Sponsored by: CARiD
C8 lowering process
Old May 11, 2021 | 01:40 PM
rondorfman's Avatar
rondorfman
8th Gear
Default C8 lowering process
I want to lower my c8 convertible a 1-2 inches. Anyone done yet?
Old May 11, 2021 | 04:43 PM
progtp's Avatar
progtp
Lots of people including myself have done it.
The way to lower it depends on the options you have on your C8 ( Z51, Non Z51, Front lift, etc).
If you do a search using the search function in the top right of your screen you should find plenty of info.
Old May 11, 2021 | 10:55 PM
Billy20's Avatar
Billy20
This is down about an inch on eibach springs and the adjustable perches at stock height
Old May 11, 2021 | 11:15 PM
rajeevx7's Avatar
rajeevx7
Originally Posted by Billy20
on eibach springs
They aren’t available to the public yet... according to eibach.com and their YouTube/FB pages🤔
Old May 12, 2021 | 08:01 AM
rondorfman's Avatar
rondorfman
8th Gear
Looking for Z51 lowering info. No front lift. Thanks!
Old May 12, 2021 | 08:32 AM
progtp's Avatar
progtp
That is the set up I have. Its a pretty simple process. All you need to do is adjust the collars on the factory Z51 springs. This will give you about an inch lowering if you go all the way to max.
I had this done by a friend so I didn't do it myself but there are places like Paragon Performance that sell the proper wrenches to turn the collars and people have done it themselves.
They also recommend an alignment afterwards but after checking my car on out dealerships Hunter Alignment Machine everything was still within factory tolerances so we did not need to do an alignment,
Old May 12, 2021 | 09:49 AM
ATVracer's Avatar
ATVracer
I need some springs !
1LT no mag or Z51
Old May 12, 2021 | 12:04 PM
\Boost Monkey/'s Avatar
\Boost Monkey/
There are companies developing replacement springs for OEM coilover setup?
Old May 12, 2021 | 02:47 PM
Billy20's Avatar
Billy20
I know its really strange I have the full spring and sway bar set up ( was a test fit for HTC back in Feb)
Eibach will soon.... let me email my contact.
Old May 12, 2021 | 03:12 PM
ATVracer's Avatar
ATVracer
I'm ready to order a set also.
Mine is a HTC if that makes a difference
Old May 12, 2021 | 11:42 PM
Billy20's Avatar
Billy20
So I was told that it won’t be till close to the end of the year for all setups.
Old May 13, 2021 | 08:20 AM
rajeevx7's Avatar
rajeevx7
Thanks for that insider tip! I’ve been an Eibach convert for 20+ yrs, so I guess I’ll have to wait for these c8 versions.
The Paragon springs are tempting, but the amount of experience, lbs/in testing and qa that go into Eibach spring design is hard to substitute for.
Old May 14, 2021 | 06:08 PM
Hib Halverson's Avatar
Hib Halverson
Pro Mechanic
Pro Mechanic
Read this article.
The total trim height range is 1.5-in, however, most of the cars are coming out of the plant with 3/4-in to 1-in of travel left on the collars below the lock rings.
Lingenfelter's Spanner Wrench Set for C8 Z51 w/o E60 is a better choice than the Paragon wrenches.
Whether or not you need an alignment depends on how much you lower the car. You can go 3/4-in in front and ½-in at the rear without any alignment work. Beyond that, have the alignment checked after the you do the work.
Old May 15, 2021 | 11:46 AM
rondorfman's Avatar
rondorfman
8th Gear
Perfect thanks.
Old May 15, 2021 | 12:53 PM
\Boost Monkey/
Originally Posted by Hib Halverson
Read this article.
ROFL $150 for a coilover wrench?
No thanks.
Old May 20, 2021 | 12:12 PM
Hib Halverson
Pro Mechanic
Pro Mechanic
No thanks.
Well, "Boost Monkey"....it's actually a set of two wrenches and if you've actually done a C8 Z51 trim height adjustment, you'd know 1) you need two wrenches not just a "coilover wrench" and 2) you'd see the advantages of Lingenfelter's tools...especially if it's a case where the user goes to the track, lowers the car, then raises it back up after track day and needs to do that on a regular basis.
Bottom line: professionals and advanced DIYs who work on cars regularly use good tools.
If you find some coilover wrenches at Harbor Freight let us know.
Old May 20, 2021 | 02:11 PM
JVi's Avatar
JVi
The Paragon wrench set relies on the user to hold the coil over tube with the help of duct tape with the help of a channel lock if necessary even though the did not use a channel lock in this video:
The Lingenfelter's, at more than triple the cost, has the advantage of having the smaller wrench with a nub to hold the coil over tube:
I'll be taking my chances with duct tape and / or a channel lock ala Red Green. A little bit of PB Blaster lube on the rubber pad between the upper perch and the pad should help as well.
To C8 lowering process
Old May 20, 2021 | 07:15 PM
rajeevx7's Avatar
rajeevx7
*Raj over here having adjusted many, many cars, many, many times over with the same pair of 10yo BC/Megan bullshit $2 Chinese coilover wrenches*
Old May 25, 2021 | 11:59 PM
\Boost Monkey/
paragon’s comes with 2 wrenches. I bought Paragon’s set.
I’ve adjusted a plenty of coilovers and it’s not rocket science man... Just means you’re spending a lot more money on things you don’t “need” to make the job very marginally easier. If wrenches costing triple the price just to make the job very marginally easier is your bag, then knock yourself out.
Old May 30, 2021 | 06:08 PM
DNAST1's Avatar
DNAST1
2025 C8 of the Year Finalist - Modified
2023 C5 of the Year Winner - Modified
2023 Corvette of the Year Finalist (C8) - Modified
2023 Corvette of the Year Finalist (C6) - Modified
2022 C8 of the Year Winner - Modified
2022 C6 of the Year Winner - Modified
Paragon is selling lowering springs for all C8 suspensions
