Do all DCT's operate in the same manner?
https://thenewswheel.com/4-mistakes-...-transmission/
"Aaron is unashamed to be a native Clevelander and the proud driver of a Hyundai Veloster Turbo (which recently replaced his 1995 Saturn SC-2). He gleefully utilizes his background in theater, literature, and communication to dramatically recite his own articles to nearby youth. Mr. Widmar happily resides in Dayton, Ohio with his magnificent wife, Vicki, but is often on the road with her exploring new destinations. Aaron has high aspirations for his writing career but often gets distracted pondering the profound nature of the human condition and forgets what he was writing…"
NO issues except for the rear caster you are referring to where a special gauge is needed. UNLESS tracking I would not let the average tech touch the rear caster adjustment- can screw it up! If tracking only go to a shop who knows what they are doing AND has done it before. Typically a race shop. Otherwise all other adjustments like any other car.
Tremec bought a high-tech automotive design and development organization HOERBIGER Drivetrain Mechatronics BVBA located in Loppem, Belgium in ~2011. HOERBIGER products and software solutions are found in leading European sports cars, including Ferrari Italia 485, AMG SLS and McLaren MP4-12C.
They no doubt have dealt with all the issues. As Tadge said no issue letting the 1st gear clutch slip slighlty as it does at a red light. The trans is robust! Heck Emilia Hartford has pushed her C8 engine to 1000 hp. As I recall other than adding HD clutches and beefier axles she has not blow-up the DCT!
And in those cars there is a tolerance called PIS ― Punto Incipiente Slittamento or point of initial slip ― which if misaligned causes the clutch to slip all the time, wearing it out prematurely.
This is not a transmission defect. They typically last forever.
Ray
Ray
The tremec does not have pistons actuating the clutches. They are fluid actuated like all dcts. The fluid is controlled by 8 solenoids on the clutch side.
"Next in line are the two normally open wet clutches positioned concentrically to save space. Hydraulic pistons [emphasis added] rotating with the clutches force them into engagement when commanded to do so by the transaxle's electronic control module."
Do you know something that the Society of Automotive Engineers is unaware of? Or are you gonna climb further out on that very thin limb?
Ray
https://www.corvetteblogger.com/2021...-take-so-long/
Ray
What i am saying is that the dct in all the cars you mentioned are in fact not using clutch forks and throwout bearings. They are hydraulically actuated (fluid activated) exactly like the c8 tremec. They use springs to open and hydraulic fluid to close. Yes there are bearings but they are activated by hydraulic fluid just like the cars you said use clutch forks and throwout bearings.
Ray
And just to be clear, "hydraulically actuated" is another way to say fluid activated.
And what about the pistons used to close the clutch? You said they didn't exist, remember?
And I'm sure Porsche owners, especially those up to 1980, will be thrilled to hear that they have a DCT because you said
Do a little homework before you shoot from the hip. And brush up on the rules of capitalization.
Ray
Not "activated" lol. .... "Actuated". Sorry about that. You got the idea i think.
Again, actuated. Just like your brake pistons are compressed against the pads via hydraulic fluid. Hope that helps you to be able to visualize it.
I have no idea why you are discussing a manual transmission with single dry clutch and were stating dual cutch transmissions from Ferrari, Lamborghini and Porsche are similar.
Again there is no throwout bearing or clutch fork on dual clutch transmissions from Ferrari, Lamborghini or Porsche.
Seriously?
And the C8 transmission is a manual transmission. It's does not have a torque converter. It has a multi-plate friction clutch, you just don't have to engage/disengage it.
And Porsche did not start using the PDK transmission until 2009. So much for "Porsche always used it".
Ray
Ray
Seriously?
Ray
You said...
..two normally open concentric clutches opened by springs, closed by hydraulic pressure
Most people would just thank me for providing you the resource like you requested. No problem Ray.
And the c8 uses a tremec tr9080 dual clutch automated transmission Ray. Unfortunately there is no manual option sorry.
And again Ferrari Lamborghini and Porsche dct do not have throwout bearings or clutch forks.
