Sponsored by: CARiD
Transmission shift noise
Old Jan 19, 2023 | 06:17 PM
JCALD's Avatar
JCALD
Default Transmission shift noise
Under very light load and just before the transmission actually shifts, is it common to hear what I think are the clutch actuators? Kind of a metallic clink and scrape.
Old Jan 19, 2023 | 11:01 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
AFM valves can make the noise you described. Try putting it in Z mode or track that should keep the afm valves open. See if the noise is still present.
Old Jan 21, 2023 | 10:17 PM
Andybump's Avatar
Andybump
That is a good recommendation. The AFM valves close when the engine transitions to V4 mode. To keep it out of V4 mode, the engine/shift setting has to be set to track (or Manual shift mode). That happens in Track Drive mode. In Z-Mode, the engine/shift setting can be operator selected. I think the engine/shift may default to Sport Mode (not certain). But, if the engine/shift setting is Sport, or any setting besides Track, the engine can go into V4 mode. I have heard (rarely) the AFM valves open and close. And I have also heard the tailpipe valves open and close with,squeak or a metallic sound. I have not noticed that sound at shift points though.
Old Jan 21, 2023 | 11:05 PM
JCALD's Avatar
JCALD
I gave Z MODE a try and the noise is still present. I have service scheduled next week. Maybe they can clear this up for me.
Old Jan 23, 2023 | 09:28 AM
Cicio Performance's Avatar
Cicio Performance
Supporting Vendor
We have seen solenoids in the trans stick which can cause issues and make sounds but if the car is driving good then that shouldn't be an issue.
Has the car been launched before?
Andrew
__________________
Cicio Performance Website
Old Jan 23, 2023 | 03:19 PM
JCALD's Avatar
JCALD
I am waiting until 1500 miles before playing with launch control.
Old Jan 26, 2023 | 08:48 AM
JCALD's Avatar
JCALD
After a dealer visit and having one of the transmission techs take a ride, it turns out to be one or both of the exhaust system valves when it goes from 8 to 4 mode under very light acceleration.
Old Dec 15, 2023 | 02:17 PM
vetteguy2019's Avatar
vetteguy2019
Mine does the same thing when downshifting so is it normal?
To Transmission shift noise
