I've filtered through multiple threads and watched many Youtube videos and it's not clear if ANY C8 bolt ons or combinations of bolt-ons (obviously without a tune) actually "bolt on" proven repeatable extra power. I have seen examples of a few combos that cost many thousands of dollars, but after extensive dyno and field testing show little to no gains.
I am not new to Corvettes (My C8 HTC Z51 is my 4th after trading in my 2019 GS Manual) but previous generations were easy to add "bolt on and tune" components.
So: tell me about your personal experience (dyno proven would be ideal) with C8 bolt ons and if any of them have been significant additions to your C8 given no ability to tune the car.
My ideal goal with my HTC would be Exhaust/Intake type mods that hopefully gain back enough power to be equal to coupe performance (given the extra weight of the HTC- 77lbs)- perhaps REAL rear wheel 20-30hp
I can't find that this thread is exactly redundant to previous threads...If it is - please close this and provide links
You are correct. The best bet is simply adding a good exhaust. It will free up decent power (maybe 10 whp), get some great sound, and save a lot of weight pending which one you get. If cats are up your ally you MIGHT net a few more whp but save some more weight. Anything after that is pure luxury until a tune ever presents itself.
Unless you want to drop 6-7K to drop the motor and have the heads ported which has proven to add 50-60whp we’re all pretty much waiting.
Hey Oregonsharkman, take a look at my post in the sticky section (Unofficial C8 Fast List). Well the only difference is that you have a Z51 HTC. I am not too keen about dyno results but mostly drag strip results. Having said that, I had only one occasion to take my base model HTC to the drag strip and was impressed for the first time out. I pretty much follow the guys with C8s at my track. There is one guy that I talk to and pretty much familiar with his bolt-ons. Not a HTC Z51 but just a Z51 with a high spoiler. His C8 with numerous runs at the in stock form best was 11.21@118. He later did the following mods.......ported intake manifold, 91 ported TB , Attack Blue Filter and AWE Exhaust system which resulted to a 10.93@122.51. The tires in use at the time was the Michilen 4S which probably gave him a better 60ft time. And yes I am aware that your car is the heaviest of the C8s. This info is only to give you an idea. My mods will probably be similar but with the 95 TB and without the AWE Exhaust system.
Saw a post by one owner who did before and after dyno tests. He did an intake, exhaust and, IIRC, sport cats. Ended up gaining about 25 hp, which really isn't very much considering the effort involved.
Every mod company claims. it seems, 15-20 hp. But the mods aren't additive. You don't get 60 hp by adding three mods that each [claim to] deliver 20 HP.
I'd agree with the full round of bolt-ons being worth approximately 20-25whp gains vs. stock.
I'm personally @ 450whp and think it's pretty well maxed out on the stock tune. I could maybe squeeze out a few more ponies with a catback system but I'm quite happy with the sound as-is (headers + cats w/NPP).
Sure, it was a lot of money considering, but I'm very happy with the results, the sound, and how it all looks. I also like just doing it! No regrets and would do it all over again and probably wouldn't change a thing
Right......each mod compliments the other. It just doesn't work that way by adding gains per mod. And actually 25 rwph does make a difference from stock. I don't rely on dyno numbers because to me it's just only very good tool to use. Example: The C8 I mentioned above only made 434 rwhp with basic mods.......same day and condition completely stock C8 made 423. The mods on the C8 were AWE Exhaust system, attack blue filter and 91mm ported TB. That was a 11 rwhp difference between the two C8's and both Z51's. When the modded c8 added the ported throttle body it picked up two tenths and two mph trap speed through the quarter mile. Those numbers definitely translated to a certain amount of horsepower in order to accomplish that feat. Having said that it was obvious that particular combo worked very well.
Note: So that same c8 completely stock went 11.30@118......modded it went 10.93@122.51.
I am willing to bet that those mods together were no more than 25 rwhp.
From: Early 2020 Z51 Coupe, Original Owner, Ahwatukee Foothills, AZ
In the same club whp as well but get that sweet sound with a slightly different cocktail ........ Cats + Hornet + pTR
2m cat delete, Halltech hornet, less than $1500 DIY, can be accomplished at the same time. Can be put back to stock and sold off when your ZO6 comes in.
Intakes and sport cats are a great place to start for sure. I personally did the aFe intake (initially the Pro5R then switched to DryFlowS) and Corsa high-flow sport cats (since they're 49-state legal, EPA-compliant, and guaranteed to not trigger a CEL, no spacers needed, etc.).
Paragon's independent intake system testing:
Quick summary of peak numbers with gains, in order of appearance, so we have it documented:
I have every performance mod you can put on a C8 except for ported heads and can say that none have really done much of anything with regards to track results. The stock cats actually flow incredibly well because of their size, the sport cats end up just being about getting the sound right.
Some mods have increased throttle response slightly, some have made the car sound different, but from a seat of the pants perspective nothing has made a real impressive difference. However I'm confident my car is set up well for when tuning is available which is nice
My dyno is 660 ft long ,up hill @ 6000+ DA. MPH is what I base my gains on. First test&tune 5/15/22 will see what a soler-socal port job added. Keep testing, dynos don't race & cars don't read magazines. As a group we will all make gains, and share results, And Learn.
You're better off just doing a ported factory intake manifold and ported factory throttle body; you'll see the same gains/benefits at a fraction of the cost.
I agree Kracka. What you are referring is where I want to start......ported intake manifold, the 87 mm ported throttle body to 91mm and the blue attack filter. Surprisingly those mods didn't show that much on the dyno but on the track almost 2 tenths and 2 mph in good air. Since you cannot tune this car, favorable air is your friend. Horrible air will kill your added horsepower mods in almost all instances.
