Sponsored by: CARiD
HP Tuning on E85
Old Jul 19, 2023 | 05:24 PM
combatninja's Avatar
combatninja
Default HP Tuning on E85
If you don't feel like wasting 10 minutes, the car has Eventuri intake, Ligenfelter PTR carbon intake w/throttle body, Paragon headers & Paragon exhaust. No tune, it put down a pitiful 437whp on 91. Tuned for 91 it put down 451. Tuned with 93 it put down 465. E85 tuned put down 500. Kinda......disappointing to be honest. The startling number is the tuned 93 number of 465 with all those bolt ons. That seriously sucks. I'd be expecting that number or better with no tuning at all. What they neglected to get was just the number on 93 with stock tuning, which would've been interesting. Until I see something revolutionary, I think that tuning is a waste of time until you are into a cam and/or headwork.
I'd estimate that to replicate that build you'd be looking at $13,000-$14,000 at retail prices. Um, that's a hard 'no' from me, dawg.
Old Jul 19, 2023 | 05:50 PM
Fore58's Avatar
Fore58
Just wondering what was the results bonestock? At least we know what the tune made. I just think one of those bolt-ons is unnecessary. And I'm going with the Lingenfelter PTR.
Old Jul 19, 2023 | 06:00 PM
bhvrdr's Avatar
bhvrdr
They did not report the 93 numbers they dynod at the last session either. Be nice to see just to see how the variance is since they don't use SAE temp correction but instead Standard on this one and uncertain on the last one.
Regardless it's exactly what we see already in the top 1/4 mile folks.
Those running top bolt on times are trapping 128 to 131mph in great air.
They would be running 123mph-124mph or so absolutely bone stock in great air.
In order to pick up 6- 7mph in trap speed they run
drag packs = 1.5mph
200lb weight loss = 1.5mph
E30 to e85 = 2mph
The bolt ons = 1.5mph-2mph
Not a ton of power from them. Cams is what you'd need for that.
Old Jul 19, 2023 | 07:00 PM
combatninja
I'm waiting until I see what the tuned results are from cams and headwork. Katech is 'claiming' 565hp, so if the numbers are there I might take the plunge. That 565 crank should be right around that 500whp mark and then if you could have an E85 tune to go with it, you might see 550whp? Maybe? I'll see how it shakes out but the gearing is so miserable in these cars that it almost makes no difference unless the TCU encryption is cracked and we can do something with the gearing.
Old Jul 19, 2023 | 07:19 PM
bhvrdr's Avatar
bhvrdr
I agree. Cam may be worth tuning for. If I'm going to completely kill the powertrain warranty I just want it to be worth the gains.
Old Jul 19, 2023 | 08:58 PM
combatninja
I just don't see it as a worthwhile endeavor to muck around with warranty to gain 50hp that is only going to make gears 1-3 that much harder to manage from a traction perspective and then have it still fall on its face in 4th. It is pretty much down to giving this car +100hp or it really makes no practical difference in the real world.
Old Jul 19, 2023 | 10:16 PM
c5racr1's Avatar
c5racr1
so you are saying you would pass on 60 Hp from a tune.....and some fuel.....
ok.............some E85 and a tune they got 60 hp in the heat from a tune and some fuel. Ok
Old Jul 19, 2023 | 11:58 PM
123sugey's Avatar
123sugey
Dig
It would be very interesting to see trans gears swap and TCU tune. AND what that alone would do on stock car. And would love to see that with a bolt on and power adder car
Old Jul 20, 2023 | 10:11 AM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
Originally Posted by c5racr1
so you are saying you would pass on 60 Hp from a tune.....and some E85
Yes a, because it voids the warranty. I’ve modified all of my previous 9 Corvettes, but it’s just not worth it on the C8 with the trans failures. I don’t think the failure rate is really as bad as many make it out to be, but even if it’s 1%, that’s still a decent risk as opposed to previous manual transmission cars.
Old Jul 20, 2023 | 10:25 AM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
I dunno, 60hp from a tune and some fuel is a pretty good gain... especially considering all these folks claimed the factory maxed out the tune and there was no power to be had. This clearly isn't for anyone that cares about a warranty, I get that... but most of the people who are going to do this dont care about a warranty... if its not for you its not for you but hard to say its not impressive. Also their just getting started on these things... I expect we'll be seeing alot more things as people get them figured out. Once they get the DCT tuning unlocked ittl really change the game.
Old Jul 20, 2023 | 10:49 AM
bhvrdr's Avatar
bhvrdr
It should be clarified the tune doesn't give 60hp.
On the same 91 octane fuel it supposedly gave them about 15hp... which I'd take with a grain of salt because you could reset the ECU that had defaulted to safety timing tables due to crap fuel and pick up that same 15hp.
But tuning for e85 is worth around 25hp to 35hp over 93 octane with no tune. It could be worth a ton more over some of the crap west coast 91 but that's irrelevant as that fuel is junk
93 octane and zero tune will get you 22 degrees of timing.
E85 with tune may very well be in the 28 to 32 degree range
That's a solid and real gain of 25 to 30hp
Old Jul 20, 2023 | 11:48 AM
PhoenixM3's Avatar
PhoenixM3
https://www.youtube.com/watch?v=FeEi...5jZSBjOA%3D%3D
It may be that expensive if you can't do it yourself, but cheaper intake, throttle body, and headers go for around $3K. Add $2K to unlock the ECU, and perhaps $1k for E85 tune to get to 500WHP from stock is not terrible.
Old Jul 20, 2023 | 05:01 PM
combatninja
You're missing a lot here. We are not talking about 60hp from a tune. The car has $13-14,000 dollars of other bits bolted to it. So, yeah, I'd pass on spending that kind of money for those gains. That's worse value for money than these underperforming blowers. They may cost $30,000 but at least they are +150hp at the lower end.
Old Jul 20, 2023 | 05:05 PM
combatninja
The prices I quoted absolutely presuppose a DIY install. Those are straight retail prices for the bits before tax or install. The build is the build. I'm not going to sit here and cherry pick the cheapest analogous part available for each and quote some low number. That is what they had on their dyno. Not my build, just reporting the facts.
Old Jul 20, 2023 | 06:06 PM
Fore58's Avatar
Fore58
Let's subtract at least 25 rwhp from the initial bolt-ons going back to bonestock supposedly.......seems like it would be around 90 rwhp total instead of 60. Does that make sense? Head and cam with a tune alone makes between 40 and 70 rwhp from my own experience. So a c8 head and cam with tune would cost a little more than the complete bolt-ons with matching rwhp. I have had head/cam cars. And if you select a right cam, the car could be a beast.
You could save tons of money by DIY. Then all you are left with is tuning if preferable. Just my. 02
Old Jul 20, 2023 | 07:40 PM
c5racr1's Avatar
c5racr1
HCI 6-gen camaros' with the right combo will put down 680 RWHP with the right combination. It kinda depends on how far you want to go. If you are concerned about the warranty don't do anything that would void it.
Old Jul 21, 2023 | 08:12 AM
PhoenixM3's Avatar
PhoenixM3
I may just unlock the ECU after I get the bolt-ons installed. Probably won’t go FI route, but do like the E85/flex fuel route and think I’d be happy with 500whp.
To HP Tuning on E85
Old Jul 21, 2023 | 08:19 AM
PhoenixM3's Avatar
PhoenixM3
My fact is that it doesn’t have to be a $13-$14k upgrade. I was quoted $18k for Procharger installation, so I agree that the bolt-on and tune isn’t cheap.
Old Jul 21, 2023 | 04:55 PM
combatninja
At those kind of prices, I'd sooner go with a real NA build. Something like the heads/cam pack that Katech is advertising. Claimed 565hp with a tune for $14,995. That thing might do 600crank with E85? We've all been buying $5,000 exhausts for so long waiting for tuning that we've lost our minds when it comes to pricing for go-fast parts. They got us.
Old Jul 21, 2023 | 05:47 PM
Laramide's Avatar
Laramide
2nd Gear
Why don't they use a bone stock C8 for the comparison? I couldn't help thinking of the claimed HP increases from each of the vendors selling the expensive individual bolt-ons listed only to get to 437 rwhp on 91 octane.
