Sponsored by: CARiD
Autocross Alignment Settings
Old Sep 16, 2020 | 01:38 PM
NTMD8R's Avatar
NTMD8R
Default Autocross Alignment Settings
OK, I've read the manual re Track settings, and I plan to be close to that for autocross, but .......
Every alignment instruction I've ever read/seen says to do Toe OUT for the front.
But this C8 says to do minimal Toe IN. Wha ???????
And, while I'm here, I also see someone is saying to do Rear Caster at 1.6, whereas manual says 0.0.
Speed Phenoms' .... https://www.corvetteforum.com/forums...xperience.html
I was planning on doing -2.5 to -2.8 front camber, and 1/16" Toe OUT (total), and as much caster as I can get.
For rear I was planning on -1.8 to -2.2 rear camber, and zero Toe, and 0.0 caster.
So... Help me please with some good recommendations
Old Sep 16, 2020 | 09:18 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
According to all the testing I have seen most autocross tracks won't allow enough speed to make much if any difference between the street or track alignments!
Old Sep 17, 2020 | 12:11 AM
mjcourt's Avatar
mjcourt
If you autocross much, the alignment will have a big affect on tire wear. With street alignment, you would wear out the outer edge of the tire fairly quickly, so alignment does matter there.
Old Sep 17, 2020 | 07:25 AM
BPHORSEGUY's Avatar
BPHORSEGUY
Ok that makes sense I'm just saying time wise it will only make a diff on the fastest or more open courses.
Old Sep 17, 2020 | 12:08 PM
NTMD8R's Avatar
NTMD8R
We (before Covid) autocrossed 20-25 times a year (2 drivers, averaging 8-12 laps each per event).
And we drive 25 km to and from the event each time for the last 6-8 years.
And we do hit 125 km in some parts of the courses.
We've been autocrossing Corvettes for 40 years, all over western Canada and the northwest US.
I just think those GM front Toe settings are wrong,
but I defer to those who have autocrossed their C8, to give some advice.
Old Sep 17, 2020 | 02:25 PM
acrace's Avatar
acrace
I would strongly disagree. On a super tight course, optimizing caster so you increase camber at high steer angles pays big dividends in maintaining a flat front tire footprint. Tight courses that have “point and squirt” straights - adjusting rear toe pays big dividends in being able to get on the throttle earlier and a more aggressive ramp rate.
Whenever I set up a test n tune course I strive to have a brisk speed maintenance section and a portion that has tight radius 180s with short straights so I can take time splits and work on both.
Old Sep 17, 2020 | 02:33 PM
acrace's Avatar
acrace
To OP, my C8 had an initial set up with GM track spec camber, very small amount of positive rear caster, GM track spec front caster, and zero toe front and rear. Also lowered about 2/3rds.
Then I used a test session to get the toe settings that seem to work best. I like my front settings (very slight front toe out) but still working on getting the rear to behave as I want. I’ve had both BFG Rival S and Bridgestone RE-71Rs on the car. Bridgestones are mine; borrowed the Rival S. Think that rear toe settings would differ between the two tires because of how different they behave in corner exit/power on situations. I also want to explore effects of rake but rear alignment settings are a pain with the C8, so not an easy test n tune parameter.
Also, don’t forget that the GM track spec is aimed at tracks and not autox. While I haven’t had the C8 out for a lapping day yet, I usually had a smidge of toe in on my C5Z and C6Z for timed lapping days. Both cars usually had zero to 5 mm toe out for autox.
To Autocross Alignment Settings
