Success! It was damp and cool with traffic so I could not do much "testing".
I did a 1st gear test rolling on the throttle until 7200k and shifting but it worked.
I can hit 40mph in first vs 35mph now... lol! (Little pdr clip linked below.) RPM Test
can you check your hp tuners version used and if it's beta or not?
Pretty sure its recommended to always use the beta version especially for c8. Im guessing even with no horsepower increase, the increased redline will result in faster times.
I definitely will being the way revving out 3rd will set you up for 4th and you won't run out of gear before the 1/4mile traps on 4th with a 7100rpm limit on a stock or even modestly modded N/A motor
TCU restrictions or lack of tuning has single-handedly stopped me from taking the C8 seriously as a potential vehicle for me in the future. This is all good news but, I would certainly prefer direct tuning of the TCU or even a complete replacement of the module itself for the sake of tuning.
You can tune the thing until the cows come home but what it needs is a new 1:1 4th gear, the old 0.85:1 4th can be the new 5th, etc. These are OHV truck engines, not sure revs are really the answer. Keep in mind there are also tuners that don't like to mess with increasing the redline even in M mode because they are trying to protect the transmission. I imagine they have encountered some drivability weirdness when they tried it. I'm all about the cammed cars revving to 7000 but nothing but a new gear set is going to make these cars even remotely 'fast'.
You would think with all the technology and resources we have today in the aftermarket industry an alternative gear set for these DCT's were already made....
It will be but its absolutely useless without being able to tune the tcm. The real question to me about all this is how can the rest of the car be designed so well but the geniuses who designed the gearing ratios never seemed to understand the engines power curve for them to be utilized effectively? 4th to 6th are horrible for it's power and it even seems the z06 suffers considering it's Ring time around the track.
If it's anything like the C7, that car absolutely does not like a change in gear ratios. There was a forum member on here who swapped his M7 from his GS to a Z06 M7 and tried to use HPTuners to change the gear ratios in the tune. He, as far as I can tell, was never able to get the car to act right (rev match, NLS). I had a really long conversation with several transmission shops back when I had my C7Z with the A8 about changing some of the gear ratios and the conclusion was the same. I could physically get it accomplished but, the vehicle would not like it at all.
Perhaps a standalone option could be explored for just the TCU?
I think a stand alone could definitely and easily be made and programmed to handle the DCT, my concern would be how would the canbus linking it to ALL the other computer systems of the car handle it?
It seem to me the best options out there so far to help mitigate this issue quite a bit is just to TT your motor or bolt in a positive displacement blower. They fatten the torque curve of the motor significantly and independently of the revs, making the low ratios of 4th and 5th not 'as much' of an issue.
Seeing that the engineering team at GM had drawn up the design for the TT ZR1 first and worked backwards with the intro of the stingrays then Z06 before it's release, I'm pretty sure the ratios mate up with the 1000HP Turbo ZR1 motor nicely..
Yep. One gear set for the full range. I'm sure the engineers argued for it but accounting shut them down. Keep in mind that this car launched with a $59,990 base MSRP. There needed to be compromises. A lot of compromises.
thanks for the update but yeah this is very exciting to see some some progress.
Does anyone on here have a relationship with Alex Peitz or had work done with him to get a more detailed account on exactly where they are with their new "redline increase" release?
Cautious optimism here. Wondering what a proper head and cam car can make being able to rev safely to 7000-7100? 600whp is maybe in the cards with enough airflow mods to both intake and exhaust. NA C8s will break into the mid-10s if so.
X 2... there are many compromises in the engineering of the current stock of cam/head packages currently available to accommodate the factory rev limit. Stretching it to say 7200RPMS opens a world in that department. Particularly if you add in E85, I believe 600RWHP will be the gold standard for N/A, stock bottom end cars once they sort it all out.
Reliable redline increase has (or had) to be demonstrated first before they start building custom cams/ heads,runnners,etc around it...
C4 of Year Winner (performance mods) 2019
Originally Posted by combatninja
I also wonder how they'll get around the display limit on the cluster? Maybe the HUD will be able to display actual RPM?
If it's auto shifting, it wouldn't matter. But for manual mode, you can actually get the tach to show numerical in some modes, although it's going to be hard to time a shift based on that. I'd either shift at 7K or add a separate shift light. I had a small red led shift light in the AC vent on one of my C4 ZR-1s, and it was perfect, when it lit, I didn't even think about it, I just shifted reactively. Had a 7400RPM rev limit and the shift light set at 7200, never once hit the rev limiter when relying on that light.
Good point, that'd be annoying as heck to me. And the idea of a shift light brings me back to the Ol' Fox Body Mustang days where the kids in them loud BS 13-sec cars had the bright *** HUGE yellow aftermarket tach light just off to the side of their steering column, literally a driving hazard how bright and big they were LOL
Can the digital tach be reprogrammed to extend it's markings to 7500 and redline to 7000? Anyone THAT good?
