Sponsored by: Wheel Design
Does a base model stingray need splash guards?
Old Aug 29, 2025 | 10:42 AM
NewOldFart's Avatar
NewOldFart
Default Does a base model stingray need splash guards?
My calibrated eyeballs tell me that the front tires on my bone stock SR are too narrow to require splash guards and the wider rear tires are unlikely to throw up anything that mars the paint.
Unfortunately my calibrated eyeballs have been known to lead me astray.
Anyone have a strong opinion in one direction or there other?
Old Aug 29, 2025 | 10:46 AM
EvanD's Avatar
EvanD
CF Community Team
I don’t have them. 2020.
Old Aug 29, 2025 | 11:05 AM
kromdom's Avatar
kromdom
Got "extra wides" on mine (2020) and in my experience, they do an excellent job.
Old Aug 29, 2025 | 11:08 AM
BADBIRDCAGE's Avatar
BADBIRDCAGE
First accessory I put on my 2020. Then grille guards.
Old Aug 29, 2025 | 11:13 AM
OLD_GOAT's Avatar
OLD_GOAT
My 2021 window sticker. Car was custom ordered by MacMulkin and splash guards were an option.
Old Aug 29, 2025 | 11:14 AM
Kenny94945's Avatar
Kenny94945
The underside near the front rocker panel and the rear panel under the exhaust tips take rock damage.
Perhaps other long-term owners can address whether rock chips are occuring on the side of the body.
I installed the OEM larger splash guards, which protect the sides, but not the undercarriage I mentioned above.
Good luck with your decision.
Old Aug 29, 2025 | 11:25 AM
scithera's Avatar
scithera
I go the GM wide ones and they help, but the biggest impact comes from the ZL1Addons side skirts I put on. Those have basically stopped all the pings off the rockers from rocks/pebbles/debris. They may not look as fashionable as other side skirts, but they are functional and durable.
Old Aug 29, 2025 | 11:38 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Glad I got them on my Stingray. Also put them on my ERay
Old Aug 29, 2025 | 01:43 PM
Zormecteon's Avatar
Zormecteon
Mine were a factory order so I can't say if it would be different if I'd never had them, but ....
On a different make and model they made all the difference. I used to get dirt up the 1/4 panel behind the wheels, but NO MORE.
Consider it cheap chip insurance, and put them on.
My 2¢
Old Aug 29, 2025 | 01:48 PM
Jettcity1's Avatar
Jettcity1
The OEM GM splash guards IMHO help out more than you might think.
I would install a set, it does make a difference.
Old Aug 29, 2025 | 02:13 PM
23cpe3lt's Avatar
23cpe3lt
I dont use them but dont drive much in crappy weather. I would get body color match guards if I decide to. I think they disappear when body color.
I actually prefer ppf if worried about damage. Just a small area of ppf would do the job.
Old Aug 29, 2025 | 02:27 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
I did the XL splash guards on all four. I ordered them from EOS. They were very nice, but the OEM clips work better. I just moved them and threw away the ones that came with the XLs.
I also did the 20mm black spacer mod on all 4 wheels. So now my wheels fit flush with the fenders and quarter panels, and the XL splash guards don't look out of place.
Old Aug 29, 2025 | 02:39 PM
papillion's Avatar
papillion
Default Only The Shadow Knows
Will you throw up big rock? Will you be forced onto an unexpected detour that is sand and gravel? Who knows? Just maybe.
The splash guards from eBay and amazon are $60, OEM look and finish. Super easy to install. 15 minutes if your smarter than a box of roxx. So do you need them? Just maybe.
Old Aug 29, 2025 | 02:50 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Depends where you life and drive. In my area wide deep splash guards not good enough. Only fill length side skirts work. Buy what kind you like BUT full length. Added to my 2014 C7, 2014 Grand Sport and my 2020 C8.
Old Aug 29, 2025 | 03:05 PM
roy826's Avatar
roy826
I added the GM guards to my car week one. GM paid for them so might as well. They have worked ok to date. They’re not the widest ones out there but fit into the cars lines nicely.
Old Aug 29, 2025 | 03:47 PM
Scruff Vette's Avatar
Scruff Vette
^^^ First thing I did on my 2025 Stingray.
Old Aug 29, 2025 | 04:16 PM
Joe's Eray's Avatar
Joe's Eray
I would go for it, you never know when or if God forbid you have to drive down a dirt gravel road at some point in time. One of the first mods I got when I got my Eray was order me a set of front guards off of Ebay to protect the lower rockers.
To Does a base model stingray need splash guards?
Old Aug 29, 2025 | 04:47 PM
Slare's Avatar
Slare
Fronts absolutely kick back lots towards your door and the strike zones that protrude back out ahead of the rear wheel. If you have rocker extensions it will help, but then the rocker extensions take the beating. Rears aren't as bad but you still got the little wedge area that will take some depending on your roads. Driving in Michigan I just do them by default. Our highways are filthy, rain, rock filled potholes, rock filled expansion joints, and a few gravel roads... there is no choice.
Given how much they are needed up front, I see them as necessary.
Old Aug 29, 2025 | 04:55 PM
JerryU's Avatar
JerryU
Have used full length Side Skirts on my 2014 C7, 2017 Grand Sport and 2020 C8. All three were flat on the bottom. Could hear the pebbles hit the flat bottom of the side skirts. BUT only ants would see those marks. None show where visible.
In our rural are where I drive, mostly two lane no shoulders. On the road edge are pebbles and dirt. That gets pulled onto the pavement. When the Corvette tires hit, some is thrown back. In fact GM knew where the issue was with the Coke Bottle car shape. For my 2014 C7 Z51 they supplied with the car brom Bowling Green, clear plastic PPF from the door center up to in front of the rear wheel well. However within a month their cheap, heavy plastic was dinged. After I installed full length carbon fiber side skirts from LG MotorSports all dinged stopped. I was able to remove the cheap heavy clear plastic. When I sold the car rocker panels looked new!
Old Aug 29, 2025 | 05:24 PM
wrecker3's Avatar
wrecker3
My 2023 C8 has ACS Rock Guards
