Sponsored by: CARiD
Removing Stock Cat
Old May 11, 2024 | 06:06 PM
reymusic's Avatar
reymusic
Originally Posted by SinisterC6
Yes, the check engine light illuminates every 50-60 miles. Using that OBD2 to Bluetooth adapter I have it auto clear the P0420 and P0430 codes. If the light is on you cannot remote start the vehicle.
People insisted I use a O2 sensor spacer on the corvette to prevent a check engine light but they did not work. When I was purchasing from Fabspeed they could not guarantee their mini cats so i couldn't justify the added cost of that solution either. I had better luck on my 2020 M2 using spark plug defoulers drilled out to fit the O2 sensor and would keep the CEL off for about 500 miles.
Removing the cats adds a smell that some may not like. It makes the exhaust pop more on decel. Adds about 20-30% volume
My camera should be arriving today and if it does ill get you videos.
im having the same
issue and i was think of buying the O2 spacers but many says it will not be guaranteed..could you provide me the exact OBD2 to Bluetooth adapter you are using.my car is a 2024 C8 Z06 with 2M fab sport cats installed.thank you in advance
Old May 11, 2024 | 06:11 PM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
Originally Posted by reymusic
im having the same
Amazon Amazon
Old May 11, 2024 | 06:25 PM
reymusic's Avatar
reymusic
Thank you ,i will get it for the C8 Z06 and hopefully it will work.
Old May 12, 2024 | 10:38 AM
undecided1965's Avatar
undecided1965
On the M5 V10, cat deletes were worth about 40hp but the smell is strong. Not recommended for a daily driver.
