Sponsored by: Wheel Design
Brake Fluid Change
Old Mar 9, 2026 | 12:14 PM
  #41
5632's Avatar
5632
After receiving my moisture meter I even checked brand new Dot 4 and it was near the same as my 5 year old C8. Why change it?
Old Mar 9, 2026 | 12:49 PM
  #42
RKCRLR's Avatar
RKCRLR
When my cars are at the scheduled interval for a brake fluid change I do a visual inspection for discoloration and check for moisture. I replace the fluid if it fails either check. I then check it periodically if I didn't replace it. But I change the fluid on schedule if I'm still under warranty. And I don't track my cars.
Old Mar 9, 2026 | 03:08 PM
  #43
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Originally Posted by Zymurgy
Closed system, yes. Totally impervious to moist air, no. Microscopic pores in seals and even the hoses allow moist air to slowly enter over time.
Also, isn't the reservoir cap vented? That means the ambient humidity is also in the air space above the fluid and can be absorbed.
Old Mar 9, 2026 | 03:17 PM
  #44
RKCRLR's Avatar
RKCRLR
Most modern brake systems (including the C8) have a diaphragm in the reservoir cap so there isn't direct contact between ambient moisture in the air and the fluid.
The C8 front lift initially had a diaphragm in the cap but it would get sucked in because it couldn't handle the displacement. GM revised the design to eliminate the diaphragm but I don't remember if they vented it or sealed it.
Old Mar 11, 2026 | 03:17 PM
  #45
C5racecar's Avatar
C5racecar
Originally Posted by gliot1
With the Ranger method you aren't bleeding the system, just exchanging fluid. I have done it many times on clutches. You suck out most of dirty fluid from resivour add fresh, pump the clutch a number of times, repeat, about 5 times until fluid is clean. I typically use a quart of brake fluid. On my C7 clutch I would do this every couple years if feeling the clutch hanging up a little. For what dealers charge for these simple procedures, it may be worth trying...
Agreed. I have seen the clutch fluid reservoir turn dark from contamination. Never see that on the brake master cyl.
Every cycle of the clutch pedal moves a lot more fluid that the brakes.
