Sponsored by: CARiD
Performance
Old Aug 15, 2019 | 02:57 PM
Race Prepared's Avatar
Race Prepared
Default Performance
With C8 stingray already a performance leader, what new owners will be modifying their car to increase horsepower and perhaps handling performance? What would your starting point B on increasing horsepower?
Popular Reply
Aug 19, 2019, 10:37 AM
Callaway Chris's Avatar
0Callaway Chris
Former Vendor
Originally Posted by Race Prepared
With C8 stingray already a performance leader, what new owners will be modifying their car to increase horsepower and perhaps handling performance? c
We plan on modifying ours.
Old Aug 15, 2019 | 03:16 PM
JadeRaven's Avatar
JadeRaven
I'm more of an OEM guy but I've been known to add a drop-in K&N filter or two.
Beyond that, I'm going to go light on the options for all those weight savings...
Old Aug 15, 2019 | 06:45 PM
john91498's Avatar
john91498
Add some stickers, that's at least 5 more hp per sticker...lol...
Old Aug 15, 2019 | 07:08 PM
Race Prepared
With the new car’s voltage system change and encrypted electronics, it seems conventional hp gain methods might not be available on the C8, at least for now. With GM streaming updates to the car, security must be extensive.
Old Aug 15, 2019 | 07:57 PM
Joefab's Avatar
Joefab
Supporting Vendor
High flow extra large catalytic converters should liberate another 20hp and sports car sound in a simple bolt-on
Old Aug 15, 2019 | 09:12 PM
atljar's Avatar
atljar
No longer 12 Volt?
Old Aug 15, 2019 | 09:19 PM
lostsoul's Avatar
lostsoul
Banned Scam/Spammer
Knowing how bad things are I'm sure once the car detects the cats missing it will send a message through the car wifi to your phone. Sending a complete log to GM, local DMV, County and State police, EPA and the DNC.
Old Aug 15, 2019 | 09:38 PM
bluedevil99's Avatar
bluedevil99
Old Aug 15, 2019 | 09:55 PM
Race Prepared
Originally Posted by atljar
No longer 12 Volt?
The C8 Corvette will have “Global B” 48 volt based electrical system.
Edit - the system is 12 volts not 48 volts as stated above, I was wrong.
Old Aug 15, 2019 | 10:19 PM
bluedevil99
The first half of that statement is true... it's still 12v.
Old Aug 16, 2019 | 09:21 AM
mustclime's Avatar
mustclime
The big mod for the c8 is going to be wheels and tires. The front tires are not wide enough for 3600 lbs car. Without reading the first review I can tell you GM designed in under steer with the 245 tires. IMO the big question is going to be how much rubber you can stuff under the stock fenders.
Old Aug 16, 2019 | 12:26 PM
fzust's Avatar
fzust
You're statement is true about designing in understeer, however, given the 40/60 weight split, they are not far off. Max the front camber and you can probably get it neutral. I agree though. I would want 295F and 335R on my GS. I would bet a $20 that the Z06 will have 275 or smaller front tires......
Old Aug 17, 2019 | 07:07 AM
94Lt1Vette's Avatar
94Lt1Vette
How is it "already a performance leader" if no one has driven it on a track yet?
Old Aug 17, 2019 | 10:34 AM
NORTY's Avatar
NORTY
Oh, it's been on tracks already. Lots of tracks. (And no, I'm not talking about MPG.)
Old Aug 17, 2019 | 10:36 AM
94Lt1Vette's Avatar
94Lt1Vette
Post the times then, because I haven't seen anything beyond GM's "Under 3 seconds" 0-60 claim yet.
Old Aug 18, 2019 | 11:34 AM
NORTY's Avatar
NORTY
None of the data will be released until GM says. They hold the strings to all media on this. They really do.
Old Aug 18, 2019 | 12:17 PM
Shaka's Avatar
Shaka
The only way you get less restriction is with less filtration. Can't beat OEM filters. Also, applying oil to the K&N filter, voids the warranty.
To Performance
Old Aug 18, 2019 | 06:35 PM
Joefab's Avatar
Joefab
Supporting Vendor
The only way to increase power is to reduce exhaust back pressure and pumping losses of the intake and exhaust. High quality 200 cell sports race catalytic converters should liberate another 20hp with no check engine lights and more gutsy sports car sound. A lightweight highflow x pipe with valves should add more power and save a lot of weight off the rear of the c8. After that an Ecu tune is a possibility.
Old Aug 18, 2019 | 09:07 PM
lostsoul's Avatar
lostsoul
Banned Scam/Spammer
I cant remember but I believe someone said they got another performance exhaust installed at a Chevy dealership. Is that something many will do and would it still be covered by warranty or at least not void the rest of the car for warranty work? Reason I ask is because they say the NPP only gives 1hp.. that blows in my book
Old Aug 19, 2019 | 10:37 AM
0Callaway Chris
Former Vendor
