Sponsored by: CARiD
Lowered C8 MAG ride
Old Mar 3, 2022 | 02:41 PM
KAguilar90's Avatar
KAguilar90
Default Lowered C8 MAG ride
Hello all,
I’m about to place my order for a new corvette and I read mixed options on MAG ride. Besides that, I read you can actually lower the vehicle about an inch with just some wrench in you have MAG ride.
Question being, I’m sure stock drives smooth but once you lower it on MAG ride does it change that smoothness? I don’t need a huge drop so that “1” I read might be enough. But if it affects the smoothness, then I might just order it without MAG ride and get the paragon springs.
thanks for all your guys/gals help. Appreciate it!
Old Mar 3, 2022 | 02:44 PM
MarioC8's Avatar
MarioC8
I haven't noticed any difference in smoothness after lowering my vehicle on stock suspension. I have a 2022 NON-z51 C8 with mag ride.
Old Mar 3, 2022 | 02:45 PM
c7steve's Avatar
c7steve
I dont have mag ride, but i do have a Z51 ,which i lowered and rides just like new before lowering. I am glad i didnt get mag ride because i like to drive in sport or track mode all the time. that way the ride does not get stiffer
Old Mar 3, 2022 | 03:21 PM
KAguilar90's Avatar
KAguilar90
You lowered it all the way on your MAG suspension? Do you have any pictures you could share?
Old Mar 3, 2022 | 03:56 PM
MarioC8's Avatar
MarioC8
I could have probably gone slightly lower on the rear but this is pretty much maxed out.
Old Mar 3, 2022 | 04:28 PM
KAguilar90's Avatar
KAguilar90
What? That’s maxed out on MAG ride? Looks amazing! I might as well go with the MAG ride option and max it out. Get a great drop and you don’t loose that stock comfort. Thank you!!!
Old Mar 3, 2022 | 05:55 PM
MillerTimeISU's Avatar
MillerTimeISU
Ditto same here with 20”/21” wheels installed too
Old Mar 4, 2022 | 05:57 AM
Tim0shel's Avatar
Tim0shel
I basically ordered a Non-Z51 but added Mag ride to have this option to lower the car but also give more firm ride when wanted. But I also plan to do springs as well and then fine tune it with the stock adjustments.
Old Mar 4, 2022 | 12:01 PM
RKCRLR's Avatar
RKCRLR
You can make the My Mode and Z-Mode settings the same as Sport and Track but have the suspension set to Tour and get the same results with MSRC.
Old Mar 7, 2022 | 08:28 PM
22c8z51's Avatar
22c8z51
Does someone have a pic completely lowered on stock wheels? Curious how that looks....
Also, where are the wrenches to lower the suspension available? I don't need anything fancy.
Old Mar 7, 2022 | 08:33 PM
MillerTimeISU
Paragon sells the wrenches if you have Z51 or non-Z51 with magride. Also I used front lowering collars since I had front lift. I have wheel spacers to flush the stock wheels with the body line
Old Mar 7, 2022 | 08:41 PM
22c8z51's Avatar
22c8z51
looks great! paragon spacers all 4 corners?
Old Mar 7, 2022 | 09:11 PM
MillerTimeISU
Yep and since have taken them off when I upgraded to 20"/21" with.correct.offsets
To Lowered C8 MAG ride
