Sponsored by: CARiD
Lowering my C8
Old Aug 12, 2021 | 12:33 AM
Marc DeSatnik's Avatar
Marc DeSatnik
Default Lowering my C8
Looking for advice on how i can lower my 2020 non Z51 without Mag Ride
Old Aug 12, 2021 | 06:17 AM
Tim0shel's Avatar
Tim0shel
Following!
From my research it depends on what you want out of it. YI would suggest depending on budget go with drop springs and or full aftermarket coil over setup.
Old Aug 12, 2021 | 10:03 AM
Marc DeSatnik
Why not just pull the shocks/springs and replace with z51 shocks/springs?
Old Aug 12, 2021 | 10:14 AM
C8forT's Avatar
C8forT
Lead time on C8 OEM parts seems to be pretty long based on various posts I have seen, though I'm not sure if the struts have been affected by supply issues. If so, maybe you can look for some used ones from someone who swapped them out for aftermarket struts.
Old Aug 12, 2021 | 10:17 AM
\Boost Monkey/'s Avatar
\Boost Monkey/
This is the best, most complete option there is. If you are unfamiliar with KW, let me fill you in: They make very good quality suspension components... Based out of Germany.
KW Coilover Kit V3 Chevrolet Corvette C8 w/o Magnetic Ride, w/o OE Noselift System 2020+ | 35261030 (vividracing.com)
Old Aug 12, 2021 | 05:33 PM
Marc DeSatnik
the kw is nice but I don't want to invest 3 grand into a car I'm only keeping until i can get a Z06. I'm looking for a set of used z51 shocks
Old Aug 31, 2021 | 02:54 PM
RussM05's Avatar
RussM05
The manual has a section on lowering. It may not answer all your questions, but its a start.
Old Sep 1, 2021 | 07:50 PM
smoove7410's Avatar
smoove7410
Eibach has springs, but I'm not sure if they have released them. I'd suggest reaching out about availability.
To Lowering my C8
