Sponsored by: CARiD
C8Z Valve Tick
Old Nov 21, 2023 | 11:20 AM
GatorsJMC's Avatar
GatorsJMC
Default C8Z Valve Tick
Currently 850 miles and have developed a noticeable valve tap at idle. Can't hear it above idle,- exhaust drownes it out.
NCM delivery and almost afraid to have a local dealer's tech address the issue and "learn" on my car.
Open to solutions before any component damage...
Old Nov 21, 2023 | 12:17 PM
ShibaZ06's Avatar
ShibaZ06
Is it the loud tick / same as the videos or the normal sewing machine tick of the hpfp on the drivers side mostly?
D
Old Nov 21, 2023 | 01:55 PM
rwwlaw24's Avatar
rwwlaw24
Injector noise. Normal
Old Nov 21, 2023 | 07:46 PM
GatorsJMC's Avatar
GatorsJMC
D
It is loud- video?
Didn't realize injectors could sound like a loose tappet/ rocker follower
Old Nov 21, 2023 | 08:19 PM
GatorsJMC's Avatar
GatorsJMC
Apparently there is a GM service bulliten that can require engine removal. Not funny
Old Nov 22, 2023 | 06:49 PM
Ragtop 99's Avatar
Ragtop 99
There are a couple big threads in the Z06/ZR-1 forum on this issue. Search for ticking.
Put your car exhaust in stealth and see if you hear it in the higher rpms. Finally there is a TSB on this. They do a picoscope recording to determine if the problem is there. If they determine there is a problem, you decide whether you want to fix it or leave it as is.
These cars do have a lot of mechanical noise; much more than the stingray and the C7.
Old Nov 22, 2023 | 08:44 PM
GatorsJMC's Avatar
GatorsJMC
Copy that,- Thanks!
Old Dec 27, 2023 | 09:56 PM
GatorsJMC's Avatar
GatorsJMC
So, had the local dealer do the TSB work for a minimal improvement in the cam/ follower/ valve tick, coming from the left bank. Before & after pico scope prints did show an improvement, but not much. Looks like it's there to stay, just not as pronounced as before.
Old Dec 29, 2023 | 09:31 PM
Ragtop 99's Avatar
Ragtop 99
That's disappointing to hear for all that work, the improvement was minimal.
Old Jan 5, 2024 | 07:26 PM
Habu08's Avatar
Habu08
Mine has been at the dealership for a few days with a ticking noise issue, and a couple fault codes. ECM and Knock Sensor.
The service manager called me today and said GM told him to pull the motor. They will be tearing into it Monday. It’s a 2023 with 6500 miles on it.
I’ll post what they figure out when I get it back.
Old Jan 5, 2024 | 11:56 PM
Mitchell_B's Avatar
Mitchell_B
The ticking developed suddenly or gradually over time?
Old Jan 6, 2024 | 08:52 PM
Habu08's Avatar
Habu08
The ticking noise had been going on for a while. Everyone I talked to about it said it was normal injector noise. I took it in for the check engine light, and apparently the noise was not normal.
Old Jan 9, 2024 | 02:18 PM
Rapid Z's Avatar
Rapid Z
I understand some earlier 2023s have this issue there is a TSB on it. As I recall the fix has something to do with mis aligned cam shaft caps.
Old Jan 9, 2024 | 09:27 PM
Habu08's Avatar
Habu08
I just passed that info on to the service manager when I checked on my car today. Thanks.
Old Jan 10, 2024 | 07:32 AM
GatorsJMC's Avatar
GatorsJMC
Much more information posted here:
Check out post #328 forward
LT6 engine failures/problems
Old Jan 10, 2024 | 10:44 AM
Mitchell_B's Avatar
Mitchell_B
That's an irregular tapping and this is symptomatic of a problem engine.
Be aware going into this that GM does not want take apart any engines to 'fix' them because attempting this has, in the past, resulted in snapped cam tower bolts which further complicated the repair. Since then, most/all the pico tests have come back 'satisfactory' meaning - your car is okay.
Old Jan 10, 2024 | 11:27 AM
GatorsJMC's Avatar
GatorsJMC
I'm curious where your information comes from within GM. My "repair" was just done in December and I saw two Pico Scan graphs of the before and after the TSB was done. It clearly depicted less amplitude in the display and the sound was less pronounced after the TSB work.
Coming from a mechanical lifter- tappet background from years ago, too much valve/ rocker clearance meant too much wear. Fast forward to todays LT6 cam follower set up, my thoughts were the same- too much noise meant too much wear in the cam-follower arrangement. Have you seen how low the torque settings are for the cam cap bolts? I was surprised, myself...
To C8Z Valve Tick
Old Jan 10, 2024 | 11:39 AM
Mitchell_B's Avatar
Mitchell_B
[QUOTE=GatorsJMC;1607412960]I'm curious where your information comes from within GM. My "repair" was just done in December and I saw two Pico Scan graphs of the before and after the TSB was done. It clearly depicted less amplitude in the display and the sound was less pronounced after the TSB work./QUOTE]
The engine still had the valvetrain/tick after the repair, it was just less pronounced, but still there - you are saying?
Old Jan 10, 2024 | 11:42 AM
GatorsJMC's Avatar
GatorsJMC
[QUOTE=Mitchell_B;1607413008]
Affirmative, my friend
Old Jan 10, 2024 | 11:53 AM
Mitchell_B's Avatar
Mitchell_B
[QUOTE=GatorsJMC;1607413018]
So, in your case, it seems GMs 'fix' made the problem better, but did not truly fix the problem?
