Sponsored by: CARiD
Cicio Performance
Old Aug 17, 2023 | 10:50 AM
Cicio Performance's Avatar
Cicio Performance
Supporting Vendor
Default Cicio Performance - C900 + Texas Speed V2 Turbo Cam!
Fresh out of the shop at our Georgia location is this gorgeous C900 package C8 with our first TexasSpeed - V2 Turbo Cam, including our very own in house made DOD delete and custom spec Pushrods.
While a cam in a Corvette is nothing new, combined with the Cicio Performance ETS Turbo kit the Precision 6466 whistle really gives it that sinister ghoulish sound! Absolutely a match made in heaven (or would that be hell?).
This C900 was tuned in house using HP Tuners.
For any specifics on this Build or the C900 Package (or any other of our C8 offerings) please reach out!
~Parker @ Cicio Performance
Old Aug 17, 2023 | 03:42 PM
combatninja's Avatar
combatninja
What does she rev to?
Old Aug 17, 2023 | 03:51 PM
Cicio Performance
Supporting Vendor
Redline is currently set to 7,000 RPM.
Old Aug 17, 2023 | 04:28 PM
combatninja
Tasty. I need 7200 out of my NA build.
Old Aug 17, 2023 | 04:44 PM
Cicio Performance
Supporting Vendor
7,200 is do-able on an N/A build, when you start throwing boost into the mix things are a little different with valve spring tension and possible float. This particular C900 does have upgraded valve springs as a byproduct of doing the cam installation.
Old Aug 17, 2023 | 05:04 PM
combatninja
For sure. I'm looking to build a stock displacement LT2 that will rev to 7200ish and make good power up to at least 6600 or so. Ported heads, mild cam, built valve train, and good headers should be able to make 520whp on ethanol with good tuning. When do you guys crack into your first NA build? Getting excited to see what the heads and cams can do on LT2s.
Old Aug 17, 2023 | 05:31 PM
Cicio Performance
Supporting Vendor
We've actually got an NA build about to be finished up in our Virginia location, Headers, Hi-flow cats, Catback, Cam, the works!
~Parker @ Cicio Performance.
Old Aug 17, 2023 | 07:40 PM
combatninja
No porting of heads or bump in compression? I have a theory that the exhaust side of the LT2 is pretty efficient and owners can save thousands and thousands of dollars by leaving it intact and putting that money where it matters more. I'm just waiting for a few to be built to work out all the teething problems but I'll gladly write a check to a shop I have confidence in to build it.
Old Aug 18, 2023 | 08:24 AM
Cicio Performance
Supporting Vendor
Nope! No head work nor change in compression. Just some good ole' bolt-ons and a cam with supporting mods (valvesprings, lifters, pushrods etc.)
To Cicio Performance
