Sponsored by: CARiD
C8 Overheated
Old Aug 24, 2021 | 05:41 PM
Black_Pearlzzz's Avatar
Black_Pearlzzz
Default C8 Overheated
2020 C8 with 2800 miles overheated to 240 with no lights or sensors indicating coolant loss. Dealer found leaking head gasket as of now but working to find other potential damage to the engine. Is it possible that the performance of the car is permanently affected? How likely is there damage to engine that may manifest itself in the future? What kinds of test and analysis should be done and should I be worried?
Old Aug 24, 2021 | 07:39 PM
MarioC8's Avatar
MarioC8
If it just overheated I’m thinking it’ll be fine, but I don’t know these cars as well as others.
You could do a compression test.
But opening the engine up would probably be best, and that’s what I imagine the service dept will do.
Old Aug 24, 2021 | 09:04 PM
NoMatter's Avatar
NoMatter
What’s Next
Getting to 240 isn't harmful but it shows an issue under normal driving. So I wouldn't call it overheated at that point. But it's still a good idea to inspect for other signs while changing out head gasket. I assume you were just driving casual when it came about. Did you ever smell anything leading up to this?
Old Aug 24, 2021 | 09:08 PM
ChiTownVetteTech's Avatar
ChiTownVetteTech
If it truly was only 240f degrees, I wouldn’t worry about it too much. That’s barely overheated and if you shut it down before it got much higher it’ll be fine.
Old Aug 24, 2021 | 11:03 PM
Black_Pearlzzz
Yes I was driving casually in the city. No smell but the radiator fans were going crazy.
Old Aug 25, 2021 | 06:27 AM
ChiTownVetteTech
I’d have to check, but high speed fans start somewhere around 232-236f.
Old Aug 25, 2021 | 08:01 AM
c5racr1's Avatar
c5racr1
240 is hot for city driving, you got a problem.
Old Aug 25, 2021 | 04:44 PM
GTUnit's Avatar
GTUnit
Bad overheating can warp heads on some cars. Not sure about the LT2. The shop will check the deck and head mating surfaces for flatness when they put head gaskets on it.
Worst case head surface would need to be resurfaced. Either way the rest of the motor will be fine.
Old Aug 29, 2021 | 09:34 PM
PRE-Z06's Avatar
PRE-Z06
It shouldn’t get that hot on the street, but 240* shouldn’t be an issue as I hit that regularly on track in my C6 before shutting it down. What’s the over temp warning at on a C8?
Old Aug 31, 2021 | 12:51 PM
Andybump's Avatar
Andybump
The leaking head gasket would be of considerable concern to me. How was it found? Water leaking out? Or .... I have a test kit that tests for combustion products leaking into the cooling system that I use on my older cars. This is usually due to a head gasket problem, but can be due to other internal issues, like a crack in something. This type of leakage can cause overheating as the hot gasses escape into the cooling system. Regardless, did the overheating cause the leak, or was there a leak that caused the overheating. I any case, you will have to rely on the service department to tell you the extent of the damage. And yes, a compression check should be one of the tests.
Old Aug 31, 2021 | 02:43 PM
RussM05's Avatar
RussM05
Depends on how bad and where the coolant went. Coolant in the crank case is bad as it dilutes the oil and could wipe out the bearings resulting in a new engine. If the coolant leaked outside the block and the system became low on coolant resulting in 240° temp, that's not so bad. The question then is why did the head gasket fail? Improper installation? Head bolts not torqued to spec? Block or head warped and out of flatness spec? Bad head gasket? The service tech should be able provide some information after the head is removed or the engine pulled.
Over the years, lots of engines had head gasket leaks and the repair was simply replace the head gasket. Don't know at this point, but don't simply assume the worse.
Old Sep 1, 2021 | 08:36 AM
Egoncool's Avatar
Egoncool
Mine hit 271 on the track, but it was 102 outside air temp. When I pitted the tranny flashed a warning.
Old Sep 1, 2021 | 09:52 AM
ArrestMeRed's Avatar
ArrestMeRed
Just got back from Spring Mountain and it was over 100 degrees both days. Never saw the temp on my car get over 225. Amazing cars and experience on the track. Rick Malone and his staff are outstanding!
Old Sep 1, 2021 | 02:48 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Has the car had any other work done recently? We've had a couple cars that had a cooling fan, radiator or similar part replaced at another dealer and then come in for over heating a few hundred miles later. The cooling system is a bitch to bleed correctly and both cars had air trapped in the system after their previous repairs. Both cars registered coolant temps in the 250+ range before getting towed in. We bled the cooling system, confirmed the coolant level and sent them on with no other issues.
It's even possible your car had an air pocket from the factory and the coolant temp sensor was reading that air pocket.
Old Sep 2, 2021 | 07:13 AM
Egoncool's Avatar
Egoncool
I’ve had an air pocket when they put a new engine in. The temp instantaneously goes to max and you get overheat warning, and then just as fast it goes away.
Old Sep 2, 2021 | 10:11 AM
socalspringmountain's Avatar
socalspringmountain
Premium Supporting Vendor
thank you!
__________________
Victor Resendiz
Spring Mountain Motor Resort and Country Club
Ron Fellows Performance Driving School
The Official Performance Driving School Of Corvette
www.racespringmountain.com
victor@racespringmountain.com
800-391-6891
Old Sep 2, 2021 | 10:24 AM
RussM05's Avatar
RussM05
During the event they COTA back in October it was also 100° and I never saw over 225 either and I have the screens installed. I know at Spring Mountain they don’t use screens
To C8 Overheated
Old Sep 2, 2021 | 07:13 PM
PRE-Z06's Avatar
PRE-Z06
That’s impressive, just curious how hard you were pushing it i.e. what kind of lap times you were turning?
Old Sep 2, 2021 | 09:07 PM
RussM05's Avatar
RussM05
i thought I was pushing pretty hard but
my lap times weren’t that great. Full throttle is on the front and back straights. So most of the
time you’re in the corners so not full throttle.
Old Nov 25, 2021 | 09:35 AM
okaythen's Avatar
okaythen
For tracking the car, C8 got no overheating issue right? ( and water, oil temp at 230 to 240 that's normal?)
