Brake Fluid For Track
Although the Motul 600 (and even their more expensive, shorter service life Motul 660) are exceptionally good brake fluids, they are actually second and third in performance behind Castrol SRF. If you compare product spec sheets (links provided below), you'll see that Castrol SRF has a higher dry and wet boiling point. And what is more exciting, is that is rated to stay far above the necessary point, for up to 18 months. This means one flush at the start of each season and you'll be good for the entire season. I found the best price here:
Links to products' specifications:
Motul 600 (dry 594 F / wet 399 F): https://s3-eu-west-1.amazonaws.com/motul-production2/images/product_descriptions/technical_data_sheets/2635/RBF_600_Factory_Line__28GB_29.pdf?149201 6152
Motul 660 (dry 622 F / wet 399 F): https://s3-eu-west-1.amazonaws.com/motul-production2/images/product_descriptions/technical_data_sheets/2636/RBF_660_Factory_Line__28GB_29__281_29.pd f?1492016152
Castrol React SRF (dry 608 F / wet 518 F): http://www.goldfren.cz/_download_news/srf_en.pdf
Some people are highly recommending Prospeed's brake fluid.
I got the numbers from Prospeed RS683's website, see: http://rs683.com/abcs-of-brake-fluid/brake-fluid-chart/ .
For me, the "wet" boiling temperature is most important. A few other "race only” fluids start with a slightly higher "dry” temps (temps beyond our requirements) but degrade quickly and terribly with exposure to moisture. This is okay for race-teams that flush the fluids for every event.
Prospeed's big push is their claim of a very low (1%) dissolved oxygen, which contributes to a firm pedal. They suggest some of their competitors have 5% dissolved oxygen. I'm a little suspect that this is marketing hype, right along with their girls in skimpy clothing, corporate jets, and Lamborghinis. Maybe their 1% is good compared to Kmart's DOT 3, however if their 1% was truly unique in the world of high performance brake fluid, they should disclose this information on their comparison chart as well.
Prospeed RS683: dry 583 F / wet 394 F
Castrol React SRF: dry 608 F / wet 518 F
What concerns me with the Prospeed and the others is their 33% reduction in boiling point after becoming wet, and not knowing when it is wet! On the other hand, Castrol SRF only degrades 15% when wet. Castrol suggests in normal use, it will be dry enough track use for 18 months. So I feel very comfortable with one flush per season because even when wet, it is at 518 F. By the way, our calipers don’t even reach 518 F during the heaviest of use.
In conclusion, I haven’t been able to find a brake fluid, at any price, better than Castrol SRF!
I will look into the Castrol. Their wet BP is almost too good to believe.
Sorry for the delay, yes -- less than 2L for the flush.
I tracked my car this past weekend and had excellent results with the OEM brakes with SRF. I managed to burn through a complete set of pads, though!
Check out the top of the line AP Racing fluid. Higher Dry boiling point stats than just about anything else, and cheaper than SRF.
I run Endless in my Supra and have had great results as well. I wouldn't hesitate to run it in anything. Do you guys do any periodic bleeding or just set it and forget it?
I went to SRF just due to availability and it's pretty much guaranteed to be in the pits at any event.
I can't get my pressure bleeder to work though because the crappy reservoir cap seal leaks fluid everywhere. Does anyone here use a pressure bleeder and have a source for a cap that actually WORKS???
