Brakes
They said I needed brakes and rotors so after 1800 dollars later I had new brakes and rotors, today 6 months and around 2500 miles later the mother f'ers are squeaking again? Daily driven no track miles!
Dealer said they probably need more grease on the pads but that cost would be on me?
There was a bulletin on this for the Dealers to fix but my car is past it's warranty being a 2021 with 27,000 miles.
So aggravating about to put it on graigslist
https://a.co/d/9zjS6Th
I agree about it's enough to sell the car.
That is the key can't baby performance brakes and pads. At least occasionally need to apply brakes aggressively. This is my experience and WHY They Squeal. Now to define, most squeal is with light brake pressure at slow speed. If they only squeal backing up probably a different issue causing vibration, why worry!I had the original OEM Brembo pads on my 2014 C7 Z51 for ~6 months. Broke the brakes in as suggested very easy on brakes for the first 500 to 600 miles. At about 1000 miles they started to squeal like a stuck pig at slow speed with low brake force. Dealers may pull the pads and put a small amount of lub on the pads steel sides, GM will usually pay them to do that on warranty. It's Band-Aid that will help for a while but many report it returns. GM won't pay them to stop the cause (there are some safe driving issues) that is on you, by bedding the brakes!
- What is causing the low speed modest brake pressure squeal? Vibration.
- What is causing the vibration? Uneven pad material on the rotors. That causes a skip/slip friction and vibration.
- Bedding (GM calls burnishing) is recommended for Tracking and you can read the procedure in the Owner's Manual under Tracking.
- BUT all pads need to get and MAINTAIN a uniform pad layer on the rotors. Its microscopic but it's that thin layer of pad material on the iron rotor that provides the highest friction with the pad. It's NOT pad on iron (or if CCB's the carbon ceramic rotor.)
Don't need to apply the brakes aggressively the 20+ times outlined for Tracking. Not easy to find a place to do 20+ aggressive brake applications from 60 mph to 10 to 15 mph without ever stopping and allowing about 1 minute brake cooling between brake applications. And ~10 minutes after also never stopping. the whole time (because it would damage the uniform pad material you just created on the rotor before it had time to fully bond to the cooled rotor.)
- For street driving, I find 5 to 7 are enough aggressive braking cycles from ~60 mph to 10 to 15 mph (~0.8 "g" not activating ABS.)
- Then drive a mile at 60 mph (1 minute) to let the pad residual that transferred cool and start to bond with the iron rotor.
- Then must drive ~10 minutes again "WITHOUT Stopping From The Start of the Procedure" to let the now uniform pad material you created fully bond to the rotor.
- The difficult task is finding a safe place to perform even this shortened procedure than that defined for Z51 OEM pads in the Owner's Manual. Your brakes, street driving, will never reach the high Tracking temps the recommended 20+ consecutive braking cycles creates. A reason GM will not reimburse a Dealer to perform. Your car up to you.
My 2014 C7 Z51 OEM Brembo pads stopped all squealing after the aggressive stop mini bedding. An article re the issue said periodically you must use the brakes aggressively to maintain the uniform layer. Particularly necessary with performance pads on a Z51. I do about every drive for fun, braking from highway speeds prior to a turn.
SIDEBAR
BTW switched my 2014 C7 Z51 to low dust pads after foolishly waiting 6 months. I was cleaning my wheels every few trips to town (~200 miles) or the dust not only looked bad it pitted my black wheels.. Switched to Carbotech Street Only pads with low dust. Also used those pads on mt 2017 Grand Sport and 2020 C8 Z51. Never had a squeal and only washed wheels when I washed the cars.
Some replacement pads suggest bedding when installed. They outline the procedure for their pads. My E-Ray CCB's were terrible braking to about 200 miles. I bedded using a modified suggested bedding (GM burnishing) outlined for Tracking with CCBs. I used 10 aggressive braking from 60 to 10 mph cycles, drove one mile at 60 mph after each and repeated. After drove ~10 miles not using the brakes. It was on a limited access 55 mph rural road. Only slowed the few times required using the downshift paddle. For my street only driving CCB's stop great when warm/hot and good with ambient temp rotors/pads.
