Sponsored by: CARiD
How to Remove Seats?
Old Jun 28, 2023 | 08:19 AM
MM9284's Avatar
MM9284
Great info here on the seat removal. Does anyone know if the GT2 and Competition seats are able to be swapped out easily or the harness different. For reference, both the GT2 and Comp seats have heating and cooling with lumbar controls. I am considering a swap with another forum member but want to be sure its an easy "plug and play" swap before we ship seats across the country to each other.
Old Jun 28, 2023 | 01:48 PM
SpectreOne's Avatar
SpectreOne
Veteran: Marine Corps
@Rayc60 Thanks for sharing your process!
Old Jun 28, 2023 | 11:26 PM
allblackeverything's Avatar
allblackeverything
I’d bet the connector is the same.
I have my comp seats in the basement. Would you like me to take a picture of the plug so that you can compare?
Old Jun 29, 2023 | 11:27 AM
68/70Vette's Avatar
68/70Vette
If the C8 is like previous generations you can pull the airbag fuse, wait one minute for the charge to dissipate and not have to worry about disconnecting the battery. One of the problems when disconnecting the battery is you remove power from the power seat track and you may find you need to move the seat back and forth to get all of the nuts removed or to get the wiring harness disconnected from the seat.
Bill
Old Jul 11, 2025 | 09:49 AM
indycar5's Avatar
indycar5
Navigator
Thanks for this post. I followed it last week when I replaced the bottom drivers seat cover on my 2020. I was able to maneuver the seat around and remove the cover and replace it without disconnecting the seat belt. Took a few hours to complete it but worth it replacing my worn Sky Gray bottom. Couldn't have done it without this post and the instructions on how to disconnect the under seat connector.
Old Jul 24, 2025 | 08:45 AM
undecided1965's Avatar
undecided1965
For all you guys doing this, has anyone removed the piano black looking plastic piece off the back of the seat? Mine creaks a bit and I would like to stuff some foam in there to quiet it down. I tried unscrewing the screws that go through it but it won't budge so I am assuming there are other attachment points but I did not want to manhandle it as it feels kinda flexy.
Old Oct 22, 2025 | 11:20 PM
mistborn94's Avatar
mistborn94
2nd Gear
Have any of y'all removed the passenger seat completely? I was doing so to add space for my dog instead of a seat cover, but it seems like you can't use the driver side if the passenger seat is missing. Or maybe I messed something up?
