Sponsored by: CARiD
Built-in Catch Can C8 Maintenance
Old Aug 12, 2021 | 05:16 PM
C8Hawaii's Avatar
C8Hawaii
3rd Gear
Default Built-in Catch Can C8 Maintenance
Hi All,
Is there any information on the maintenance required for the built-in catch can for the Direct injected LT2 and LT6?
I saw on a post that GM added a catch can so you don't have to install one.
Thanks.
Old Aug 12, 2021 | 05:36 PM
Racer X's Avatar
Racer X
Originally Posted by C8Hawaii
Hi All,
Thanks.
Where did you see that post? As far as I know the LT6 does not publicly exist and such specs are not known.
Can you give us a cite where you are seeing these this?
Old Aug 13, 2021 | 04:49 AM
C8Hawaii's Avatar
C8Hawaii
3rd Gear
Hi I had a post on the LT6 direct injection engine and someone responded that GM had already designed in a catch can so you don't have to add one. The LT6 is used in the C8R. If you google there is a spec that says it is direct injected.
Old Aug 13, 2021 | 10:55 AM
Kracka's Avatar
Kracka
What you're referring to is the air/oil separation system integrated into the LT2's dry sump oil tank and requires no maintenance.
To Built-in Catch Can C8 Maintenance
