Sponsored by: CARiD
Brake pads / roller bars (understeer)
Old Jan 14, 2020 | 01:44 PM
KNSBrakes's Avatar
KNSBrakes
Supporting Vendor
Originally Posted by vndkshn
His is a 2016. He's done all sorts of stuff to it, front mount, tune, EGR deletes, etc etc etc... I have a 4x8 shelf of Subi crap in my shop from him!
Had a 2015 - not tracked.
Needs big brakes in front for track.
Old Jan 14, 2020 | 02:11 PM
vndkshn's Avatar
vndkshn
Yeah, it's a heavy car.
On topic, just about any car needs upgraded pads that are designed for track work for track use.
Old Jan 14, 2020 | 10:43 PM
pfbz's Avatar
pfbz
Cruising
Based on Randy Pobst's comments, nothing more than an aggressive alignment with lots of neg camber put it right back into true sports car mode... Add a set of Performance Friction pads and go have a blast on open track days.
Of course there are always more upgrades... But it sure sounds like a Z51 package car with a $200 performance alignment and corner balance (it already has adjustable coilovers) is ready to go for light track days.
It also isn't mentioned much, but I believe the Z51 package also adds improved front brake cooling ducts.
Old Jan 15, 2020 | 02:09 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
It will be interesting to see how aftermarket pads effect the algorithm for the brake fade warning system. The C8 uses fluid and brake pad temps to determine if there is a possibility the brake system will experience fade. If the computer determines there will be fade, a warning comes up on the dash. If the driver continues to push the car hard and more heat is generated, a second warning will come up, along with a latched code. That latched code will limit the car to 55 MPH until the owner can take it to the dealer for inspection.
I am very curious to see how this new 'brake by wire' system plays out and how well it works (or doesn't).
Old Jan 15, 2020 | 02:11 PM
RapidC84B's Avatar
RapidC84B
This is a big part of why I'm going to try to do my HPDE weekends on OEM Z51 pads. I always go hardcore with my cars and I want to truly leave this one alone and just drive it if I can. I don't want to be swapping pad compounds back and forth and have separate trackday wheels/tires when I'm just instructing and trying to have a fun weekend away from work.
EDIT - To add... in the ask Tadge section, whenever ice mode, or use with track pads/tires comes up, his standard retort is that they only test/develop on the OEM pads/tires as they don't spend the time/money to test other items. Kind of like how the LS7 cars had oiling issues used on race tires even with the dry sump. It was a use-scenario that never came up in validation testing. To GM's credit they changed the tank design and added capacity.
Old Jan 15, 2020 | 06:05 PM
KNSBrakes's Avatar
KNSBrakes
Supporting Vendor
I can't imagine they are rating the OEM pads over 1000 degree's or even that high.
Old Jan 20, 2020 | 02:02 PM
RichieRichZ06
St. Jude Donor '08
I don't if they are either. They didn't tell us the algorithm or what temps it's using to determine brake fade.
Old Feb 9, 2020 | 12:46 PM
copjsd's Avatar
copjsd
Hello, RichieRichZ06. I'd appreciate learning more about the source or reliability of your statement that the C8 will look at fluid and pad temperatures to identify and warn of a brake fade potential. Thank you!
Old Feb 12, 2020 | 11:23 AM
Dane@LGmotorsports's Avatar
Dane@LGmotorsports
Premium Supporting Vendor
Rich is the service & parts director for a chevrolet dealership so it's pretty safe to say his statement is extremely reliable.
Old Feb 13, 2020 | 10:24 PM
Newton06's Avatar
Newton06
Originally Posted by savage
about the pads < i changed to hawk street race pads and the rotors on 2015 and 2016 z51's melted. rotors on C7 z51's were soft and could not handle much more than a stock pad . yes many guys changed pads to dustless but im talking about a autocross pad, stock rotors did handle hawk hps and 5.0's but they are just street pads, i hope the C8 z51 has a rotor harder than c7. if not the DBA'S are the best value in rotors, AP is the best but big money >
What?
I put almost 2 full seasons (16+ events) of HPDE instructing at VIR on my 2015 Z51 with OEM rotors running very aggressive Carbotech pads (XP12/XP10).
The C7 Z51 J-hook rotors were very good. DBA blanks cost significantly less but wear faster than the OEM rotors. Performance was about the same. I now run APR's which as you say are in a different league, from a price and performance POV.
Old Feb 13, 2020 | 10:58 PM
savage's Avatar
savage
Originally Posted by Newton06
What?
those were not my results, stock z51 rotors actually smoked and looked on fire 🔥 with hawk street race pads in 60 second autocross. Actually the first turn guys would stand there taking pictures. That’s all behind us now let’s see what the c8 is all about.
Old Feb 13, 2020 | 11:10 PM
RacerRik's Avatar
RacerRik
So what about the issue where GM says you cannot use anything but stock pads on the C8 because of some built in sensors? How long will it take the aftermarket brake guys to work around that problem?
Old Feb 13, 2020 | 11:12 PM
  #33
RapidC84B's Avatar
RapidC84B
My 2014 Z51 has the early 2-part cast rotors, ran 1.5 track seasons on them (8 weekends) with Carbotechs before having to replace. They were great rotors.
Old Feb 15, 2020 | 03:15 PM
  #34
MitchAlsup's Avatar
MitchAlsup
47 minutes after first car delivery.
Old Feb 21, 2020 | 10:59 AM
  #35
The HACK's Avatar
The HACK
Wait WHAT?! Really?
Old Feb 21, 2020 | 11:30 AM
  #36
RapidC84B's Avatar
RapidC84B
Originally Posted by The HACK
Wait WHAT?! Really?
Technically not true, but we don't know how the system will react to different high temp compounds. There are two levels of warning:
1. Brake fade feedback - Tells you you're in brake fade
2. You're fucked - Limits the car's max speed in the 50s until you see a dealer.
It's been said you really have to abuse the car after warning 1 to trigger warning 2. No clue if the car will think a high temp pad is in fade when it's not. Lots to learn. I intend to keep this car as OEM as I can and do my 4-5 weekends a year. I'm not buying this car to compete.
