I previously had an AWE track exhaust n kooks cats installed with no CEL. Recently I added the kooks headers and got a CEL after about 200 miles. Car seems to drive fine so I’m wondering what it could be. Going to bring it in to dealer next week but just wondering if anyone had any issues similar to this. Dealer was cool and said as long as issue is not due to the aftermarket parts they’d cover under warranty.
Will be interested to hear the end result. The addition of the headers alone should not create a fault, as no emissions control devices are removed. It's likely too early for the Kooks cats to fail and throw P0420 / P0430. Hopefully it's just a loose connection with a sensor or something small. Keep us posted!
Pulling a code is not too difficult. I have the Kiwi that plugs into the OBD-II port and connects via Bluetooth to my I-Phone. I downloaded a free app to my I-phone and gets all kinds of information include DTC codes.
My guess (and its a guess...) its the rear O2 sensors reporting cat inefficiency. Not anything bad, but nobody wants the check engine light glowing in your face. Also, the car will fail the annual inspection.
full exhaust swap on mine... i've had P0420 i think 3 times in as many months. each time i erase the code it is the drivers side 02 sensor after the cat. i have swapped the sensor to the passenger side this week and see if it pops on again. so many things i think it could be. I'm 7 minutes from work probably not driving it hard enough and cats getting a bit backed up. who knows. It wont let you remote start the car if the cel light is on either.
Keep us posted thx
Keep us posted thx
Interested to learn what Sport Cats you're running?
My setup is Kooks Headers & high flow cats along with the AWE track exhaust... the shop checked it out and its pulling the emissions code on bank 1... We are going to add the O2 spacers on both sides
Seems a bit outrageous to be forced to purchase another product to work around the Kooks cat failure?
You couldn't have had them installed for too long or too many miles. What is their warranty?
Catalysts are a consumable part - only a finite amount of catalyst material can be contained in the core - which can only "scrub" a finite amount of exhaust. They should last for tens of thousands of trouble-free miles. Our Sport Cats come with a No Check Engine Light Guarantee, and a 5 year warranty to the original purchaser - including a one-time re-coring of the cat itself.
Glad I Have Your Cats Coming...Hopefully Get Here Soon...National Auto Brokers
UPDATE... Knock on wood, after installing o2 sensor extensions/ non mini cat style, and a long drive today both cruising and harder driving no p0420 cel. hope this helps.
Afe headers kook cats and awe track exhaust. yep my neighbors love me at 6 30 am.
so far the 02 spacers on mine have done the trick. non mini cat just spacers installed after the cats.
Still confused as to why O2 Spacers would be required on what are essentially brand new high flow cats?
The whole idea of high flow cats is to make power while remaining "green" and emissions compliant. If the high flow cats work properly, no tune or O2 Spacers are required to kill a Check Engine Light. If the high flow cats are not 'scrubbing" the exhaust well enough to avoid a CEL, why not just save the money and go cat bypass instead if you're encountering all the downsides of cat bypass anyway?
Because the Cats are working to spec for emisions. The O2 extension are a band aid and just trick the computer into thinking the cats are working.
I fully understand how O2 Spacers work - as they are one of the more popular items in our catalog due to their nearly universal application: O2 Spacer Pair
My point is thatO2 spacers should not be necessary if you're using a quality high flow catalyst or sport cat. The high flow cats themselves should keep the CEL out if engineered properly.
