Sponsored by: CARiD
Keeping C8 on All * ALL the Time
Old Dec 15, 2022 | 01:30 PM
joecbrzx's Avatar
joecbrzx
Default Keeping C8 on All * ALL the Time
Aside from putting trans in manual to have all 8. Is there a way to bypass this function and have all 8 cylinders all the time without having to put trans into manual?
Not concerned with fuel economy.
I also understand some of you say don't feel the difference. You just may drive in a way to where it doesn't matter to you.
However, for those of us who race, we can feel delay in throttle reaction time.
Old Dec 15, 2022 | 04:11 PM
Andybump's Avatar
Andybump
Use Z mode, and put the engine/shift setting to track.
Or use track drive mode.
Old Dec 15, 2022 | 05:19 PM
ArizonaZ06's Avatar
ArizonaZ06
From: Early 2020 Z51 Coupe, Original Owner, Ahwatukee Foothills, AZ
Get one of these: https://www.solerengineering.com/gen...tors/se0525-tc
You will have Zero throttle delay reaction time.
Old Dec 15, 2022 | 06:04 PM
bhvrdr's Avatar
bhvrdr
This.
Old Dec 16, 2022 | 04:07 PM
ak6960's Avatar
ak6960
For those that do race, select the mode that best enables the desired performance for your particular type of racing. If racing to the golf course to make your tee time, consider selecting other than weather / touring mode.
Old Dec 16, 2022 | 05:08 PM
RKCRLR's Avatar
RKCRLR
If your only concern is when you are racing then put it in Track mode. AFM is locked out in track mode as well as when using Z-Mode with engine/shift set to track.
Old Dec 16, 2022 | 05:22 PM
saleen556's Avatar
saleen556
THIS. I found this to work best for myself as well. I don’t mind 4 cylinder mode when cruising on the highway though. Then I just go to My Mode.
Old Jun 17, 2025 | 07:38 AM
Paleblue's Avatar
Paleblue
From: Basking under the neon lights, sipping on rye whiskey
Wrong thread....
Old Jun 17, 2025 | 10:35 AM
Orion2011's Avatar
Orion2011
Manual mode, track mode or Z mode with the track mode settings. I did see where someone has an OBD plug coming out that might do it. Forgot the name though.
Old Jun 18, 2025 | 03:35 PM
Uncle Pasko 73's Avatar
Uncle Pasko 73
I think it was Hawking who concluded that time travel is not possible because if it was we would have been visited by people from the future.
Old Jun 18, 2025 | 03:58 PM
Wadejesu's Avatar
Wadejesu
Unlock ECM and get a HPtuner
Old Jun 19, 2025 | 09:57 PM
Red Mist Rulz's Avatar
Red Mist Rulz
https://www.corvetteforum.com/forums...m-disable.html
Way cheaper than a tune:
https://www.obdlink.com/products/carbyte/
To Keeping C8 on All * ALL the Time
