Sponsored by: CARiD
Track set up for daily use?
Old Sep 26, 2021 | 10:34 AM
Yellowvette10's Avatar
Yellowvette10
Default Track set up for daily use?
I am getting my 2lt z51 about two months from now. I was curious can I do the set for track use and do daily driving with it without any issue? I will probably do track twice a month and probably do a lot of spirited driving during daily drive.
Old Sep 26, 2021 | 10:39 AM
64drvr's Avatar
64drvr
St. Jude Donor '15
Track prep guide, brake fluid, and alignment.
Old Sep 26, 2021 | 02:17 PM
Yellowvette10
I got that but is that set up any side effects for daily driving?
Old Sep 26, 2021 | 03:15 PM
c5racr1's Avatar
c5racr1
I keep the track set up. Have not noticed any increased tire wear. Another member got 13k miles with the track alignment.
Old Sep 26, 2021 | 03:41 PM
Yellowvette10
Ya tire was my main concern. Have you seen any increase in 0-60? anything else felt different vs stock set up?
Old Sep 26, 2021 | 03:51 PM
NoMatter's Avatar
NoMatter
What’s Next
You won’t get the best 0-60 times from a track alignment.
I’m on track setup and like to see at least 10K miles. All depends on what tires you actually run and how hard you run. Also how many track days you do a year. Cross reference that with how many alignments you might do going back and fourth.
Old Sep 29, 2021 | 11:18 PM
KK87's Avatar
KK87
Tracked my car in street alignment -- I had 7,500 daily street miles on the factory stock tires, put three days on the tires (total about 180 miles of track time) and I think the Carousel at Road America just finished the fronts for good, rotated the tires through the day. Gonna use this on a few short commute as I'm waiting to put winter tires on in 6 weeks from now anyway.
Cold pressure was 25 psi, hot was 32 psi
Old Oct 20, 2021 | 06:05 AM
Jacques Albrecht's Avatar
Jacques Albrecht
I've been driving my 2LT Z51 + Mag ride (but no front lift) for ~ 5,000mi or one year now with the full track track set-up and have not had any issues - tires are wearing fine. Found that the OEM street alignment was too squirrely.
Old Oct 20, 2021 | 12:10 PM
C8gofast's Avatar
C8gofast
What is your camber and toe setup for the track?
Old Oct 20, 2021 | 12:29 PM
NoMatter's Avatar
NoMatter
What’s Next
For myself I’m running -3.5° and 0 Toe on front and -2.5° and .02 in toe on rear.
I believe I need to run -3° camber in the rear. Tire rolls over a little to much for myself.
Old Oct 20, 2021 | 10:59 PM
foo.c's Avatar
foo.c
I now have about 200 miles on the track alignment and I also had it lowered 1/2". No problems. It does spin the rear tires easier now is the only thing I noticed.
Old Oct 20, 2021 | 11:01 PM
Jacques Albrecht
Default Factory Track Align Specs
These are the numbers I'm running: First page is my set-up; Second page is the factory recommended track spec sheet.
Old Jan 7, 2022 | 08:48 PM
Greg_c8's Avatar
Greg_c8
So I was gonna start a post on cost to set my C8 up to track and then ask, assuming I do track on a weekend, how much is it to go back to normal...or once track never back?? Do people "track" align and lower and go back...back and forth or people who configure a legit track setup just stay that way.
Just curious
To Track set up for daily use?
