Sponsored by: CARiD
C8 Z51 Track setup questions
Old Jun 29, 2023 | 03:24 PM
PThai72's Avatar
PThai72
Default C8 Z51 Track setup questions
Hi, I'm new to the Corvette. Wondering what you guys use for tires and brakes in a Stingray Z51 track setup?
Brakes: I want to still stick with stock Z51 calipers for now but considering the Girodisc rotors and not sure what pads would be good for the track (like a Pagid Yellow but without the squeal if possible).
Wheel/Tires: What tires would be good for the track with the stock wheel 19/20" wheels? Cup2s? How about 19/19" or 18/19" wheels and tires? - stock suspension with maybe track alignment setup.
Thanks in advance.
Paul
Old Jun 29, 2023 | 08:38 PM
Tommygunn5645's Avatar
Tommygunn5645
I would say a lot depends on your track experience. If you have little or none, I would say just do the recommended track prep and let her rip. The PS4’s are just fine if you’re new to the track. The Goodyear eagle F1 supercars are a really good alternative for the stock wheels. I also have a set of 18/19’s that open up more tire choices. I actually like the stock break pads. The go quick, but you can pick them up used for next to nothing.
Old Jun 29, 2023 | 08:53 PM
PThai72's Avatar
PThai72
Thanks. I'm an instructor for HPDE events and have tracked with Porsches but not with Corvettes. I usually do some sort of enduro track pad like Pagid Yellows with Nitto NT01's or Toyo R888R and stock calipers and wheels. Since I'm just getting into Corvettes, I'm wanting to stay with stock gear for the most part and start with track pads and tires. Looking for pad and tire options for the stock caliper and wheels. I'm willing to go smaller wheels like 18/19's as well and wondering what tire options fill fit a stock C8.
Old Jun 29, 2023 | 09:46 PM
jwr9152's Avatar
jwr9152
You got Goodyear Supercar 3 and 3R and Michelin Sport Cup 2 and the Nankang CRS1
Old Jun 29, 2023 | 09:59 PM
allblackeverything's Avatar
allblackeverything
Yourself a favor and learn from us who have been there done that.
the Girodisc are worth the money.
I’m a fan of the Gloc pads. I run R16 fronts and R10 rear compound.
switch your brake fluid out for Motul RBF 600+ or Castrol
As far as the wheel/tire choice.
I’m running 18” wheels
18x10 and 18x12.
less weight and tires are slightly cheaper.
I’m running Falken RT660 but my next set with be the Nankang AR10
also the MCS suspension is worth every penny.
If I were to do it all over again I would just bite the bullet and buy the AP system
Old Jun 29, 2023 | 10:08 PM
MistressMotorsports's Avatar
MistressMotorsports
Your favorite track pad with stock calipers should be fine. Girodisc rotors are helpful but probably not necessary if you are good with brakes.. That said, some people (including me) have experienced fairly severe brake shudder with certain pad compounds, there is a thread on this in this section of the forum. I was able to eliminate the shudder by using Cobalt pads, but there are a ton of opinions, some contradictory on what the best pads that don't shudder are. Pads that shudder for one person don't for another.
In addition to the tires listed above, the Nankang AR1 is also available and usually in stock. Going to 18/18 or 18/19 will open up more tire options. With an 18 inch rear wheel, you may need to pay attention to suspension clearance as the suspension travels through its range, so 19's are a bit safer. C8s don't feel like Porsches on the track, they are their own animal. Torquey, fast, and fun. They do reward precision and smooth, deliberate inputs.
Old Jun 29, 2023 | 10:30 PM
PThai72's Avatar
PThai72
Good advice! That's why I asked you guys! What would you do if you were starting out? But within reason and not spending Z06 money to trick a stingray out.
Old Jun 29, 2023 | 10:35 PM
PThai72's Avatar
PThai72
How about tire widths? Front 275/35-18 // Rear 325/30-19?
Old Jun 29, 2023 | 10:39 PM
allblackeverything
I would spend my money on a set of 18” wheels, girodisc front rotors, and the MCS 2way non remotes.
a forum member has a set of MCS Coilovers for sale for cheap.
Also, consider a seat, harnesses and a harness bar
Old Jun 29, 2023 | 10:45 PM
PThai72's Avatar
PThai72
Working on the harness bar as well. Thinking the Paragon harness bar. Just need to source out the plastic trim pieces that need to be cut and getting those parts.
18/19" wheel setup seem like the safest bet without having to commit to coilover suspension for clearance?
Old Jun 30, 2023 | 11:33 AM
BruceV's Avatar
BruceV
This thread really interests me. I have zero track experience with a Corvette - for that matter I've only been on track in a car 2 times. One of those times I did have an instructor in the car with me. My car is several months away from delivery - getting a 3 LT Z51 coupe. I have every intention of doing track days with it, but it will not be a dedicated track car.
My problem is how to set it up - being realistic in regard to my experience. Here's my situation - I've been on race tracks hundreds of times, thousands and thousands of miles - all of it on two wheels. So I certainly have track experience - kind of sorta of.
Where should I start?
Here's a video at Barber I took. This is a typical session, you will see I'm pretty conservative - I don't make questionable passes, if I can't clearly see an easy safe pass I lay back and wait for a better opportunity. I have to think with my car I will be even more conservative.
Old Jun 30, 2023 | 11:39 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Carbotech makes various track compounds but with out a tire its hard to say what will work best for you. I would choose a tire than go to pads. Here is a compound guide. Carbotech Brake Compounds – Amp'd Autosport (ampdautosport.com)
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Jun 30, 2023 | 03:05 PM
WHPLASH's Avatar
WHPLASH
https://www.youtube.com/watch?v=iO_hsIEiuJo
When you pick up your amazing C8, I highly recommend the Ron Fellows C8 Driving School in Spring Mountain, NV. If you go within your first year of ownership, it costs only $1k for 2 days of learning and driving this great piece of machinery. Many of us have done it, but non of us regret going.
Have fun with the new toy!!!
Old Jun 30, 2023 | 04:10 PM
PThai72's Avatar
PThai72
Wow! That's awesome. I don't have the ***** to track on 2 wheels. Sticking with 4 wheels.
Old Jun 30, 2023 | 04:11 PM
PThai72's Avatar
PThai72
I've heard Ferodo 3.12 and now Carbotechs. I'm thinking tires like Toyo R888R or Hoosier R7's.
Old Jun 30, 2023 | 04:50 PM
BruceV's Avatar
BruceV
I will do the RF school for sure. I'm not so concerned with track rules and understanding brake markers, reference points, apexes and all that. I honestly have zero experience on setting up a car for track days - especially a car that I'm not dedicating to track only. l really think I'm going to purchase a set of wheels and tires for the track, along with pads and rotors. I have access to a lift so swapping the brakes and wheels is not a big deal, plus I might do 4 - 6 track days a season.
Old Jun 30, 2023 | 04:58 PM
BruceV's Avatar
BruceV
I've been riding bikes for 55 years I was 10 or 11 when my dad bought me my first mini bike. Going fast is a lot of fun, going fast and doing it well is another thing. The car is going to be a completely new experience, from my 2 times driving on track in a car, I can tell you, I'm making no mistake about this, I basically sucked in the car - brake markers - backing it in to the corners, well everything I did poorly, I tried driving the car like it was a bike - didn't work out so well.
To C8 Z51 Track setup questions
Old Jun 30, 2023 | 09:10 PM
allblackeverything
I too had never tracked a car but spent the last 8 years coaching for STT and racing with WERA.
the C8 is tons of fun on track but IMO not in stock form.
but just like I’m sure you are aware from the motorcycle world. Suspension is worth every penny.
The MCS suspension was an absolute game changer for me.
I ran my PB a the other day at Road Atlanta of a 1:36.5
time for me to add some aero!
Old Jun 30, 2023 | 11:53 PM
BruceV's Avatar
BruceV
You are 100% correct suspension is a game changer at the track. I didn't struggle with setting up my bikes, they are all dedicated track bikes and will never be street legal.
My dilemma is trying to find a setup that works both on the street and track - I'm mostly driving it on the street with the goal of going to the track a handful of times a season to let it rip without worrying about getting hurt or hurting anyone and of course going to jail.
Old Jun 30, 2023 | 11:56 PM
BruceV's Avatar
BruceV
