Sponsored by: CARiD
Removing Stock Cat
Old Oct 31, 2022 | 04:16 PM
camwilson6's Avatar
camwilson6
Navigator
Default Removing Stock Cat
Thinking about doing a cat delete and straight piping my C8. Any thoughts?
do I need a tune following this? If so, how much can I expect to spend?
Old Oct 31, 2022 | 05:09 PM
Racer X's Avatar
Racer X
No tune necessary. The C8 has wide band O2 sensors and functions in closed loop all the time, except start up and limp home. As for cost? how are your welding skills? If none, there are bypass pipes with new gaskets for $420 if you can install them yourself.
Old Oct 31, 2022 | 06:01 PM
camwilson6's Avatar
camwilson6
Navigator
so I won’t get a check engine light if I do this? And I plan on just taking it somewhere after I get the part and having them install it
Old Oct 31, 2022 | 06:13 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Not quite sure but I think any C8 is NOT tunable---
Old Oct 31, 2022 | 06:38 PM
bhvrdr's Avatar
bhvrdr
Youll get a cel and id advise against "mini cat" or defoulers to try and physically remove it. The cel is just a cat inefficiency code and will have zero negative performance impact. The defoulers and minicats on the other hand can impact metering.
Old Oct 31, 2022 | 08:08 PM
camwilson6's Avatar
camwilson6
Navigator
Originally Posted by bhvrdr
Youll get a cel and id advise against "mini cat" or defoulers to try and physically remove it. The cel is just a cat inefficiency code and will have zero negative performance impact. The defoulers and minicats on the ither hand can impact metering.
How do I combat or fix these issues? and how much performance can I expect to receive from it?
Old Oct 31, 2022 | 09:45 PM
bhvrdr's Avatar
bhvrdr
No issue to fix. Don't use a spacer or mini cat. Ignore the cat inefficiency cel.
Im sure you are already aware of the regular cons associated with running catless.
Old Oct 31, 2022 | 10:03 PM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
I use a Bluetooth obd2 adapter to run torque and auto clear the CEL. The light doesn't bother but you can't remote start if it's illuminated at shutdown
I used defoulers when I decatted my bmw and would go 5 to 600 miles between lights. I tried a O2 spacer on the c8 and get the light every 50 miles.
I never used a mini cat but don't recommend it because there's no guarantee.
Below is a obd2 blutooth adapter
https://www.ebay.com/itm/25519817761...hoC4L0QAvD_BwE
Old Oct 31, 2022 | 10:28 PM
camwilson6's Avatar
camwilson6
Navigator
What issues presented when you removed your cat out of your C8? Any lights or other issues?
Old Nov 1, 2022 | 10:16 AM
SinisterC6's Avatar
SinisterC6
Speedy
Yes, the check engine light illuminates every 50-60 miles. Using that OBD2 to Bluetooth adapter I have it auto clear the P0420 and P0430 codes. If the light is on you cannot remote start the vehicle.
People insisted I use a O2 sensor spacer on the corvette to prevent a check engine light but they did not work. When I was purchasing from Fabspeed they could not guarantee their mini cats so i couldn't justify the added cost of that solution either. I had better luck on my 2020 M2 using spark plug defoulers drilled out to fit the O2 sensor and would keep the CEL off for about 500 miles.
Removing the cats adds a smell that some may not like. It makes the exhaust pop more on decel. Adds about 20-30% volume
My camera should be arriving today and if it does ill get you videos.
Old Nov 1, 2022 | 11:04 AM
Racer X's Avatar
Racer X
The power gains are not that great from the reports I have read. Mostly sound. You would have to have other mods to need the extra flow. The stock cats have huge openings. Bigger than most standard aftermarket cats.
Old Nov 1, 2022 | 04:59 PM
gavinvr4's Avatar
gavinvr4
I had Soul Performance sports cat with stock exhaust, it sounds great especially if you want to retain the AFM valves, most importantly no CEL.
I now upgraded the paragon exhaust so no need for the sports cat, hit me up if you interest in them.
Old Nov 1, 2022 | 06:00 PM
ArizonaZ06's Avatar
ArizonaZ06
Active Streak: 90 Days
From: Early 2020 Z51 Coupe, Original Owner, Ahwatukee Foothills, AZ
Your going to make someone very happy.
Have the HJS 200 Cell Cats as well with the NPP stock exhaust and the sound is just right.
Old Nov 1, 2022 | 09:31 PM
camwilson6's Avatar
camwilson6
Navigator
you think I’d he beret off with a muffler delete? Or would suggest different cats? I don’t plan on adjusting my exhaust at all.
Old Nov 2, 2022 | 07:05 AM
SinisterC6's Avatar
SinisterC6
Speedy
Cat delete gives you a max volume in track mode while making it tame in tour and weather mode
Old Nov 2, 2022 | 10:45 AM
gavinvr4's Avatar
gavinvr4
Very simple if you track your car and don’t mine the obnoxious noise then go with test pipe, you might gain a few more hp. Otherwise stick with sports cat to eliminate CEL.
Old Nov 2, 2022 | 02:06 PM
d16dcoe45's Avatar
d16dcoe45
In what way do the defoulers impact "metering"?
To Removing Stock Cat
Old Nov 2, 2022 | 03:28 PM
C5racecar's Avatar
C5racecar
Performance gain; next to nothing, maybe a few HP. Bad smell, if you back up into a parking place, you will smell strong exhaust smell. Why bother? It will never pass DMV or DEQ.
It may sound different, but overall not worth the trouble. I had a no cat racecar that I drove on the street, every time I came to a stop sign I could smell that nasty exhaust. I put high flow cats on it.
Old Nov 3, 2022 | 10:07 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
Fun starts about 25 minute mark. 20HP gains.
Old Nov 4, 2022 | 09:37 PM
PhoenixM3's Avatar
PhoenixM3
Originally Posted by itsonlyairandfuel
Fun starts about 25 minute mark. 20HP gains. https://www.youtube.com/watch?v=E23z3UtwMOQ
I’d say take my money, but I’ll likely go with ARH and no cats anyway.
