Sponsored by: CARiD
Track Tires
Old Apr 12, 2021 | 09:37 AM
dfettero's Avatar
dfettero
Default Track Tires
What are folks running for track tires? Will be running RBF600 and G-LOC 12 pads.
Old Apr 12, 2021 | 11:57 AM
bad mooofooo's Avatar
bad mooofooo
Modified C8 of the Year 2021 Finalist
I know you're looking to crank it up a notch but I couldn't believe how well the Michelin 4s did at Spring Mountain on the North track which is a pretty technical track.
Old Apr 13, 2021 | 12:50 PM
Poor-sha's Avatar
Poor-sha
Track Rat
Goodyear 3R in stock sizes.
Old Apr 13, 2021 | 08:54 PM
dfettero's Avatar
dfettero
Default Hpde 2 ?
I wish I was as good a driver as you. HPDE 2 .
Do you have C8 PDR track maps?
Old Apr 14, 2021 | 07:58 AM
c5racr1's Avatar
c5racr1
Goodyear 3 or 3r way better than the michelin 4s
Old Apr 14, 2021 | 12:12 PM
william wyatt's Avatar
william wyatt
Only come in 19 inch????????
Old Apr 14, 2021 | 01:04 PM
c5racr1's Avatar
c5racr1
Goodyear 3
Old Apr 14, 2021 | 01:08 PM
c5racr1's Avatar
c5racr1
Stock size....
Old Apr 14, 2021 | 02:34 PM
J5isalive's Avatar
J5isalive
NT01's, A052's, Supercar 3, Supercar 3R.
Old Apr 15, 2021 | 09:01 PM
Poor-sha's Avatar
Poor-sha
Track Rat
Sorry I've been super lazy about updating the site. I just updated www.hipodriver.com/resources with what I have. I also updated the Pi Toolbox workbooks on the site.
Note however that a few things don't work right with those workbooks and the C8 either. GM decided to drop the yaw, outside air temp, and suspension channels from the C8. They also reversed the steering angle channel and renamed all the wheelspeed channels.
Old Apr 19, 2021 | 01:31 PM
Z06Norway's Avatar
Z06Norway
check out this test ?
Old Apr 26, 2021 | 12:22 PM
SPACE RACE's Avatar
SPACE RACE
I need help with tire sizing for track days please. I am buying 20/21 aftermarket wheels for cruising, and would like to use my 19/20 stock wheels for racing. I plan on quarter-mile racing most of the time so I would like to set up for that primarily. However I might do a track day now and then so I need to consider that also. I don’t plan to race serious enough that I would buy special wheels for the drag strip. So can I do 245/35 in the front and the 325/25 in the rear? Is that the best setup for this use?
Thanks for the help!
Old Apr 26, 2021 | 09:20 PM
Griffin9611's Avatar
Griffin9611
Just ordered F 18x10 R 18x12 Forgeline's with Hoosier A7 should be here in a few weeks
The 4's were great but not enough grip! I was going to try using my stock wheels but heard they bend super easy.
Old Apr 26, 2021 | 09:31 PM
Griffin9611
Tires are
275/35R18
345/35R18
Old Jul 20, 2021 | 01:41 AM
GeauxTigers1's Avatar
GeauxTigers1
freaking awesome man! How’d these fit and did the clear our stock brakes? Seems like there’s not a lot of info out there on smaller wheels/thicker tires. :\
Old Jul 20, 2021 | 09:08 AM
J5isalive's Avatar
J5isalive
I have 18in forgelines and it seems there isnt a ton of information out there on what you need to do to make them fit. So I will help everyone out here... I have AP Racing Brakes FYI
The front, the front pretty much clears without issue, you will want to keep an eye on the lower spindle, you *may* need to grind a little on the bottom to clearance out the threads below the spindle.
The rear... this is where things get fun lol... Brake ducting... the piece that goes inside the wheel, kiss it good bye. The piece attached to the lower A-Arm depending on your offsets you may need to clearance that a 1/4 of an inch. Heat shielding around the spindle, just go ahead and cut all the corners off of it. Suspension at full droop with no tension on the sway bar (car on a lift) the wheels will contact the top of the A-Arm, when there is tension on the sway (one side of the car is on the ground) the wheel probably wont touch the A-Arm, depending on the manufacturer of the wheel and its offsets, Now you get to play the game of "How much clearance is enough?"... break out the grinder and get to work, have an understanding of how much suspension travel you have during a track day and grind appropriately, there are already 'pockets' on top of the A-Arms for the stock wheels, you will need to expand those pockets a little more, use some grease or some paint, install the wheel, see where it rubs and grind there a little.
Honestly if I had known the headache it was to get the rears to work perfectly I probably would have ran a 19in in the rear instead of an 18in. Now that I have it sorted I am happy though.
As for tires, i just installed some Nankang AR-1's. 295/30/18 fronts and 335/30/18 rears.
Old Oct 22, 2021 | 03:18 PM
milkrun's Avatar
milkrun
Hey @J5isalive - would you please post or message me the sizes, offsets, etc of the wheels? - thanks
To Track Tires
Old Oct 22, 2021 | 03:38 PM
J5isalive's Avatar
J5isalive
18x10 et45 & 18x12 et57. However i run a 3MM spacer up front, and a 15MM spacer in the rear.
If your car is dual purpose i would get a 18x10F 19x11.5/12 rear.
Edited: thought this was a different thread, i mention the struggles of 18s above. However call Cicio and get a set of MCS 3-Ways, ask about getting the rear shocks droop limited to maintain distance of the wheel barrel and the upper A-Arm. Been working very closely with MCS to get these things dialed for the larger market, multiple spring rates to address all types of car setups!
Old Jul 12, 2022 | 11:14 PM
JRRZR1's Avatar
JRRZR1
How many track days do you get out of the GY 3R?
Old Jul 14, 2022 | 11:21 AM
Ksteckba's Avatar
Ksteckba
if driven on the limit, two track days at most.
