Sponsored by: CARiD
Dextros 2
Old Nov 18, 2022 | 04:52 PM
fredl11's Avatar
fredl11
Default Dextros 2
Where are you finding it? Have no joy here in Ft. Lauderdale , Fl Either dont have it or out
Old Nov 18, 2022 | 05:27 PM
bhvrdr's Avatar
bhvrdr
$5.50 a quart at AutoZone and they ship it next day air to you for free...
https://www.corvetteforum.com/forums...ispreloading=1
Old Nov 19, 2022 | 10:26 AM
Bburr's Avatar
Bburr
I'm sure that is not the correct oil.
Old Nov 19, 2022 | 11:46 AM
C8-Vette's Avatar
C8-Vette
I agree
Old Nov 19, 2022 | 01:35 PM
RKCRLR's Avatar
RKCRLR
It is the correct oil, I purchased 10 quarts.
Old Nov 19, 2022 | 04:07 PM
bhvrdr's Avatar
bhvrdr
Originally Posted by C8-Vette
I agree
Just check the manual. The c8 requires dexos 2 (or 2023 its dexos R) 0w40 oil. Theres three oils available that meet this (2 are identical oils actually).
1. M1 ESP 0w40
2. M1 Supercar 0w40
3. M1 ESP x3 0w40
The one referenced is indeed an approved oil and arguably a the best of the three
Old Nov 20, 2022 | 06:15 PM
MikeinAZ's Avatar
MikeinAZ
1. M1 ESP 0w40
2. M1 Supercar 0w40
3. M1 ESP x3 0w40
yep, the x3 meets stringent Porsche specs and i prefer to run that of the 3.
Old Nov 24, 2022 | 11:53 AM
psollitto's Avatar
psollitto
I just went on the Auto Zone web page and I cannot find anything but the European blend. What am I missing?
Thanks.
Old Nov 24, 2022 | 01:52 PM
Drew888's Avatar
Drew888
Mobil has discontinued the ESP for 23. The options are the ESP X3 (dexos 2) and the Supercar (dexos R). The 23+ Stingray’s are spec’ed dexos R and from recent dialog with Mobil they claim that the SuperCar is the only product for this application. I did notice that the X3 does have a slightly higher viscosity though. The SuperCar is currently hard to find and seems to be a bit more expensive.
1. M1 ESP 0w40
2. M1 Supercar 0w40
3. M1 ESP x3 0w40
Old Nov 24, 2022 | 10:31 PM
bhvrdr's Avatar
bhvrdr
You can buy supercar from Walmart (online only). But yeah I have a 2022 so i go with esp x3 that has much better high temp protection.
Originally Posted by psollitto
I just went on the Auto Zone web page and I cannot find anything but the European blend. What am I missing? Thanks.
Part number 124798
Put in your car information then search the term "oil"
Old Nov 25, 2022 | 09:18 AM
Andybump's Avatar
Andybump
...... I have a 2022 so i go with esp x3 that has much better high temp protection.......
Does one or more of these numbers capture the higher temperature protection of the ESP X3? These are from the product data sheets on the Mobil site. I realize there is more to an oil specification than just these parameters.
Old Nov 25, 2022 | 10:39 AM
Drew888's Avatar
Drew888
No and both oils are very close in chemistry based of the data released by Mobil. Definitely not “much better”, but maybe a little better.
I have had some dialog with Mobil via email. I will inquire more about the two options. Mobil has not re-added the C8’s to the application guide since the change. What is most important is the noack volatility and phosphorous content.
Old Nov 25, 2022 | 11:07 AM
Andybump's Avatar
Andybump
...... both oils are very close in chemistry based of the data released by Mobil...........
Well, maybe, maybe not. I don't know and I was not suggesting that either way. The actual details of the dexos2 or dexosR requirements are far, far more than just the list of parameters in the PDS. I was just asking if the higher temperature protection of the ESP X3 is captured in one or more of the advertised parameters. I'm trying to learn something, not make a point.
I have also had email exchanges with Mobil and was told that dexosR supercedes dexos 2. And someone posted a reference, direct from Mobil (and not second hand from a third party website) that said ESP Formula 0W-40 (not to be confused with ESP X3 which was the subject of my question) and Supercar are identical, at least at the time the material was published.
Old Nov 25, 2022 | 11:41 AM
Drew888's Avatar
Drew888
I was answering your question in regards to the difference based on the information that has been released from the manufacturer, not a third party, about the difference between the 0-40 esp x3 and the 0-40 supercar. Not the previous esp.
The pds does have some important information about the physical properties, such as the viscosity, shear and flash point. These properties are relative to the chemistry. There is not much known other than what has been released by Mobil.
This is speculation based on the known viscosity and the limits of allowable phosphorus for catalytic emission vehicles one can deduce that these are very similar. As mentioned if we knew the noack and phosphorus values maybe we could quantify the difference between the two current offerings. IMO these are very close in performance. The esp x3 is specified to have been developed for applications using particulate filters.
Old Nov 25, 2022 | 12:10 PM
Andybump's Avatar
Andybump
Yes, thanks. And your answer to the question - do any of the parameters reflect increased temperature protection - was no. There are several parameters that appear to have something to do with high temperature - Kinematic Viscosity at 100C, Hi-Temp Hi-Shear Viscosity at 150 C, and Flash Point. I was asking the person that made the statement if any of these reflect the protection at higher temperature. I was not trying to make a point - I'm just interested in how it was determined.
Old Nov 25, 2022 | 12:16 PM
MikeinAZ's Avatar
MikeinAZ
I learned of the exp3 oil a year ago, maybe more and special ordered it and started using it.
I had heard about it on bobistheoilguy site which I've been part of for years. Some of those guys are immersed in tje tech side of oil, it's overwhelming. They had put out a lot of Info on that oil at that time and I remember it just being a robust oil that met the Porsche test standards which are very stringent. I read over data sheets and comparisons, check out that site for additional info but know it's in elite territory to meet a Porsche test and wear standard.
Old Nov 25, 2022 | 12:21 PM
bhvrdr's Avatar
bhvrdr
The high temperature viscosity is the number to look at for high temp protection.
3.8 is significantly higher than the 3.53 which just barely skates by the minimum required 3.5.
as far as virgin oil analysis, these were done at different labs so take them with a grain of salt. I use three labs and their values are regularly off by around 10 to 15 percent. Nothing jumps out from them ...
To Dextros 2
Old Nov 25, 2022 | 12:35 PM
Andybump's Avatar
Andybump
Thanks! That's what I was wondering. I can see the difference, which was a little over 7.6% higher, but don't have a feel for whether or not the difference is significant.
Old Nov 25, 2022 | 12:58 PM
Drew888's Avatar
Drew888
Those oil analysis’s are very close. Viscosity is a very straight forward measurement. Based on the tests the old esp was very close to the x3. There are manufacturing tolerances, it is possible that they could overlap when in the min and max condition. Based on the information so far, the difference is small and the overall benefit might not be measurable. I’m not trying to be a naysayer, but just practical or realistic. There is always a possibility that there are economic reasons behind the different versions. Would not be surprised if GM profits from the dexos labeling or Supercar product.
Old Nov 25, 2022 | 01:00 PM
bhvrdr's Avatar
bhvrdr
I wouldn't call it a massive difference but definitely significant. To put it into perspective generally oils from 0w20 up to 15w50 have from around 2.5 to 5.5 high temp high shear viscosities
