Sponsored by: CARiD
TPMS Training
Old May 24, 2023 | 07:14 AM
jthornton's Avatar
jthornton
Default TPMS Training
On my C5 I've tried a variety of magnets to train the TPMS with a rather large horseshoe magnet the only one that worked well. I assume the C8 is the same that you use a magnet to train when you swap wheels and tires out or change a sensor with a dead battery?
What is the best magnet to use?
How do you initiate the training?
JT
Old May 24, 2023 | 07:52 AM
RandelB's Avatar
RandelB
Default Rtfm
From page 270, 2022 owner's manual (it's in the glovebox)
Old May 24, 2023 | 08:10 AM
jthornton's Avatar
jthornton
Thanks, that looks much easier.
My glovebox is still on the shelf at Bowling Green...
JT
Old May 24, 2023 | 01:11 PM
bhvrdr's Avatar
bhvrdr
JT
Can download them from general motors free of charge if you want to get ahead of the game
Old May 24, 2023 | 01:22 PM
jthornton's Avatar
jthornton
@bhvrdr Thanks, got it.
JT
Old May 24, 2023 | 09:21 PM
NoMatter's Avatar
NoMatter
What’s Next
Just order this. I’ve used it for a year dozens of times. Works great. Cheap.
Yes the system can relearn itself but takes to long. I swap wheels often so it’s more convenient when I need to know pressures quickly. The relearn process is in Dic options for using this tool. Your call.
Old May 25, 2023 | 12:20 AM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
Unless you're in a real hurry there is no re-learn tool needed for the C8 and no need to do the relearn in the menu system either. When installing new wheels/sensors or rotating the old ones simply drive the car normally for a few miles after installation. It will learn the new sensors - or the new position of the old ones - all by itself. Same goes for having the battery disconnected.
Old Aug 9, 2023 | 07:02 PM
RafGTS's Avatar
RafGTS
The auto-learning process on the C8 takes way too long if you change between the wheel sets often so I bought the above tool as well. It works great and I don't have to wait for the TPMS to be functional.
Old Aug 9, 2023 | 08:33 PM
wrecker3's Avatar
wrecker3
C8 Manual Link.
https://www.chevrolet.com/bypass/pcf...22AUG01_2P.pdf
Old Aug 10, 2023 | 08:54 AM
pettvette's Avatar
pettvette
CI 5-6-7-8-9-10-11 Vet
Takes too Long?? I have 3 sets of wheels I switch out,,, Drive less than 2 miles and their reset...
Old Aug 10, 2023 | 12:44 PM
bhvrdr's Avatar
bhvrdr
That's been my experience. Very fast. I also have multiple sets of wheels and tires mounted I swap often (summers, all seasons and two track sets)
To TPMS Training
