Sponsored by: Wheel Design
Does a base model stingray need splash guards?
Old Aug 29, 2025 | 08:53 PM
JMO, but adding splash guards and/or side skirts are valuable insurance against paint damage from rock chips.
Old Aug 29, 2025 | 09:23 PM
BJ67's Avatar
BJ67
Yes, and buy the GM ones from a dealer.
Old Aug 29, 2025 | 09:37 PM
Walt White Coupe's Avatar
Walt White Coupe
Probably not need but a good idea. They finish off the look of the wheel wheel and they protect the paint. Lot's of choices on eBay that are just as good as the GM part and a lot cheaper.
Old Aug 29, 2025 | 10:49 PM
brian3's Avatar
brian3
Every time you turn the wheel the front tires protrude so being narrow does not really mean they are immune.
Old Aug 30, 2025 | 09:49 AM
NewOldFart's Avatar
NewOldFart
It seems like with the wheel turned stuff coming off of the wheel would be thrown under the car on one side and away from the car on the other, but heck I don't know.
Anyway, appreciate the feedback from everyone. Have some oem guards on order. Now I will fret about whether or not I think I need radiator guards . . . . being paranoid can be kind of expensive.
Old Aug 30, 2025 | 10:15 AM
DonC7's Avatar
DonC7
I have them along with Scrape Armor radiator protectors
Old Aug 30, 2025 | 10:17 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Easy install for ~$60. Yep I added AC Condenser protective Mesh from Custom CarGrills who have been in the business for over 30 years. They offer large Mesh like Scrape Armor who started selling theirs several years AFTER the C8 came out in 2020. However they also offer 1/2 size mesh that lets in half size bugs, which most of us used. That was my biggest concern with mesh, would I be able to remove bugs that get thru with mesh in place.
But cheap enough and easy install. IMO better than Scrape Armor as double size bugs get thru their mesh to clog the AC condenser! Also Scrape Armor only cover the outer large openings. Bugs ad debris can also get in thru the two center openings. Not a high %age BUT not zero!
Here are some Pics of what you can buy from CCG:
Yep for ~$60 you can buy a sheet of powered coated Aluminum (not plastic.) That is enough to do the two large openings, the two smaller center opening and enough to cover the two rear fender scoops!
Don't want to cut your own? CCG sells precut. The 2 large, or 4 to provide 100% protection.
Member blaun made Protective Mesh for the 4 front openings and two rear fenders from one sheet.
I installed my CCG 1/4 inch mesh that lets in half the size bugs! In 4 years of hot summers in NE SC, some days 100+F no increase in coolant temps with aggressive street driving. I (and others) installed with NO wire ties showing by removing the grill bar. Only requires removing the same 3 grill screws as Scrape Armor requires for install. Once out just slide grill bar out. Installs the same way. Also no cut edges are visible, all behind the OEM Grill. If you want to cover the edges (no reason to) CCG sells Neoprene edging that fits their mesh. Their stated business philosophy is keep prices low so manual labor is on you. Better than paying someone in Chana as all there product made in USA! This is a How To Doc, mostly Pics with long captions. Comers member blaun's 4 front grill install:
http://netwelding.com/CF_Splitter.pdf
Old Aug 30, 2025 | 10:57 AM
boomer76's Avatar
boomer76
OP-Yes I think it is a good investment. I did not get the oversized guards, but the GM OE seem to work very well for me. As an aside, way back in 23, I bought mine direct from the (Chinese) manufacturer at half the price, as had to wait over a year for the car. Installation was easy and took less than 10 minutes a wheel.
Old Aug 30, 2025 | 11:20 AM
ZORANGE's Avatar
ZORANGE
Originally Posted by corvettezman
I did the XL splash guards on all four. I ordered them from EOS. They were very nice, but the OEM clips work better. I just moved them and threw away the ones that came with the XLs.
I also have these XL splash guards and found there is no need for rocker panels if you have them, unless of course if you like the aesthetic look of rockers. Also the carbon flash paint perfectly matches the other CF accents. 14k miles and no chips on the side body panels or rear behind the wheels. I occasionally hear a rock kicked up but the splash guard catches it.
Old Aug 30, 2025 | 01:41 PM
Blue Lion's Avatar
Blue Lion
My 2024 doesn't have them
Old Aug 30, 2025 | 02:00 PM
23cpe3lt's Avatar
23cpe3lt
Anyone have color match guards?
Where did you purchase them?
Old Aug 30, 2025 | 02:15 PM
bartruff1's Avatar
bartruff1
Originally Posted by EvanD
I don’t have them. 2020.
I don't have them on a bone stock 2021....no problem....in the collector world we call chips and dings " patina ",
patina - Google Search
Old Aug 30, 2025 | 02:26 PM
  #33
RKCRLR's Avatar
RKCRLR
Some people prefer less patina...
Old Aug 30, 2025 | 05:39 PM
  #34
JerryU's Avatar
JerryU
Yep, when I sold my 1st two Vettes a 1988 and 1993 in mint condition they had excess "patina" on the rocker panels and behind the rear wheels. To get top @ those areas need to match the rest of the car.
The remainder in Pics:
When I got my 3rd Vette a C6 was determined not to have any "patina" (how silly.) I bought contoured, body colored large deep splash guards. They worked for the rear and for rocker panels up to the rear that were dinged. So even these large more like a bit gorpy MUD Flaps did not provide 100% protection in our rural area.
When I got my next Vette a 2014 C7 thought GM knows where the problem is and put clear Plastic PPF on the rocker panels from the door center back to the front of the rear wheel well. BUT turns out that thick cheap [plastic PPF was dinged with a month. Already looked bad. Yellow line I added shows where it was.
I bought aftermarket FULL LENGTH side skirts from LG MotorSports that solved the issue. Pebbles hit under the large flat side skirt and only ants would see them! When I sold the car no extra "patina" and got top $.
My next Vette ,a 2017 C7 Grand Sport also came with some cheap GM plastic as it had 2/3 length side skirts standard. But GM knew the issue was further back and had plastic in front on the rear wheel well. BUT I bought full length side skirts than worked so well on my 2014 C7. I removed the cheap GM plastic as I had on my 2014 C7. Car looked like new when I sold it.
When I bought my 2020 C8 no question I would get full length side skirts. Ordered the GM option 5VM BUT they were constrained. In a month had some small dings as this Tracker showed where Track rubber hit. No Splash guards will not stop dings toward the rear!
So I bought aftermarket copies! Fortunately they covered the dings. When I sold it 4 years later no "extra patina" and got about my purchase price!
Old Aug 30, 2025 | 07:10 PM
  #35
bartruff1's Avatar
bartruff1
I understand one theory is that OCD can start during toilet training.......
ocd meaning - Google Search
Old Aug 31, 2025 | 07:31 AM
  #36
JerryU's Avatar
JerryU
Far from OCD! However when I sell the Vette (which have done with my prior 6 starting, from 1st a 1988) to get best price, can't have what you think as patina! Most normal folks don't like rocker arm dings.
Heck even my 1934 Ford does not have "patina!"
Old Sep 1, 2025 | 08:21 PM
  #37
Action Andy's Avatar
Action Andy
IMO you can never have enough protection! You pay all that money for a C8 so why cheap out and not get the rock guards?? SPEND THE MONEY lol!!! You'll be glad you did..
Old Sep 10, 2025 | 10:37 AM
  #38
NewOldFart's Avatar
NewOldFart
Installed these this week. Not a terribly entertaining job but it didn't take that long and the end result seems good. Found the note above in my 2025 manual for those, like me, who wonder about potential loss of cooling.
