Under 3 secs for Z51- how?
I got a $500 phone app that gets my BMW 335i into 11's.... I can only imagine the tuning potential for the C8 Z06...
https://www.porsche.com/canada/en/models/911/911-gts-models/
https://www.porsche.com/canada/en/mo...11-gts-models/
I can easily testify the truth and reality to your statement that I easily exceed MT's published results with my C5, my C6 and my C7 all on street tires and without any mods or tunes. Later after a couple of years a few mods , like a cold air intake , bettered their times by .3 to .6 seconds. Add drag radials and you pick up another .1 sec. Just stating the real facts.
I can easily testify the truth and reality to your statement that I easily exceed MT's published results with my C5, my C6 and my C7 all on street tires and without any mods or tunes. Later after a couple of years a few mods , like a cold air intake , bettered their times by .3 to .6 seconds. Add drag radials and you pick up another .1 sec. Just stating the real facts.Last edited by usrodeo4; Sep 20, 2019 at 02:37 PM.
Lots of cars both front and rear engine have gotten to 60 in less than 2.9 seconds. You illustrate that with the Pooch example. The turbo Porsche, micky McLaren, and even a decently modded C5 will eclipse that 2.0 to 60 number
As an extreme example, a rear wheel drive top fueler hits zero to ONE HUNDRED in .8 seconds. As the power goes up, traction is at a premium but 4 wd is not necessarily the solution. Weight distribution, transfer, and the sheer grip of the rear tires can negate the need and the drivetrain loss and weight is less.
C8 Vette does 0-60 boogie with lots of gear, low end torq, and traction. No real magic here. It is however a huge testimate to the efficiency of the drivetrain and ability to put the power down.
Vette punches at a weight class above it's own competing with cars costing 3-4 times as much and can be fixed for 3-4 times less. Pretty good deal. Ferrari and others gears their cars also for more top end which can hurt the 0-60.
Put the same gearing into cars with more power as long as you maintain the grip and they will shade the vette. The old ZR-1 would do it if it could put that massive torq to the pavement. That's a big driver behind the c8, increasing efficiency and a much better platform for more power to do something besides produce smoking rubber. Spinning ain't winning.
From prior generation vettes, that 0-60 times didn't plummet as HP went up, spinning ain't winning and the new vette will get with the program much quicker. I think something that will be interesting is to see how much power the dct absorbs. This c8 drivetrain should reduce parasitic drag and allow more of the engine HP to make it to the tires by eliminating torq tube drive shaft and parts along the way to get the front engine power to the tranny. My bet is that the parasitic drag penalty is less than 15%. Interested to find out!
usrodeo4 , I guess you don't read very well. I never said I had a ZO6 with a ZO7 package but I had a C5 which MT said at best would turn 13.2 in the quarter with a M6 trans. I turned 12.6-12.8 all day long. My C6 with the LS2 and A6 GM said would turn 12.6 and MT said 12.8. I turned 12.3- 12.4's all day long on street tires. Then MT and GM said my C7, A6 would turn 12.2's but some how my 2014 Base Stingray turns 11.8-11.9's on street tires. My point is don't assume anything that MT or GM says. Okay?
With near similar weight to a base C8 and a 30hp advantage along with fast DCT shifts, it will out accelerate a C7 and C7 GS throughout the 0-170 range. A Z06 and ZR1 have the HP advantage to catch and reel in a C8 after the initial 0-60.[/QUOTE
The 11.3 quarter mile time proves the car is not slow after it reaches 60 mph. What people do not fully understand is typically it takes a high horse rear drive car to do 0-60 in under 3.0 sec . Take the awd and rear engine, and mid engine exotics out of this thought process. Because of this , the high horse cars also trap speed and et much faster and quicker the 495 horse C8. In other words a 2.9 0-60 time does not usually only end up with a 11.3 1/4 mile et and a low trap speed of 120. Instead we stuff like 10.9 and 130 mph trap speeds. Put that same 495 horse into the C7 and you are lucky to see 11.7 et's with maybe a 3.5 0-60 mph on OE tires and stock otherwise.
The 60 ft time (or 0-60 mph on the street) is the most important number for the 1/4 mile. The C8 has a much lower over all first gear along with the more weight on the rear axle and will make a quick 60ft.
The power to weight will show when the car is moving and no longer has the gearing advantage. The C8 will beat the M7 C7 Z06 on the 60ft times and may hang on though the 1/4 from the huge gearing advantage and physical advantage from the traction.
But rolling races between the 2 on the hiway would show the C7 Z06 easily puling away from the C8.
I grew out of that foolishness at 18! Crazy when there are lots of drag strips all over the country. On Wednesday nights folks do race for money at the strip around here!
