got a $4k estiment to have it fixed. I am six weeks out of warrenty. GM offer the possibilty of some coverage after I pay the full amount. I know others have had the same issue. There is no way of knowing if the replacement is the same part a better one or worse. $1500 in parts the rest labor. I am fully able the bolt the parts in my self but not fill and reprogram it. What do you all think?
Old Jul 10, 2025 | 04:49 PM
5632's Avatar
5632
I have never herd of programing an A/C.
Old Jul 10, 2025 | 09:22 PM
RKCRLR's Avatar
RKCRLR
See if an automotive AC repair facility can do it.
Old Jul 11, 2025 | 07:51 AM
Get a second opinion and see what corrective action, and cost, is recommended.
Old Jul 11, 2025 | 09:16 AM
Red Mist Rulz's Avatar
Red Mist Rulz
What parts?
Old Jul 11, 2025 | 11:11 AM
Adaviss's Avatar
Adaviss
There is no question the compressor is gone and it sent metal through the system. It is what it is. The parts total is $1700. The only question is well GM kick in any on the deal. Which they will only do after I pay in full.
Old Jul 11, 2025 | 11:32 AM
Rocketmanwpb's Avatar
Rocketmanwpb
Has GM told you they would contribute to the repair cost? I had a similar issue with a defective clutch on a C5. The car was just out of warranty. I was able to prove the clutch was defective and GM paid for the parts only.
My argument was that the clutch was an item that should have lasted for around 200,000 miles.
Good luck.
Old Jul 12, 2025 | 08:38 AM
Adaviss's Avatar
Adaviss
Good luck.
After I pay they might do something. They will not say anything until its done and I have paid.
Old Jul 12, 2025 | 08:39 AM
Adaviss's Avatar
Adaviss
Also the cost has gone up to $9k. The dashboard has to come out.
Old Jul 12, 2025 | 09:59 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Good luck.
Back when I got my 1st new car a 1967 4 speed, the clutch pressure plate broke (cracked) in ~6 months not many miles. Dealer service manger agreed with me the clutch disk and flywheel looked new it was not abused. Looked like the cast iron clutch pressure plate had a defect that caused the failure. BUT he said it's a wear part and not covered. We can keep the car apart and when the GM Service Rep look at it when re comes to visit.
About a week later he came, said yep looks like a defect and we'll cover.
PS: Can understand GM position as until they check all removed parts and define it was a defect they will stand by "Past Warranty."
I'd spend the money as you can't sell a car without AC at least in our area. BTW see where AC lines go from the front AC Condenser to engine compressor to Evaporator under passenger dash.
I paid $800 for a new AC Condenser on my 6 month old C6 because servcie manager said GM won't pay as hole "Probably caused by rock." I brought Condenser home and showed hole caused because Condenser was dropped before installation, perhaps by supplier. GM agreed and refunded the full $800. I took pic of old condenser I brought home and showed it was bent where flattened tube with hole was located. My thought re GM's probably caused by rock was it was dropped propr ro being installed. Took 6 months for weakened are to break!
Old Jul 12, 2025 | 01:57 PM
rmorin1249's Avatar
rmorin1249
St. Jude Donor '15-'16,'18
I would sell or trade it. Unless you have something from GM in writing I would not spend $9k. What year is your Corvette?
Old Jul 12, 2025 | 02:01 PM
RKCRLR's Avatar
RKCRLR
If the OP truly wants to do the work himself he could probably find an automotive AC repair facility to evacuate the system and recharge it when the work is complete. He might also need to have the components that aren't removed (lines, etc.) flushed out.
Old Jul 13, 2025 | 08:22 AM
Undy's Avatar
Undy
Having a very good relationship with your dealer is paramount. They stand to be about the best way to get GM's subsidy for the repair. They will go bat for you and hopefully convince GM to assist in paying a percentage of the repair. I had a similar experience with my C5 coupe with the well known fuel tank leaks. GM paid 50% of the repair and I only had to roger up with the other half. I DID NOT have to pay the whole bill up front, just 50% of it. Your dealer should be able to tell you all this in advance of the repair.
Old Jul 14, 2025 | 10:52 AM
Adaviss's Avatar
Adaviss
The dealer I bought it from is no help. Another dealer in my area is much better working with me. They can also do the repair next week as the dealer I bought it from would be 6 weeks out. Its a 22 C8 with 19k miles.
Old Jul 14, 2025 | 10:57 AM
Phil1098's Avatar
Phil1098
If it lost a compressor, why would the dash need to be removed?
Old Jul 14, 2025 | 12:22 PM
RKCRLR's Avatar
RKCRLR
They are probably concerned that the failed compresor spread contamination throughout the system and don't want to take the risk that the condenser would re-contaminate the rest of the system unless they remove it for a thorough cleaning. I believe that there is equipment/methodology that can decontaminate the system without removing components (other than the compressor and receiver/dryer) but they not have the equipment or expertise.
Old Jul 14, 2025 | 01:00 PM
Phil1098's Avatar
Phil1098
I've had compressors come apart and I flushed out the system and had zero issues. I think they're just trying to soak him for big $$$$$$.
To A/C Issues
Old Jul 14, 2025 | 01:10 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Wait. The price went up $4k just because the dash has to come out?
The dash came out of my C7 at the local dealer for blending motors replacement. I think parts and labor together were $ 1850.00
I think this dealership is a real stealership.
If the issue is not Corvette related per se, as in AC components only, an AC shop that is reputable should be able to flush and replace all the bad parts for a fraction of the OP is being quoted by the dealer.
$9k for any AC work is absurd.
Old Jul 15, 2025 | 01:48 PM
Adaviss's Avatar
Adaviss
The process at this point. Remove the compressor and see if it sent metal through the system. If not its 3 to 4k. If it has then the dash and front body work has to come out to replace all components. That is the bigger number. I have heard the debates about cleaning instead of replacing and its a roll of the dice not too replace. The openings in the condensers are just too small to clean. The part numbers for the compressor say it has not been updated. I do not understand the process but I can get for sure coverage for part of it before the work and then beg for more after.The bottom line is new cars are not made to be repaired. Just replaced. I heard it said do not buy new trucks, rebuild old ones.
Old Jul 25, 2025 | 02:34 PM
Adaviss's Avatar
Adaviss
Default A/C issues
A Big shout out to Taylor at Smith Chevrolet in Idaho Falls. Got me scheduled right away, fixed the a/c and got GM to pay for almost all of it without me having to do anything.
