Sponsored by: CARiD
c8 instrument cluster goes blank
Old Oct 31, 2022 | 05:03 PM
frontera's Avatar
frontera
1st Gear
Default c8 instrument cluster goes blank
2023 C8 instrument cluster went blank on 2 occasions. Each time the car sat outside in 85 degrees + for over an hour. When starting all systems operational except for the instrument cluster, completely dark. tried everything I could, no results. The only way that corrected the problem was when the vehicle cooled down in my garage and all systems were go. Haven not had the problem since cooler weather arrived. Finally took to the dealer and they are at a loss as to the sporadic issue. They reprogrammed the entire computer system, so we'll see if the problem re-occurs.
Old Nov 1, 2022 | 07:05 PM
Jnape's Avatar
Jnape
My 2022 did it once right after I started it it was on than blank. It takes 15 min for the BCM to shut down so it can do a cold boot up. I'm in the Central Valley in Ca. My car has been outside parked in 110 deg days without issue. I don't think it's a heat issue. More a boot up hiccup.
Old Nov 5, 2022 | 10:18 AM
dohabandit's Avatar
dohabandit
Sounds like classic symptoms of a cold solder joint. Thermal expansion is causing the faulty connection to open up.
To c8 instrument cluster goes blank
