Sponsored by: CARiD
Engine Light Code P12EA
Old May 9, 2023 | 03:02 PM
dahogan's Avatar
dahogan
Enjoy while you can.
Ohio Events Coordinator
2025 Corvette of the Year Winner - Unmodified
St. Jude Donor '14 thru '26
Default Engine Light Code P12EA
Cylinder Deactivation Exhaust Control Valve, Position Signal Exceeds Upper Limit.
They cant get to it for 7 weeks and said it was ok to drive it but dont track it Sound right to you guys?
Old May 10, 2023 | 11:44 AM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
The "can't get to it for 7 weeks" part sure doesn't sound right. Driving it is probably OK as long as AFM valve is not stuck closed (not sure what that position error actually means).
Old May 10, 2023 | 12:09 PM
dahogan's Avatar
dahogan
Their main mechanic is off for several weeks. I called another dealer close by, I am in this Monday. They too, said it was safe to drive.
Old May 16, 2023 | 01:30 PM
dahogan's Avatar
dahogan
They were able to get the exhaust value working again, so they decided not to order a new one.
Old May 16, 2023 | 01:39 PM
Kracka's Avatar
Kracka
Probably just needed a relearn procedure performed, is my guess. What does your paperwork state?
Old May 16, 2023 | 02:46 PM
dahogan's Avatar
dahogan
Examination found the left exhaust flow control valve cylinder deactivation was out of specifications. They performed the left exhaust flow control valve reset which did the trick.
Old May 25, 2023 | 06:34 AM
mrsuds's Avatar
mrsuds
just order this scanner from Amazon. I had the same issue after Corsa exhaust install. This has the relearn feature you need. Good luck scanner is the Creader Elite with GM software.
To Engine Light Code P12EA
