Sponsored by: CARiD
Performance Exhaust
Old Sep 9, 2021 | 07:23 PM
RickHuntz's Avatar
RickHuntz
Default Performance Exhaust
Can you use the performance exhaust (make it louder) while in the Tour Mode? If so, how? Thank you!
Old Sep 10, 2021 | 12:47 AM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
Exhaust settings (and all others) are fixed in Tour Mode. You can, however, adjust exhaust settings (and others) in My Mode. You can, if you want, set all other parameters just like tour mode, but the exhaust setting like Sport Mode or Track so that My Mode will be a "loud" version of Tour Mode. See owners manual.
Old Sep 10, 2021 | 03:45 AM
RickHuntz's Avatar
RickHuntz
Will the car still switch between V8 and V4 in My Mode?
Old Sep 10, 2021 | 08:35 AM
Kracka's Avatar
Kracka
V4 is still enabled in My Mode, but it is not in Z-Mode (which also allows you to adjust your parameters similar to My Mode). My Mode is tied to your key fob/profile and will retain that setting between ignition cycles.
Old Sep 12, 2021 | 06:36 PM
LT2/3LT's Avatar
LT2/3LT
Unmodified C8 of the Year 2021 Winner
Kracka - ??? to your comment highlighted in bold above. What am I missing or misunderstanding? I use My Mode 85% of the time behind the wheel, I use the same key fob 100% of the time and My Mode ALWAYS reverts to Tour Mode each time I shut down.
I would LOVE it to stay in My Mode....how??
Old Sep 12, 2021 | 07:08 PM
Kracka's Avatar
Kracka
Do you have a profile created and saved in the infotainment system? If I shut down in My Mode it remains in My Mode when I start it back up.
I have both our FOBs tied to the same profile, but each with their own unique memory seat settings.
Old Sep 12, 2021 | 07:15 PM
LT2/3LT's Avatar
LT2/3LT
Yes...at least I'm pretty sure I do!! On info screen at start up, my name appears and informs me I am using Fob 1.
I will be looking deeper into it tomorrow. This is good news if so as I am confident that if this is all it takes, I will be good to go. Thank you for this info.
If this works, there may be a group of others that this bit of info will be helpful to also as I have read in the past that my mode will always revert back to tour mode when you shut down.
How about Z mode? Same? As listed, I experience the same when shutting down while in Z mode...back to tour mode.
Old Sep 12, 2021 | 07:18 PM
Kracka's Avatar
Kracka
Z-Mode will always return to Tour.
Old Sep 12, 2021 | 07:21 PM
LT2/3LT's Avatar
LT2/3LT
Thank you. My experience also. Would be happy to get My Mode to stick. I'll update on my success or failure in the near future!!
Old Sep 12, 2021 | 07:24 PM
Kracka's Avatar
Kracka
Good luck! Your profile will be tied to your email in the infotainment system, just FYI.
Old Sep 12, 2021 | 09:21 PM
BJ67's Avatar
BJ67
V4 mode is still enabled in Z mode unless you set the engine/trans in track setting while in Z mode. problem with that is driving on the street , track mode is way to aggressive , trans will not upshift below 3000 rpm and downshifts if you just breath on the gas pedal. Manual mode will shut off V4 mode, but driving all the time in manual mode on the street in everyday driving .... gets to be a pita. Cannot wait for the ecm to be tuneable or when the range device can be plugged it to shut down V4 (AFM) mode completely.
To Performance Exhaust
