Sponsored by: CARiD
Track wheel recommendations
Old Sep 2, 2020 | 10:48 AM
Toilets's Avatar
Toilets
Originally Posted by Poor-sha
Cool - I'm interested to hear how the car handled with the Hoosiers. My car is loose on turn-in on stock tires with the track alignment and it wasn't confidence inspiring.
The big difference really is in GSPEEDs write up and testing they did. It sounds weird but you really got to drop the rear 10-12 turns (basically all the way down) and that solves the majority of the loose handling. Basically a negative rake. You drop the front however just not as much. Basically, for every one turn in front you turn 2 in the rear. We also went a little more aggressive than the track alignment for camber (-3.6 front -3.0 rear) . So far that set up seems to work well and feels more comfortable.
Old Sep 7, 2020 | 12:25 AM
mrrrkva's Avatar
mrrrkva
Is there any rubbing on those sizes? Quite a bit wider than stock.
