Issue with Front Trunk Latch Recall Fix
The recall "fix" was nothing more then reprogramming of how the frunk release buttons work. That should not be causing your issue.
The car thinks the frunk is open which means the sensor to latch interface probably needs adjustment. Maybe the connector is not fully seated.
What messages is the car showing?
It’s finally fixed and I finally have my car back. After about two weeks and me calling GM to add some pressure the dealership finally realized that the door kit had nothing to do with it. They really couldn’t say what caused the issue to be honest but what they ended up doing was replacing the latch all together which included the module to my understanding. They did say that this issue would not have happened if they had disconnected the module before running the update being that I had the door kit, not sure how that makes sense but whatever. I know the frunk had issues during the assembly of the 2020 which they halted assembly for a lil but due to it, I’m guessing mine didn’t get corrected.
Im good to go for now, hopefully no more issues and thanks for the replies.
It’s finally fixed and I finally have my car back. After about two weeks and me calling GM to add some pressure the dealership finally realized that the door kit had nothing to do with it. They really couldn’t say what caused the issue to be honest but what they ended up doing was replacing the latch all together which included the module to my understanding. They did say that this issue would not have happened if they had disconnected the module before running the update being that I had the door kit, not sure how that makes sense but whatever. .
