You are 100% correct suspension is a game changer at the track. I didn't struggle with setting up my bikes, they are all dedicated track bikes and will never be street legal.
My dilemma is trying to find a setup that works both on the street and track - I'm mostly driving it on the street with the goal of going to the track a handful of times a season to let it rip without worrying about getting hurt or hurting anyone and of course going to jail.
honestly for the few times I’ve driven on the street with the MCS. Sometimes I drive to the track (don’t tell on me)
the ride isn’t all that bad if you dial the compression out after your track day.
In the GM Track Preparations document it states the J55, J56 and J57 brake systems require a specific process for flushing the brake system. They reference the service manual. Does anyone have a copy of this procedure?
I know the system must be bleed with the battery disconnected. Any thing else? I use a pressure bleeder.
J
I know the system must be bleed with the battery disconcerted. Any thing else? I use a pressure bleeder.
J
I use a pressure bleeder as well. I'm guessing you have to have the car cycle through the ABS to get every bit of the old fluid out. If you do frequent changes probably doesn't matter? I'd like to know the way to cycle the ABS as well if anyone knows?
J
Other than disconnecting the battery there's nothing special required. The old school 2-person method works just fine so I've never needed/used a pressure bleeder. IF you're concerned with residual fluid in the ABS module you could do the initial flush, hit ABS a few times and then re-bleed. I didn't bother and have had zero issues. I do a bleed with every pad change so by now any of that residual is looooong gone.
One minor annoyance -- SRF is nearly transparent so it's difficult to see the level in the master cylinder so you have to be extra judicious about keeping it topped off when bleeding.
Also of note, filling the brake fluid reservoir is the slowest process ever in this car. 90% of my brake flush using the pressure bleeder was spent filling the fluid lol.
I have always avoided pouring brake fluid into my motive pressure bleeder to keep the seals fresh, but next time I’m just going to pour it in and make sure I clean the motive out well after.
I didn't see an update after this one, I've used the pressure bleeder both ways and can say it isn't possible to flush the pressure tank well enough if brake fluid is introduced. It is better to keep it dry and put up with keeping the master cylinder topped up between calipers. I also only pressurize between 5 and 7 psi.
Same here, too; always kept it dry. I keep it between 10-15 PSI, and it worked well. With the addiitonal pressure, things 'happen' quicker : )
If you need to quickly flush the reservoir, you can always start from one of the fronts, which flow faster. Due to baffling inside, it's no longer easy to empty the reservoir with a syringe, etc.
"If you need to quickly flush the reservoir, you can always start from one of the fronts, which flow faster. Due to baffling inside, it's no longer easy to empty the reservoir with a syringe, etc."
Good point! I have a professional grade mity vac hand operated vacuum pump that makes simple work of emptying the master a relatively easy task, though you really can't empty it as it has two chambers and impossible to get to the second chamber.
I think you'll find great comfort in going from 2 wheels to 4 wheels. I got out of tracking bikes when friends were getting hurt and I didn't want to risk my career. It's been cars ever since.
I'm fairly new to the C8 and tracking as well. I've driven a few on track. Some with track alignment and some still with the street alignment.
My suggestion is to try it straight out of the box and get climatized to the car. Decide from there what you're going to need to start lowering lap times etc. Your home track will also play a part in what you're going to need. For me I noticed that brakes were first on the list followed quickly by tires. I went from a highly modified C5 to the C8. It's been quite an adjustment.
When you pick up your amazing C8, I highly recommend the Ron Fellows C8 Driving School in Spring Mountain, NV. If you go within your first year of ownership, it costs only $1k for 2 days of learning and driving this great piece of machinery. Many of us have done it, but non of us regret going.
Have fun with the new toy!!!
I took the Ron Fellows Drive School last April in a Blackwing Cadillac. I highly recommend it as well. Excellent facility and top notch instruction. Having them teach you the limits of the car will help make you better on track, but most importantly make you safer on the road.
Do you happen to sell a package for C8 Z51 that would allow me to use carbon rotors and brake pads? If so, how much is the package? It's one of the first upgrades I want to make. Thanks so much for your time.
I am getting a Z51 soon. I want to do the Ron Fellows school. Does anyone do a school like this without a “track alignment”? I mean tire wear with this alignment makes it impractical to drive the car on the road? I’m reading the track alignments are involved and not cheap. Can you do light track driving with the stock alignment and still have fun and learn about the car?
About the only time alignments become expensive is when you convert to camber plates, its very time consuming process. Most of the tire wear comes from toe settings, not camber. You won't notice a "track alignment" driving the car on the street, for dual use be careful of the amount of toe that is set. Some folks go to the extent of changing toe setting before and after their track sessions. You could also work with the alignment tech to determine how much the tie rod ends have to be turned to achieve the toe you want for the track v.s. a street setting and do it yourself.
Actually, C5Racr1 makes a great point because as a novice you do not want to go much faster than 6/10's. Better (and safer) to learn how to drive the track first.
How many street miles would you guess you'd be driving? Is the car a "daily"?
I've done around 4500 miles with track alignment with no issues. It's a bit "darty" on rutted roads but nothing significant. My alignment from the dealer was under $300.
You can absolutely enjoy the car with the oem alignment. It's still going to be great especially if you're a novice.
Don't over think it. It's easy to do with all of the info that comes at someone from online sources.
The biggest thing that I found I really needed to do first was brake pads. I left the driver aids all on at first which uses the brakes a lot so heat was an issue. I threw on a set of Hawk DTC 6.0s and I've been very happy with them on street and track. Got them off of Amazon
