Sponsored by: CARiD
HTC Halltech Hornet Install
Old Mar 1, 2022 | 06:41 PM
MillerTimeISU's Avatar
MillerTimeISU
Default HTC Halltech Hornet Install
Dropped off my 2021 HTC to Paragon Performance today to have them R&D the HTC fitment for the intake install! I will provide updates once I get them.
Old Mar 1, 2022 | 06:45 PM
Fore58's Avatar
Fore58
Thank you sir👍🏻
Old Mar 1, 2022 | 07:48 PM
ArizonaZ06's Avatar
ArizonaZ06
From: Early 2020 Z51 Coupe, Original Owner, Ahwatukee Foothills, AZ
Like the HTC just gonna take some extra time.
Old Mar 1, 2022 | 11:55 PM
Kracka's Avatar
Kracka
Awesome! I'm sure they'll find an acceptable solution for you. I'm curious if Halltech will eventually release a revised box design or additional HTC specific box?
Old Mar 2, 2022 | 10:15 AM
MillerTimeISU
I think Halltech is looking to its vendors to help come up with a solution
Old Mar 2, 2022 | 11:28 AM
WHPLASH's Avatar
WHPLASH
Katech has my HTC for the Halltech also. Good luck!!!
Old Mar 3, 2022 | 05:59 PM
MillerTimeISU
Default HTC Hornet
Paragon Performance just called and said they got it installed. The only modification is to simply remove (1) single rivnut. The access panel goes back in place, as does the carpet kit. Paragon should be releasing a video soon of the install on it. Thank you Paragon and Halltech excited to drive it tonight
Old Mar 3, 2022 | 06:02 PM
MillerTimeISU
Default Here are two initial pictures of the single rivet that is removed.
Old Mar 3, 2022 | 10:46 PM
Kracka's Avatar
Kracka
So... Why doesn't Halltech know this? It's almost like they created an intake system and never actually test fit it...
I hate to say it, but they literally copied the stock intake system and slightly enlarged it without actually trying to test fit it on a vehicle. 🤞
Their R&D consists of a computer program and a fake dyno sheet created with Excel?
Old Mar 3, 2022 | 10:55 PM
MillerTimeISU
So... Why doesn't Halltech know this? It's almost like they created an intake system and never actually test fit it... On wait
Their R&D consists of a computer program and a fake down sheet created with Excel; nothing more.
They designed it off the C8 they had which was a coupe. Then released it's and didn't have access to any HTC to verify.
Also can verify the dyno results are legit but you can wait to see the testing and intake shootout video coming from Paragon doing 3rd party testing on their dyno.
Old Mar 3, 2022 | 11:00 PM
Kracka's Avatar
Kracka
They have no actual dyno results. Dru the CEO himself admitted he created their claimed dyno sheet with Excel.
Old Mar 3, 2022 | 11:05 PM
MillerTimeISU
They have no actual dyno results. Dru himself admitted he created their claimed dyno sheet with Excel.
I can't leak the results I saw but like I said keep an eye out for Paragon's video coming out. You can watch the dyno and results for yourself. No Excel magic.
Old Mar 3, 2022 | 11:07 PM
Kracka's Avatar
Kracka
Paragon's claims also misled people on their drop-in air filter test. Look at the actual dyno sheet results and you'll understand what I mean.
Old Mar 4, 2022 | 09:38 AM
drul's Avatar
drul
Supporting Vendor
Paragon made sure we were the first to know it. We try our best to ensure we post factual data without making assumptions or jumping to conclusions. Unfortunately, not everyone exercises the same caution when posting online.
Early on, we strategically decided to focus mostly on the coupe. Previous corvette generation sales suggested the convertible wouldn’t sell nearly as well as the coupe. The statistics supported our decision. Boy were we surprised when the sales ratio approached 50/50.
Anyway, we took delivery of a 2020 coupe early on and began our development work, which included 3D scanning the stock filter box and cover, as well as many of the mating components. Then we went to work on our 3D CAD design, followed by 3D printing each and every version and test fitting it in our couple. Once we knew it would fit, we hit the dyno and made iterative changes to both the filter box and the filter box cover to optimize the design and performance. The stainless backing plate and huge filter went through a similar evolution. Even the hardware selection process was carefully scrutinized. Fortunately, most of this work happened in very favorable weather conditions. It took much longer than we anticipated, which resulted in a winter launch.
And, to top it all off, yesterday we were blessed to learn that all that effort didn't go to waste on the HTC. Phew!
Old Mar 4, 2022 | 09:40 AM
drul's Avatar
drul
Supporting Vendor
Almost true. I admitted I used excel to create the graph, but it was generated from an actual csv table exported from real dyno tests done at Powerlabs Dyno in Idaho Falls by a very skilled Jeremy Bird.
Old Mar 9, 2022 | 07:06 PM
MillerTimeISU
Install video from is live
Old Mar 19, 2022 | 09:24 AM
itsonlyairandfuel's Avatar
itsonlyairandfuel
Where can we watch the results, of the halltech dyno run video?
Old Mar 19, 2022 | 09:48 AM
MillerTimeISU
I'll check with guys a lot Paragon next time 8 swing by to see where they are with it
To HTC Halltech Hornet Install
