Sponsored by: CARiD
Cost to track a C8
Old Jul 15, 2020 | 07:50 PM
BlownDeadline's Avatar
BlownDeadline
Default Cost to track a C8
I am looking for some ballpark vehicle setup and replacement part costs associated with participating in club type track days.
Old Jul 15, 2020 | 08:15 PM
sainthoo's Avatar
sainthoo
The GM track alignment and adding 2 qts to transmission is a bigger job than you think. Took several hours, cost me about $1K at dealer, including oil change.
Factory brake pads toast after 1 day. I will switch to G-loc. I also switched to Goodyear Eagle F1 Supercar tires, because I didn’t like the PS4s.
Should just be brakes and tires from here on out.
Old Jul 15, 2020 | 08:35 PM
TARANTULA's Avatar
TARANTULA
^^^ What he said and you should also change the oil more frequently assuming you track regularly.
Old Jul 16, 2020 | 12:15 PM
MitchAlsup's Avatar
MitchAlsup
Might want to schedule an oil change before/after a track event.
Old Jul 16, 2020 | 01:14 PM
Bill Dearborn's Avatar
Bill Dearborn
Oil change shouldn't need to be that often. The OLM will decrease oil life faster when you are driving on track due to higher oil temperatures and other extreme operating conditions. Have tracked C5s, C6 and C7 with up to 20 track days per using OLM as guide and have never had problems over the last 23 seasons.
Bill
Old Jul 16, 2020 | 04:35 PM
PRE-Z06's Avatar
PRE-Z06
Oil breaks down with heat, so I’d say depending on how hot the oil is getting should be taken into consideration and not just that someone is driving their car on a closed course.
Old Jul 17, 2020 | 09:31 AM
punky's Avatar
punky
Banned Scam/Spammer
Damn, tracking is pricier than I thought. I'd probably start renting airplanes again do some flying instead.
Old Jul 17, 2020 | 12:41 PM
KNSBrakes's Avatar
KNSBrakes
Supporting Vendor
This is written assuming you have not been on track before.
If you are just starting and your car of choice is a C8 and $$ matters don't do it. Go rent a track car first.
It's expensive and hard on the car to track it. You can do a weekend at VIR in a Spec E30 or Cayman for likely far less and you will ABSOLUTELY learn more and have more fun. You might also consider going to an event to spectate first and see how the event runs. There is a lot going on.
C8 + green group + novice driver. Your instructor will be smiling nervously
Good luck either way. Don't let the $$ stop you from trying the hobby.
-Ken
Old Jul 17, 2020 | 06:25 PM
thrilled's Avatar
thrilled
I had heard to do it right and not play it can run in the thousands. Even the 1/4 mile can add up.
Old Jul 17, 2020 | 07:12 PM
1ED1's Avatar
1ED1
Entry, insurance tires, brake pads gas and hotel. It will be close to 1500 to 2000 a day
Old Jul 17, 2020 | 08:02 PM
Egoncool's Avatar
Egoncool
over the last 2 years I’ve averaged a $1000 a day. Its more difficult and more expensive than I ever imagined, but it’s also fun and generally a great community.
Old Jul 18, 2020 | 10:24 AM
vanlieremead's Avatar
vanlieremead
Doesn't’ the transmission fluid also have to be changed more often? I remember watching a video stating every 24 hours of actual track time.
Old Aug 25, 2023 | 06:08 PM
tm9341's Avatar
tm9341
2nd Gear
I have a Z51 c8. I would like to do some track days, maybe 3 weekends a year. Is it totally necessary to change to DOT4 brake fluid? I'm not going out to set any records, just to have fun. ( yes I have some racing experience).
Old Aug 25, 2023 | 08:34 PM
bhvrdr's Avatar
bhvrdr
It would probably be the first thing I'd do along with the DCT track fill.
I look at it this way. You pay $400 for the track day, $400 for insurance, you may consume $900 worth of tires (half the tire life), and you clear 10 hours from your calendar for commuting to and participating in the track day and sometimes $60 in fluid and 1 hour in time can separate you from having a great full day versus having to have the car towed home.
Old Aug 25, 2023 | 09:13 PM
fatsport's Avatar
fatsport
Yes, probably the most important thing to do. Many of us use Castrol SRF. It has a high wet boiling point so it can stay in for up to a year.
Here's what happens when you don't change to high temp brake fluid... (jump to 3:10 for the wreck)
Old Aug 27, 2023 | 12:31 AM
Ksteckba's Avatar
Ksteckba
This thing eats brakes if you are ripping. They really underbraked it.
Old Aug 27, 2023 | 01:36 AM
X25's Avatar
X25
Sr.Random input generator
Looks like Raybestos has started shipping ST47 pads. They usually last a lot longer than any other option. Don't know about OEM C8 Z51 sizes, though.
To Cost to track a C8
Old Aug 27, 2023 | 03:19 PM
Ksteckba's Avatar
Ksteckba
I’ve only tried st43 when racing my friends mustang. Did not like those at all. Had that tap the brakes crazy bite people seem to love. What is the st47 like? Also, is it super loud on the street?
Old Aug 27, 2023 | 03:33 PM
X25's Avatar
X25
ST47 has more (wear) tolerance at higher temps, but even more bite, so perhaps it's not something you'd like : ) Why do you hate high bite pads? I know you'd overbrake initially, but you'd also end up adjusting to the pedal feel anyway?
That loudness is a hit and miss, and I think it might have to do with the piston/pad sizes and how much force is on the pad during traffic stops. It's like playing a flute: it doesn't happen if you over or under-blow the tube : P I've had ST43s screaming on my C6 GS, yet they were quiet on my Miata, and C7 Z06 brakes.
Old Aug 27, 2023 | 08:19 PM
Ksteckba's Avatar
Ksteckba
I’d prefer to press the pedal harder to get more brake force. I feel that I have better perceived resolution with a larger force range at the pedal, and corner entry is dependent on brake modulation, so I’ll take all of the resolution I can get.
